PropLoader - Propeller Firmware Loader
This is a "Firmware Loader" for the propeller chip.
An earlier version of this program was posted on a different thread, any updates etc will be posted here.
This program is based upon the recently released Propellent.dll (V1.1).
This program requires the DotNet 2.0 Framework to run.
Any feedback/suggestions etc let me know.
Cheers
Post Edited (Praxis) : 6/17/2008 7:59:41 AM GMT
Cheers
zip
297K
Does it matter what file name/filter is used for load RAM? Seems to be looking for .EEPROM ... I always use .binary for RAM downloads.
I have modified the filters for RAM loading to default to binary, eeprom can also be selected.
Enrique, you can use it anyway you want.
kdoney, as the program contains our custom visual controls the source will not be available, however when I get a moment I will post a "vanilla flavored" version using standard window interface.
Cheers
This is a VS2008 project.
Cheers
I forgot that I had posted this program way back then.
This update just to bump it in case anyone else can make use of it.
Cheers.
