LM339 H-Bridge — Parallax Forums
LM339 H-Bridge
morris4019morris4019 Posts: 145
edited 2009-05-06 02:00 in Robotics
I've been looking for awhile and was just wondering if anyone has been able to use an LM339 w/ transistors to build a "smoke-proof" motor driver. Looking at the pinout and reading up on it, I would assume that since it has 4 outputs it looks like it would be possible to drive 1 dc motor with reverse, right? Similar to an op-amp? (Sorry if i am way wrong, trying to teach myself)
-Mike
······ I'll try everything once [noparse]:)[/noparse]
    edited 2009-05-03 13:27
    It is possible, but the LM339 is a poor choice for that purpose. It is a voltage comparator designed for lower speed applications.
  • GWJaxGWJax Posts: 267
    edited 2009-05-03 15:16
    morris4019 said...
    -Mike
    Mike I use the L298 chip which is a dual full bridge driver. Not once have I smoked one out but you need to attach a good heat sink to it. Attached is the data sheet for it. Hope this help you out.
    Jax
    If a robot has a screw then it must be romoved and hacked into..
  • PrettybirdPrettybird Posts: 269
    edited 2009-05-06 01:58
    ·· I reciently got 3··L6203 to use on a trackster. I like you am waiting for parts. Good deal for $7 + shipping. 48V 4 amps not bad.
    Forgot to mention on Ebay
