PropBasic: SD Card - Page 2 — Parallax Forums
PropBasic: SD Card
2»
  • HarleyHarley Posts: 997
    edited 2010-09-15 11:53
    Sapieha,
    Thank you, I downloaded the two files (OSX version for me), but found the IDE Preferences under 'bst' not Tools' menu.
    Now to read the documentation to know what to do to begin.
  • SapiehaSapieha Posts: 2,964
    edited 2010-09-15 12:01
    Hi Harley
    You need start BSTC and link PropBasic to IDE before it can recognize it.
    Look on attachment
    Harley wrote: »
    Sapieha,
    1920 x 1080 - 310K
    edited 2010-09-15 13:33
    Sapieha, I don't see a screen anything like what you are showing. Mine is like this attachment; a .tiff format. Lower-case 'bst' for the application on the window title, and this next window.
    I don't have anything called BSTC, and if I did how does one link PropBasic to IDE. I don't have anything called PropBASICIDE. I'm wondering if I got something wrong somewhere.
    edited 2010-09-15 13:41
    Hi Harley.
    Sorry I dont know mych on OSX
    BUT in BST You need find Top Menu Like on my BST.
    And in it Tools --> IDE Preferences.
    I think that menu opens with one of round buttons Top Left on BST window
    Harley wrote: »
  • max72max72 Posts: 1,155
    edited 2010-09-16 03:04
    New test run, still the same set of SD cards. i hope to be able to test also a bigger one...
    debug results:
    ? - SDplay -
    Insert card : Card inserted.
    Card name=S016B ,Serial number=997232359
    0 93 1 50 19 89 128 227 118 217 207 255 22 64 0 79
    909 6 9
    Blocksize=512 ,Totalsectors=232960 ,Totalcapacity=119275520
    -- Data Written OK! --
    -- Data Read OK! --
    20 bytes of data back from card:
    ABCDEFGHIJKLMNOPQRST
    End.
    ? - SDplay -
    Card name=128MB ,Serial number=269180828
    0 54 0 50 23 89 129 221 118 218 255 129 150 64 0 233
    1909 6 9
    Blocksize=512 ,Totalsectors=488960 ,Totalcapacity=250347520
    -- Data Read OK! --
    End.
    ? - SDplay -
    Card name=SD256 ,Serial number=1615369124
    0 38 0 50 31 89 131 196 254 250 207 255 146 64 64 193
    3859 6 9
    Blocksize=512 ,Totalsectors=988160 ,Totalcapacity=505937920
    -- Data Read OK! --
    End.
    Thanks for your effort.
    Massimo
  • VonSzarvasVonSzarvas Posts: 3,630
    edited 2010-09-16 03:21
    Well, the quick fix is in sd.lib, around line 291...
    change
    INC SD_sectormult, 2
    to
    INC SD_sectormult, 1
    BUT, this does not solve the matter. The SD card spec clearly states to add 2 to the mult value. It might be your cards are a different version/standard to mine??
    1. I will look through the other "standards" to see if there is a case where adding 1 is desired!
    2. I kindly ask if any other forum members could try this routine to establish the results from a different source?
    Hope we can solve this soon...
    edited 2010-09-16 04:19
    Could it be related to the card size? Up to now I have been able to test it with small cards. Are yours bigger?
    Massimo
    PS: I solved the code modify issue putting a propeller pin to ground and using it as detect pin.
    edited 2010-09-16 06:27
    Massimo,
    Comparing your debugging data to mine I could find the problem! I was reading the wrong bits for the sd_mult, which by luck were correct on my cards !
    Here is the updated sd.lib with debug code still included. If you can report back that its ok, I will update the non-debug version at the top of this thread :)
    Thank you so much for your help.
    Max.
    edited 2010-09-16 13:57
    I'll be way from my cards for a couple of days. I'll test it ASAP.
    Thanks again.
    Massimo
    edited 2010-09-24 08:23
    I have updated the sd.lib to fix the "mult" problem identifed by MAX72 (thank you Massimo!)
    The latest version is now available in the first post.
