PLX-DAQ TIME and DATE at the same time issue
Serial.println("DATA,DATE,TIME,"); }Using an Arduino Uno.
I am having issues with the second value after the directive DATA.
Using the code above the output into my spread sheet is Column A: 7/29/2020 Column B: 0.79
If I swap them so TIME is the first value and DATE the second I get Column A: 7:11:19 PM Column B: 44041.00
If I delete either the DATE or the TIME all the rest works fine.
Here's the other relevant code in case I am unknowingly causing the problem somewhere else.
Serial.begin(9600); Serial.println("CLEARDATA"); Serial.println("LABEL,Date,Time,House,Shed,PUMP STATUS,PUMP CYCLES"); Serial.println("RESETTIMER"); Serial.print("DATA,DATE,TIME,"); Serial.print(HouseOutputValue); Serial.print(","); Serial.print(ShedOutputValue); Serial.print(","); if(PumpStatus == HIGH){ Serial.print("ON"); }else{ Serial.print("OFF");} Serial.print(","); Serial.println(PumpCycles);Thanks for any help. I realize this an old unsupported software.
https://www.parallax.com/downloads/plx-daq
The problem was a simple column format issue.
