Uses for the Piezo Film Vibra Tab
UghaUgha Posts: 543
edited 2009-03-05 - 20:02:02 in Accessories
How have YOU used this sensor in your past projects?
  • Beau SchwabeBeau Schwabe Posts: 6,400
    edited 2009-02-27 - 16:08:57
    Ugha,
    Here is something that I experimented with awhile ago with mixed results.· I was hoping to be able to·transmit Audio (wireless bug), or something along those·lines, but I couldn't get the·resonant frequency high enough·to make that practical.· Instead, low frequency vibration worked ok.· Now, I didn't spend a great deal of time with it, so it could be refined and possibly made to work.
    Another theoretical application for the Piezo Film Vibra Tab, that I would like to experiment with would be in the area of Surface Doppler Acoustics where you have two sensors equidistant from an acoustic source on the surface of an object , for example a table.· Based on where and how you touch the table you disrupt the signal being received by the Piezo Film Vibra Tab sensors.· A differential comparison would/could reveal the location of the acoustic disturbance.
    [url=mailto:bschwabe@parallax.com]Beau Schwabe[/url]
    IC Layout Engineer
    671 x 831 - 106K
    Beau Schwabe -- Submicron Forensic Engineer
    www.Kit-Start.com - bschwabe@Kit-Start.com ෴෴ www.BScircuitDesigns.com - icbeau@bscircuitdesigns.com ෴෴
  • Oldbitcollector (Jeff)Oldbitcollector (Jeff) Posts: 8,089
    edited 2009-02-27 - 16:35:31
    Beau,
    I'll bet you could do a very small earthquake(tremor) detector with that circuit and a Propeller
    with an SD card/clock for logging. Shame I don't get that kind of activity here, or I might do it.
    OBC
    New to the Propeller?
    Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
    Got an SD card connected? - PropDOS
    <br>
    edited 2009-02-27 - 23:18:51
    http://forums.parallax.com/attachment.php?attachmentid=55474
    How I built Hand Fingers for Penguin Robot using Vibra Tab Mass
    humanoido
  • science_geekscience_geek Posts: 247
    edited 2009-03-04 - 21:01:58
    i use them to measure vibration of stuff, when my cousin used to live with me, we wouble tape a mass to the end of it, and then tape the sensor to his subwoofer in his car, we would then "know" what kind of vibration we were getting, we would then place them in various parts of his car and at certain distances away and measure the vibrations of the car, we actually would use them to find where high vibrations that would probably lead to a rattle. i am actually working with them this week to figure out the vibrations on a steam engine we are building for my small engines teacher. i am also working on getting a small display to act as a type of scope to graph the vibrations, once i get that working i am going to see where certain parts of the motor are and the likely problems of vibration come from
  • YendorYendor Posts: 288
    edited 2009-03-05 - 13:05:34
    In the Parallax documentation, it gives a 'switch' application that I have a few questions on:
    • On the mounting, can I place it on a flat surface·and it still generates an 'on' (e.g. applying pressure), or does it need to be elevated for flexing?·
    • Will the response remain 'on' as long as I apply pressure to the sensor?· This is in particular to mounting on a flat surface
    • Will the voltage change if I apply harder pressure if applied to·a flat surface?
    • I would imagine there's a certain amount of force that has to be applied if·there's a 5.1 zener applied.· Can this force be generated on a flat surface (e.g. pressure)?
    Also the web site in the documentation www.msiusa.com·is not correct.· It should be www.meas-spec.com
    Many thanks!
    Rodney
  • Tracy AllenTracy Allen Posts: 6,309
    edited 2009-03-05 - 16:31:20
    I have one on the front door of my shop, responds to people knocking (or trying to break in) with a light display in the window that varies with the time and intensity.
    Yendor, be sure to download the Piezo_Technical_Manual.pdf from www.meas-spec.com, under the literature link. It has LOTs of applications in addition to good device info. You will see that one application is as an acoustic pickup, where the sensor is fastened to a surface like a drum or sounding board. The sensor has to stretch or flex, and static pressure will not work well unless it causes some stress and strain in the surface the sensor is attached to. Not constant, but changing. It gives an analog output, proportional, not on-off in the sense of a switch. It is more like a capacitor that accumulates charge as a result of flexing, and that charge will leak off into any resistance (MOhms) that is present across the sensor. In my opinion, the zener is not really necessary, because the sensor can't generate enough current to damage the Stamp anyway. The best thing to do is get one, and hook it up to an oscilloscope so that you can experiment for yourself.
    Tracy Allen
    www.emesystems.com
    Thanks for the reference Tracy - I missed that on the web site.
    I'm seeing the light - thanks! I agree some experimentation is necessary, just wanted to make sure I'm going down the right path.
    Rodney
