waitpne in PASM
I don't know if anybody else has found this, but waitpne possibly needs some more instruction in the user manual for assembly. If I do:
Then it just goes round and round as fast as possible. The waitpne doesn't seem to stop execution at all. But if I do:
The all is good, and waitpne behaves as expected. (The extra and instruction is the only change - honest).
Am I missing something, or have others found the same thing?
It's not all that hard to count the number of grains of sand on the beach. The hardest part is making a start - after that it just takes time.·· Mirror - 15 May 2007
ScanInputs
waitpne LastIn,MaskIn 'Wait for a pin change
mov LastIn,INA 'Get the pins
wrlong foo, bar 'Tell spin about change
jmp #ScanInputs
LastIn long 0
MaskIn long $00_00_ff_00
ScanInputs
and LastIn,MaskIn 'Mask out unwanteds
jmp #ScanInputs
LastIn long 0
There's nothing wrong with the description in the manual, but something like your second code fragment could be a useful example of a common task in the "Assembly Code Examples for the Beginner" thread. If you do post it there, it would need a little more in the way of comments about what you're trying to do.
Paul Baker
