SPIN CODE EXAMPLES FOR THE BEGINNER (Public Version) - Page 6 — Parallax Forums
123468
  • Dave ScanlanDave Scanlan Posts: 160
    edited 2006-05-08 18:18
    ························································· EXAMPLE 19
    ·················· A/D CONVERSION WITH RESULTS DISPLAYED ON A VIDEO MONITOR··
                                         ADC0831
                                  /CS •1││8• Vcc +5
                                 Vin+ •2│        │7• CLK
                                  Vin-•3│        │6• DO
                                  GND •4││5• Vref
               +5V                        ADC0831
                │      Pin A0 -------→•1││8• -------- +5V
            10k ←-------------------→•2│        │7• ←------- Pin A2
                │                 │---•3│        │6• -----→ Pin A1  ←-- The series resistor is 10k.
               Vss             Vss│---•4││5• -------- Vref +5 V   The purpose of this resistor
    '        is to limit current.
              WARNING: DO NOT USE THE +5 VOLTS AS THE PROPELLER'S Vdd.
                       THE PROPELLER'S Vdd MUST NEVER EXCEED 3.6 VOLTS.
              NOTE: The ADC0831 is rated at 4.5 to 6.3 volts.  I was
                    able to get the ADC0831 to function using the
                    Propeller's 3.3 volts power supply.  How well
                    did it function? Don't know, but quick-and-dirty
                    testing looked ok.
                    RESISTOR SYMBOL IS NOT DISPLAYING CORRECTLY WHEN POSTED.
    '                                 EXAMPLE 19
    '         A/D CONVERSION WITH RESULTS DISPLAYED ON A VIDEO MONITOR
    'IMPORTANT: This example may require an understanding of example 09
    'WHAT'S NEW IN THIS EXAMPLE:
    '       ADC0831 A/D CONVERTER
    '          1. This is a serial 8-bit converter.
    '          2. Zero to 5 volt range on a single 5 volt power supply.
    '          3. Conversion time: 32uS.
    '          4. Supply voltage 4.5 to 6.3 volts.
    '          5. With an overshoot, the digital output is about 5 volts.
    '             Since the Propeller is a 3.3 volt device, it is prudent
    '             to add a 10k resistor between Pin 6 of the ADC0831
    '             and Pin A1 of the Propeller.  This limits the current
    '             at Pin A1 of the Propeller.
    '          6. References: [url=http://www2.ics.hawaii.edu/~chin/331/lab08c.pdf]http://www2.ics.hawaii.edu/~chin/331/lab08c.pdf[/url]
    '                       : [url=http://www.parallax.com/dl/sw/bs2Tutorial.ppt]www.parallax.com/dl/sw/bs2Tutorial.ppt[/url]
    '                         (Slides 223-230)
    '       BS2.SHIFTIN (DataPin, CLK_Pin, Mode, Bits)
    '          1. Shifts data in from a synchronous device.  In this case,
    '             the device is the serial A/D converter.
    'DIFFICULTY LEVEL: Easy
    'PURPOSE: The purpose of this Example is to illustrate how to interface
    '         a popular A/D device to the propeller and to illustrate how to
    '         display the results on a video monitor.
    '         WARNING: DO NOT CONNECT THE 5V SOURCE TO Vdd OF THE PROPELLER.
    '                  MAX VOLTAGE TO RUN THE PROPELLER IS 3.6V.
    'Submitted by Dave Scanlan, May 8, 2006
    'File: Example19_A2D_ADC0831_Video.spin
    'CORRECT OUTPUT:   The video monitor will dispaly the following:
    '                            EIGHT-BIT DECIMAL VALUE: XXX
    '                            ANALOG VOLTAGE INPUTTED: XXX cv
    CON
      _clkmode      = xtal1 + pll16x
      _xinfreq      = 5_000_000
      OUT = %1
      IN = %0
      HIGH = 1
      LOW = 0
      NewLine = 13
      ClearScreen = 0
      ADC_CS = 0           ' /CS Pin on Propeller
      ADC_Data = 1         ' Data Pin on Propeller
      ADC_CLK = 2          ' Clock Pin on Propeller
    OBJ
       BS2:          "BS2_Functions"
       VideoDisplay: "TV_Terminal"
    VAR
       Byte ADC_Result                             'A/D result (8 bits)
    PUB START                                      'Initialize VideoDisplay
        VideoDisplay.start
        SetScreenWhiteOnDarkBlue
        VideoDisplay.out(ClearScreen)              'Clear screen.
      Repeat
        A2D_Conversion
        DisplayOutputOfADC
    PRI A2D_Conversion
        DIRA[noparse][[/noparse]ADC_CS] := OUT
        DIRA[noparse][[/noparse]ADC_Data] := IN
        DIRA[noparse][[/noparse]ADC_CLK] := OUT
        OUTA[noparse][[/noparse]ADC_CS] := LOW     ' Select ADC chip
        ADC_Result := BS2.SHIFTIN(ADC_Data, ADC_CLK,BS2#MSBPOST,9)
        OUTA[noparse][[/noparse]ADC_CS] := HIGH    ' Deselect ADC chip when done
    PRI DisplayOutputOfADC
        VideoDisplay.str(string("EIGHT-BIT DECIMAL VALUE: "))'Send text to monitor.
        VideoDisplay.dec(ADC_Result)  'Sends a decimal value to a video monitor.
        VideoDisplay.out(NewLine)
        VideoDisplay.str(string("ANALOG VOLTAGE INPUTTED: "))'Send text to monitor.
        VideoDisplay.dec(ADC_Result * 500/255)  ' Hundredth of a volt
        VideoDisplay.str(string(" cv"))         ' cv (centivolt)
        VideoDisplay.out(NewLine)               ' Send a NewLine to monitor.
        WaitCnt(80_000_000 + Cnt)               ' One second delay
    PRI SetScreenWhiteOnDarkBlue                ' Sets the foreground color to
      VideoDisplay.out(3)                       '  white and the  background color
      VideoDisplay.out(5)                       '  to dark blue on the monitor.
    'ADDITIONAL INFORMATION
    '  WARNING: DO NOT CONNECT THE 5V POWER SOURCE TO Vdd OF THE PROPELLER.
    '  I DID NOT DO EXTENSIVE TESTING ON THIS EXAMPLE; THEREFORE, I CANNOT
    '  RECOMMEND IT FOR COMMERICAL APPLICATIONS. I BELIEVE IN MURPHY'S LAW.
    '  I did not check for failed initialization of VideoDisplay object.
    '  MEMORY USAGE:
    '    Program: 1,735 Longs
    '    Variables: 3,519 Longs
    '    Stack/Free: 2,935 Longs
    ······················································ FEW COMMENTS (EASIER TO READ)
                                         ADC0831
                                 Vin+ •2│        │7• CLK
                                  Vin-•3│        │6• DO
               +5V                        ADC0831
    '                                 EXAMPLE 19
    CON
      OUT = %1
      IN = %0
      HIGH = 1
      LOW = 0
      NewLine = 13
      ClearScreen = 0
      ADC_CS = 0
      ADC_Data = 1
      ADC_CLK = 2
    OBJ
    VAR
    PUB START
        VideoDisplay.start
      Repeat
        A2D_Conversion
        DisplayOutputOfADC
    PRI A2D_Conversion
      VideoDisplay.out(3)
      VideoDisplay.out(5)
    '  MEMORY USAGE:
    Post Edited (Dave Scanlan) : 5/15/2006 2:04:01 AM GMT
  • parskoparsko Posts: 501
    edited 2006-05-09 13:41
    Dave,
    Could you explain why the memory usage is so incredibly high??? That does not seem correct. I understand, though, that you state that you have not done extensive testing on this. Also, you may want to point out that this example almost seems like more of an example of using the serial in command, versus the A/D. You just motivated me to get my video out wired up. A/D is going to be my first real project. I'm also curious if you could provide an example using the discreet components version (non-dedicated peripherial ADC)?
    -Parsko
    edited 2006-05-09 15:34
    Hi Parsko,
    The memory usage is high because of all the objects that are being used: (1) TV_Terminal, (2) TV, (3) Graphics,
    ·and (4) BS2_Functions. Of course, my own code adds to the usage.
    SERIN·is for asynchronous communication.· This example uses SHIFTIN (synchronous communication).· As for using a capacitor and resistor for
    the A/D process, I will do that if others want to see it too.· How about an example using flash A/D?· Flash is fun stuff, for me at least.
    On second thought, I will do the cap/resistor A/D.· It is very easy to do with the objects that
    are available.
    I personally would not use this example for a commercial application until I had done about 25 measurements with calibrated
    equipment to test this circuit.· I also found some noise on the data pin.· Perhaps, one should consider bypass caps and/or a
    pullup resistor.
    As for today, well, I've got to go to work in a few minutes.· I will try to answer any further question later today.
    You are right...video is·fun stuff.· Isn't the Propeller great!!!!
    Dave
    parsko said...
    Dave,
    -Parsko
    Post Edited (Dave Scanlan) : 5/9/2006 3:58:07 PM GMT
  • SawmillerSawmiller Posts: 276
    edited 2006-05-09 16:45
    have a problem with example 13 using lcd's
    the line lcd.newline
    in my library and examples (prop .95)
    there isnt a lcd.newline procedure in my debug_lcd (updated 29 apr)
    where can i get the latest and greatest ? the library still show ver 1.0
    thanks
    dan
    edited 2006-05-09 16:53
    I could add that method -- in the meantime you can use
    · lcd.putc(13)
    Jon Williams
    edited 2006-05-09 23:19
    Hi Parsko,
    I was in such a hurry to get to work, that I did not read your words carefully.· Now I see what you meant about serial-in.· Yes, the example
    has a lot to do with processing data serially.· I was hoping that people would refer to PBASIC for this serial processing: SHIFTIN
    Sorry about the NewLine method. It was in the object I used. Perhaps you are missing one of the supporting objects.
    Dave
    parsko said...
    Dave,
    -Parsko
    edited 2006-05-13 18:52
    ·'······································ EXAMPLE 20
    '············ THIS EXAMPLE MEASURES THE CHARGE TIME OF A CAPACITOR,
    '·················· USES TWO COGS, AND HAS VIDEO OUTPUT
    '                                EXAMPLE 20
    '             THIS EXAMPLE MEASURES THE CHARGE TIME OF A CAPACITOR,
    '                   USES TWO COGS, AND HAS VIDEO OUTPUT
    'IMPORTANT: This example may require an understanding of examples 6 & 9
    '     WHAT'S NEW:
    '       RCTIME METHOD
    '       - This method measures in clock pulses (12.5 ns) the time it
    '         takes to charge a capacitor (0.1uf) in an R/C circuit.
    '         The resistor in the circuit is a 10k pot.
    'PURPOSE:
    '  -- The purpose of this example is to illustrate how to program
    '     an RCTIME method and how to use it. The output from the RCTIME
    '     method is converted to microseconds before being displayed
    '     on the video monitor.
    'Submitted by Dave Scanlan, May 13, 2006
    'File: Example20_RCTimeTwoCogs __.spin
    'CORRECT OUTPUT:  The approximate time in microseconds for the 0.1uf
    '                 capacitor to charge is displayed as below:
    '                         VIDEO DISPLAY UNIT
    '                  _________________________________
    '                 | CAP CHARGE TIME: ~XXX us        |
    '                 |_________________________________|
    CON
      NewLine = 13
    VAR
      Long  Count
      Long  stack0[noparse][[/noparse]60]  'Sets up a stack space for a Cog(processor)
      Long  stack1[noparse][[/noparse]50]  'Sets up a stack space for a second Cog(processor)
    OBJ
    PUB Start
      VideoDisplay.Start
      CogNew(RCTIME, @stack0)
      CogNew(DisplayCount, @stack1)
    PRI RCTIME | ClkStart, ClkStop, Pin, State, Out, In, High
      High := 1
      Out  := %1
      In   := %0
      Pin  := 0
      State := 1
      Repeat
        DirA[noparse][[/noparse]Pin] := Out
        OutA[noparse][[/noparse]Pin] := High      ' Discharge the 0.1uf capacitor
        WaitCnt(80_000 + Cnt)  ' 1ms pause
        DirA[noparse][[/noparse]Pin] := In        ' Reads high or low.
        ClkStart := Cnt                    ' Counter value at Start
        Waitpne(State << Pin, |< Pin, 0)   ' Wait for low on Pin 0
        ClkStop := Cnt                     ' Counter value at Stop
        Count := (ClkStop - ClkStart)      ' 12.5ns units
    PRI DisplayCount
      Repeat
        VideoDisplay.Str(String("CAP CHARGE TIME: ~"))
        VideoDisplay.Dec(Count * 125/10_000) 'Time in microseconds
        VideoDisplay.Str(String("us"))
        VideoDisplay.Out(NewLine)
      VideoDisplay.out(3)
      VideoDisplay.out(5)
    '   The code used in the RCTIME method is a modification
    '   of Martin Hebel's code in BS2_Functins.spin.
    '   According to my 7904 Tektronics scope, cap charge times
    '   displayed on the video monitor in this example are
    '   in close, but not in perfect, agreement with the scope's.
    '       IT WOULD BE GREAT IF SOMEONE WITH ACCURATE
    '       EQUIPMENT WOULD CHECK THESE CHARGE TIMES.
    '   Memory Usage:
    '   - Program:    1,719 Longs
    '   - Variables:  3,630 Longs
    '   - Stack/Free: 2,839 Longs
    Post Edited (Dave Scanlan) : 5/13/2006 7:11:27 PM GMT
    368 x 232 - 10K
  • cocokiwicocokiwi Posts: 75
    edited 2006-05-14 08:11
    Bruce Bates said...
    Dave -
    At the possible risk of seeming to go off topic slightly, I wish Adobe or someone would publish just some simple tools, not unlike what Microsoft has done, to do minimal manipulation of their PDF files. The universality of the format is well respected in most quarters, but once they're "locked in", you need deeper pockets than I have, to get the information back out, unless you're just looking to extract some simple text, or a single graphic or two which is not "protected" <sigh>.
    Just to bring this back on topic, nothing would please me more, than if I had access to just such a program so that I could take all of these marvelous Propeller examples (THANKS Dave and others!), Propeller tips, tricks, and hints, and the Parallax prepared Propeller documentation, etc. and build my own personal Propeller Notebook. The REALLY nice thing about something like that is you could make personal notations therein, as to who the "experts" are in all the various application-specific areas which have been mentioned on this Propeller Forum, for possible future reference, without having to re-scan all the messages to find those gurus!
    Bruce Bates
    ·Well, this may solve everyones problem!· FREE tooscool.gif It works as a reader!
    · The PRO version $39.95 has a library function that may do the trick.
    ·http://www.foxitsoftware.com/
    ·Cheers Dennis
    http://people.delphiforums.com/cocokiwi/Image/picture.jpg
    Post Edited (cocokiwi) : 5/14/2006 8:25:24 AM GMT
    edited 2006-05-14 11:58
    Hi Dennis,
    I checked out the PDF software site below.··A person·certainly can't grip about the price.
    Dave
    cocokiwi said...
    Bruce Bates said...
    Dave -
    Bruce Bates
    ·Cheers Dennis
  • Brian RileyBrian Riley Posts: 626
    edited 2006-05-14 19:47
    Dave Scanlan said...
    EXAMPLE 19
                                         ADC0831
                                  /CS &#8226;1&#9474;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#9474;8&#8226; Vcc +5
                                 Vin+ &#8226;2&#9474;        &#9474;7&#8226; CLK
                                  Vin-&#8226;3&#9474;        &#9474;6&#8226; DO
                                  GND &#8226;4&#9474;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#9474;5&#8226; Vref
               +5V                        ADC0831
                &#9474;      Pin A0 -------&#8594;&#8226;1&#9474;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#9474;8&#8226; -------- +5V
            10k &#61628;&#8592;-------------------&#8594;&#8226;2&#9474;        &#9474;7&#8226; &#8592;------- Pin A0
                &#9474;                 &#9474;---&#8226;3&#9474;        &#9474;6&#8226; ---&#61629;&#61630;--&#8594; Pin A1  &#8592;-- The series resistor is 10k.
               Vss             Vss&#9474;---&#8226;4&#9474;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#61569;&#9474;5&#8226; -------- Vref +5 V   The purpose of this resistor
    Dave, a small typo here. You have in the diagram above labele pin 7 of the ADC0831 as "A0" - it should be "A2" according to your actual code. "A0" is the Chip Select "CS". The problem is in both copies of the source code.
    cheers ... brian riley, n1bq, underhill center, vermont
    See the K107 Serial LCD Controller at
    www.wulfden.org/k107/
    edited 2006-05-15 02:16
    Brian,
    The typing error has been fixed.
    Thanks for spotting·the error·and for taking the time to report it.
    Did you try out the example?
    Dave
    Brian Riley said...
    EXAMPLE 19
                                         ADC0831
               +5V                        ADC0831
            10k &#61628;&#8592;-------------------&#8594;&#8226;2&#9474;        &#9474;7&#8226; &#8592;------- Pin A0 (Change A0 to A2)
    Post Edited (Dave Scanlan) : 5/18/2006 4:05:45 AM GMT
    edited 2006-05-19 13:51
    EXAMPLE 8 AND EXAMPLE 18
    IF YOU HAVE THE LATEST VERSION OF THE PROPELLER DEMO BOARD, CHANGES HAVE
    BEEN MADE SO THAT THE KEYBOARD OBJECTS AND CODE ARE DIFFERENT FROM
    THE EARILER VERSION OF THE DEMO BOARD.· THE EXAMPLES I WROTE ARE FOR THE
    EARLIER VERSION.
    THE EARLIER VERSION USES THIS OBJECT: Keyboard_iso.spin
    THE LATEST VERSION USES THIS OBJECT: Keyboard.spin
    See·this thread for changes and modifications: "keyboard_iso"
    http://forums.parallax.com/showthread.php?p=587529
    SORRY ABOUT THE CONFUSION.· I JUST FOUND OUT ABOUT THESE CHANGES TODAY, MAY 19, 2006.
    If I had the latest version of the demo board, I would·post Examples 8 and 18 using the·code for this demo board version.·I can't post code unless I can test it.
    The code I posted works perfectly with the earlier demo boards.
    Post Edited (Dave Scanlan) : 5/19/2006 5:11:55 PM GMT
    edited 2006-05-30 07:34
    ···········EXAMPLE 21
    ···W/R TO AN EXTERNAL EEPROM(24LC32A) USING I2C
    ·AND DISPLAY RESULT ON AN LCD·
    '      SERIAL EEPROM                                   SERIAL LCD (4x20)
    '       _______                                      _____________________
    'Vss &#8592;&#9547;&#8226;&#9474;1   8|&#8226;&#8594;Vdd (3.3 VDC)        (Pin A2)RX--&#8594; &#9474;                     &#9474;
    '     &#9507;&#8226;|     |&#8226;&#8594;Vss (Write Enabled)         +5&#8592;--- &#9474;     LCD SCREEN      &#9474;
    '     &#9507;&#8226;|     |&#8226;SCL--------&#8226;--R1--&#8594; Pin A1  Gnd---&#8594; &#9474;                     &#9474;
    '     &#9507;&#8226;|4___5|&#8226;SDA---&#8226;----|--R2--&#8594; Pin A2          &#9474;_____________________&#9474;
    '       EEPROM        R3   R4
    '       24LC34A       &#8595;    &#8595;                        R1: 160
    '                    Vdd  Vdd  (3.3VDC)             R2: 160
    '                                                   R3: 4.7K
    '                                                   R4: 4.7K
    '                               EXAMPLE 21
    '                  W/R TO AN EEPROM(24LC32A) USING I2C
    '                    AND DISPLAY RESULT ON AN LCD
    'IMPORTANT: This example may require an understanding of other examples
    '   I2C: The name I2C is shorthand for a standard Inter-IC
    '        (integrated circuit) bus.
    '         1.  Basically it is a two-wire bus using a bi-directional
    '             data line (SDA: Seral DAta) and a clock line
    '             (SCL: Serial CLock).
    '         2.  Resources: [url=http://www.embedded.com/story/OEG20010718S0073]http://www.embedded.com/story/OEG20010718S0073[/url]
    '                    ww1.microchip.com/downloads/en/DeviceDoc/21713F.pdf
    '         3.  This is a commonly used serial interface for IC devices.
    '   24LC32A: This is an 8-pin, serial, 4096 byte (32Kbits) EEPROM. It uses
    '            an I2C protocol.
    '            CHARACTERISTICS:
    '              1. 1,000,000 Erase/Write cycles
    '              2. Max clock: 400 KHz
    '              3. 2.5 to 5.5 volts
    '   Control byte for 24LC32A: %1010_000_0
    '          FUNCTION OF BITS:
    '            1.  1010 is the device ID
    '            2.  000 These are the  bus-address bits for this device.
    '                  -- Eight devices (0-7) are possible on this bus.
    '                  -- This example uses address 000.
    '                  -- 000 was selected by grounding pins 2,3,and 4
    '            3.  0 is the R/W bit. 0 = Write; 1 = Read
    '                  -- This "tells" the EEPROM what the operation is
    '                     going to be: Write or Read.
    'DIFFICULTY LEVEL:  Intermediate
    'PURPOSE: This example illustrates:
    '         1. How to hookup a serial EEPROM (24LC32) to the Propeller
    '         2. How to hookup a Parallax, serial LCD (20x4) to the Propeller
    '         3. How to Write to and Read from a 24LC32 using I2C protocol
    '         4. EVERY EFFORT WAS MADE TO SIMPLIFY THE I2C ALGORITHM.
    'Submitted by Dave Scanlan, May 30, 2006
    'File: Example21_EEPROM_I2C_LCD.spin
    'CORRECT OUTPUT:
    ' 1. Write:xxx (Shows the values as they are being written to the EEPROM.)
    ' 2. Read:xxx (Shows the values as they are being read from the EEPROM.)
    ' 3. W/R Failures:xxx (Shows the number of W/R failures.)
    ' 4. W/R Passes:xxxxx (Shows the number of successful W/R operations.)
    ' 5. ALL LOCATIONS OK (Displayed at the end of W/R's if there are
    '                      no W/R failures.)
    ' 6. All values are displayed in real-time on the LCD.
    '                                 SERIAL LCD (4x20)
    '                             |&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;|
    '              (Pin A2) RX--&#8594; &#9474;Write:xxx  Read:xxx     &#9474;
    '                      +5&#8592;--- &#9474;W/R Failures:xxx        &#9474;
    '                  Ground---&#8594; &#9474;W/R Passes:xxxxx        &#9474;
    '                             &#9474;ALL LOCATIONS OK        &#9474;
    '                             &#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;&#61574;
    CON
       SDA  = 0                   'EEPROM Data pin
       SCL  = 1                   'EEPROM Clock pin
       IN   = %0                  'Pin direction
       OUT  = %1                  'Pin direction
       LOW  = 0                   'Pin state
       HIGH = 1                   'Pin state
       Ack  = 0                   'Valid data transfer
       Nak  = 1                   'Invalid data transfer
       LCD_Pin   = 2              'The LCD is connected to pin A2.
       LCD_Baud  = 19_200         'Baud
       LCD_Lines = 4              'The number of lines on this LCD
    VAR
      Byte EEPROM_ID              'Device ID: 1010 MSBits
      Word EEPROM_Address         'Holds EEPROM addresses used in
    '                              Write/Read operations.
      Byte Data                   'Holds Data to be stored in the EEPROM
      Byte AddrOrData             'Working byte for TX and RX routines
      Byte Ack_I2C                'Ack bit from device
      Byte Index                  'Used to index LOOKUP
      Byte ValueStored            'Holds the value to be written to EEPROM
      Byte ValueRead              'Holds the value read from the EEPROM.
      Word WriteReadFailures      'Holds the number of W/R failures
      Word WR_Passes              'Holds the number of successful W/R passes.
      Byte HiByte                 'Holds the MSB of the EEPROM address
      Byte LoByte                 'Holds the LSB of the EEPROM address
    OBJ
      LCD : "Debug_Lcd"           'Code must be able to access Debug_Lcd
      BS2 : "BS2_Functions"       'Code must be able to access BS2_Functions
    'START
    PUB Start
     Initialization                            'Calls Initialization Method
      Repeat EEPROM_Address FROM 0 to 4095     'Used to generate 4096 EEPROM
    '                                           addresses for Writing to and
    '                                           Reading from the EEPROM.
        Repeat Index FROM 1 TO 4               'Tests each EEPROM location
    '                                           using four values.
          ValueStored := LOOKUP(Index: $FF, $AA, $55, $00) 'Four test values
          Data := ValueStored                  'Data is used in Write_Byte
          Write_Byte                           'Calls Write_Byte Method.
          BS2.PAUSE(10)                        'PROGRAM "MUST" PAUSE
          Read_Byte                            'Calls Read_Byte Method
          ValueRead := Data                    'Data value comes from Read_Byte
          DisplayResultsOnLCD                  'Calls DisplayResultsOnLCD
      If WriteReadFailures == 0                'If all locations test OK,
        LCD.GotoXY(0,3)                        ' ALL LOCATIONS OK is
        LCD.STR(STRING("ALL LOCATIONS OK "))   ' displayed.
    'INITIALIZATON
    PRI Initialization
      EEPROM_ID := %1010_000_0           'Device ID: 1010 (MSBits)
      LCD.Start(LCD_Pin, LCD_Baud, LCD_Lines) 'Initialize LCD object
      BS2.Start(31,30)                   'Initialize BS2 object
      LCD.Cls                            'Clear Screen on LCD
      LCD.Backlight(1)                   'Turn on LCD backlight
      LCD.GotoXY(0,0)                    'Go to Home position on LCD
      LCD.STR(STRING("Write:"))          'For value written to EEPROM
      LCD.GotoXY(10,0)
      LCD.STR(STRING("Read:"))           'For value read from EEPROM
      LCD.GotoXY(0,1)
      LCD.STR(STRING("W/R Failures:"))   'W/R failures
      LCD.GotoXY(0,2)
      LCD.STR(STRING("W/R Passes:"))     'W/R successes
    'DISPLAY Results on LCD
    PRI DisplayResultsOnLCD
      LCD.GotoXY(6,0)                   'Puts cursor at Col 5, Line 0
    '                                    (Cols and Lines start at 0,0)
      LCD.DEC(ValueStored)              'Current value Written
      LCD.GotoXY(15,0)
      LCD.DEC(ValueRead)                'Current value Read
      LCD.GotoXY(13,1)
      If ValueStored <> ValueRead       'Tracks W/R failures.
        WriteReadFailures := WriteReadFailures + 1
      LCD.DEC(WriteReadFailures)
      LCD.GotoXY(11,2)
      If ValueStored == ValueRead       'Tracks W/R successes
        WR_Passes := WR_Passes + 1
        LCD.DEC(WR_Passes)
    'WRITE_Byte
    ' -- See this URL for a full understanding of the Write algorithm:
    PRI Write_Byte
      Start_I2C                      'Send Start bit to EEPROM
      AddrOrData := EEPROM_ID & %1111_111_0  'Set "0" WRITE bit
      TX_Byte                        'Send Write bit to EEPROM
      IF (Ack_I2C == Nak)            'Wait until not busy
          Write_Byte
      HiByte :=  EEPROM_Address >> 8 'Get High address byte
      AddrOrData := HiByte
      TX_Byte                        'Send High address byte to EEPROM
      LoByte :=  EEPROM_Address      'Get Low address byte
      AddrOrData := LoByte
      TX_Byte                        'Send Low address byte to EEPROM
      AddrOrData :=  Data
      TX_Byte                        'Send Data byte to EEPROM
      Stop_I2C                       'Send Stop bit to EEPROM
    'READ_Byte
    ' -- See this URL for a full understanding of the Read algorithm:
    PRI Read_Byte
      IF (Ack_I2C == Nak)            'Wait until EEPROM not busy
         Write_Byte
      AddrOrData := HiByte           'HiByte for code clarity
      AddrOrData := LoByte           'LowByte for code clarity
      TX_Byte                        'Send LoByte address byte to EEPROM
      Start_I2C                      'End Write and Prepare to Read EEPROM
      AddrOrData := EEPROM_ID | %0000_000_1   'Set READ bit "1".
      TX_Byte                        'Send READ bit to EEPROM
      RX_Byte                        'Get Data byte from EEPROM
      Data := AddrOrData             'Put data from EEPROM in Data
    'RX_Byte
    '-- See PBASIC documentation for a basic understanding of SHIFTIN and
    '   SHIFTOUT.
    PRI RX_Byte
      Ack_I2C := Nak                                  'Nak = High
      AddrOrData := BS2.SHIFTIN(SDA,SCL,BS2#MSBPRE,8) 'Get data from EEPROM
      BS2.SHIFTOUT (SDA, SCL,Ack_I2C, BS2#LSBFIRST,1) 'Send ACK or NAK
    'TX_Byte
    '   SHIFTOUT
    PRI TX_Byte
      BS2.SHIFTOUT (SDA, SCL,AddrOrData, BS2#MSBFIRST,8)
      Ack_I2C := BS2.SHIFTIN(SDA,SCL,BS2#MSBPRE,1)   '1=NO NAK; 0=ACK
    'START
    ' -- See this URL for a full understanding of the Start algorithm:
    ' -- This code should be easy to follow, because it does not
    '    depend on pullup resistor conditions; and it follows the
    '    start algorithm perfectly.
    ' -- There are more statements than some would deem necessary, but
    '    these statements produce scope pulses that perfectly match the
    '    algorithm. Some statements could be eliminated if processing
    '    time is a major consideration. (See comments below.)
    PRI Start_I2C
      DIRA[noparse][[/noparse]SCL] := OUT
      OUTA[noparse][[/noparse]SCL] := LOW   'Could be eliminated to save processing time
      DIRA[noparse][[/noparse]SDA] := OUT
      OUTA[noparse][[/noparse]SDA] := HIGH
      OUTA[noparse][[/noparse]SCL] := HIGH
      OUTA[noparse][[/noparse]SDA] := LOW    'Sets SDA to Low to trigger START in I2C.
    '                      START is triggered by transitioning SDA to a low
    '                      while SCL is high.
      OUTA[noparse][[/noparse]SCL] := LOW  'Get ready for address and data
    '                    Could be eliminated to save processing time
    'PULSES GENERATED BY THE START CODE:
    '    __    ___
    '      &#9474;  &#9474;    SDA Pulse
    '      &#9474;__&#9474;
    '      __
    '     &#9474;  &#9474;
    '  ___&#9474;  &#9474;___  SCL Pulse
    'STOP
    ' -- See this URL for a full understanding of the Stop algorithm:
    '    stop algorithm perfectly.
    PRI Stop_I2C
      OUTA[noparse][[/noparse]SDA] := HIGH   'Sets SDA High to trigger a STOP in I2C.
    '                      STOP is triggered by transitioning SDA to a high
    'PULSES GENERATED BY THE STOP CODE:
    '    __    ___
    '      &#9474;__&#9474;
    '        __
    '       &#9474;  &#9474;
    'ADDITIONAL INFORMATION:
    '  -- This program is an adaptation of a PBASIC program written by Jon
    '     Williams.
    '  -- This code "should" work with other serial, 8-pin EEPROMs such as
    '     the 24LC64, 24LC128, 24LC256, and 24LC512. These device have
    '     NOT been tested with this code.  Minor modifications may be
    '     necessary.
    ' --  The LCD (4x20) is from Parallax: Stock#: 27979
    ' --  The EEPROM (24LC32A) is from Parallax: Stock#: 604-00020
    ' --  Over 300,000 W/R operations were used to test this code.
    '     No failures were detected.  Only one EEPROM was used.
    ' --  The code for Start_I2C and Stop_I2C was carefully checked
    '     with a 500 MHz Tektronix scope to be sure that the timing is correct.
    ' --  In my opinion, this program has too many global variables; but in order
    '     to make the code easy to understand, I did not use arguments and
    '     parameters to communicate between methods.
    ' --  CAUTION: DO NOT ALLOW THE +5 VOLTS, USED WITH THE LCD, TO POWER
    ' --  THE PROPELLER.
    ' --  This code is intended for educational purposes only.
    ' --  This code is intended to be used with a single EEPROM with the
    '     device address set to 000.
    ' --  I have used "W/R" instead of the standard "R/W" because this is the
    '     order of operations in this example.
    ' --  R1 and R2 are not necessary unless you have more than one device
    '     accessing the I2C bus.  These two resistors will compensate for a
    '     possible bus short when more than one device is accessing the bus.
    ······························· FEWER COMMENTS (EASIER TO READ)
    '                      FEWER COMMENTS (EASIER TO READ)
    '     &#9507;&#8226;|     |&#8226;SCL--------&#8226;-R1-&#8594; Pin A1    Gnd---&#8594; &#9474;                     &#9474;
    '     &#9507;&#8226;|4___5|&#8226;SDA---&#8226;----|-R2-&#8594; Pin A0            &#9474;_____________________&#9474;
    '       EEPROM        R3   R4                        R1: 160
    '       24LC34A       &#8595;    &#8595;                         R2: 160
    '                    Vdd  Vdd  (3.3VDC)              R3: 4.7K
    '                                                    R4: 4.7K
    '                               EXAMPLE 21
    'CORRECT OUTPUT:
    '                      no W/R failures.)
    '                                 SERIAL LCD (4x20)
    'File: Example21_FewerComments.spin
    CON
       SDA  = 0
       SCL  = 1
       IN   = %0
       OUT  = %1
       LOW  = 0
       HIGH = 1
       Ack  = 0
       Nak  = 1
       LCD_Pin   = 2
       LCD_Baud  = 19_200
       LCD_Lines = 4
    VAR
    OBJ
      LCD : "Debug_Lcd"
    'START
    PUB Start
     Initialization
          Data := ValueStored
          Write_Byte
          Read_Byte
          ValueRead := Data
          DisplayResultsOnLCD
        LCD.GotoXY(0,3)
    'INITIALIZATON
    PRI Initialization
      BS2.Start(31,30)
      LCD.Cls
      LCD.Backlight(1)
      LCD.GotoXY(0,0)
      LCD.GotoXY(10,0)
      LCD.GotoXY(0,1)
      LCD.GotoXY(0,2)
      LCD.GotoXY(6,0)
      LCD.GotoXY(15,0)
      LCD.DEC(ValueRead)
      LCD.GotoXY(13,1)
      LCD.GotoXY(11,2)
        LCD.DEC(WR_Passes)
    'WRITE_Byte
    PRI Write_Byte
          Write_Byte
      AddrOrData :=  Data
    'READ_Byte
    PRI Read_Byte
         Write_Byte
      Start_I2C                      'Prepare to READ EEPROM
      AddrOrData := EEPROM_ID | %0000_000_1   'Set "1" READ bit.
    'RX_Byte
    PRI RX_Byte
    'TX_Byte
    PRI TX_Byte
    'START
    PRI Start_I2C
     'STOP
    PRI Stop_I2C
    '     Williams.
    Post Edited (Dave Scanlan) : 6/1/2006 5:56:53 PM GMT
  • Kaos KiddKaos Kidd Posts: 614
    edited 2006-05-30 13:53
    Dave: I love these demos, and all the comments. It does a great service to you for coding and answering the questions, as well as me, to see some of the things in actual working program. THanks again. I have some questions, but before I ask, I'll go do some more reading...
    Fred
    Just tossing my two bits worth into the bit bucket
    KK
  • El PaisaEl Paisa Posts: 375
    edited 2006-05-30 15:33
    You guys should more consistent .
    Example 21 connects SDA to pin A0 and SCL to pin 1.
    The propkit and demo board uses A29 to SDA and pin 28 to pin A28.
    What is going on??
    edited 2006-05-30 15:36
    What is going on??
    I should said
    The propkit and demo board uses A29 to SDA and pin 28 to SCL.
    edited 2006-05-30 15:45
    El Paisa,
    Example 21 is showing how to hook up an external I2C memory (24LC32A) on A0, and A1 other than the memory the Propeller uses (24LC256) during power up on A28 and A29.
    There is not an issue of inconsistency here.
    Beau Schwabe
    IC Layout Engineer
    edited 2006-05-30 15:49
    Sorry.
    I understand now.
    edited 2006-05-30 15:52
    Hi Fred,
    Thanks for your words of support.
    I am wondering if·YOU and·OTHERS would comment on my coding in the Start and Stop routines.
    When I was coding these two algorithms using more traditional methods, I would occasionally get
    Write/Read errors.·
    I looked at the pulses generated and found both·fall and rise transitions of SDA while SLC was
    high for a START. I decided to make sure that a START only had a fall transitions while SLC was
    high; thus, I coded the algorithm as seen in the example.· I was concerned that the EEPROM
    was occasionally not "seeing" the fall transition, but was "seeing" the rise transition.· Both transitions
    were occurring close in time.
    I have now done about 300,000 W/R combinations without an error.
    BTW, your interaction on this forum is as good as it gets.· Thanks!
    Dave
    Post Edited (Dave Scanlan) : 5/31/2006 1:07:00 AM GMT
    edited 2006-05-30 16:15
    Thanks Beau.
    Also, thanks to you, El Paisa.· Your comment shows how important it is to
    think of all the ways a reader could·interpret things.· I changed the
    leading title to·include the words ·"External EEPROM" on Example 21.
    Dave
    Beau Schwabe (Parallax) said...
    El Paisa,
    edited 2006-05-30 16:26
    Dave:
    This is what my questions were about...
    I was sure there are timing specs needed for the I2C device between clock transactions.
    I know I read someplace the max clock was something, 20 mhz coms to mind, but I could be wrong...
    (I havent done the reading I said I was going to do before I posted my questions.)
    But... if there's a max speed for the I2C bus, that would, in part, define the pulse width and length, right?
    In your examples, you manually creating the clock levels, at the indicated code speed:
    Here's a link to the pdf with the timings...· Now, please understand, most of this is in the BFZ (Beyond Fred Zone), but I real sure that the speed of the propellrer running at the coded speed is way to fast...
    http://www.sparkfun.com/datasheets/IC/24LC256.pdf
    (BTW: I ordered 4 of these exact chips... )
    This could be part of the reason why you were getting errors without resulting to code you did.
    My new hardware is due today (Yea!), and I'll be reading and doing your code for my stuff...
    I have a long way to go on making it work, but I know when it's done, it will be worth it...
    I agree with you about all the global vars and stuff, and even for ease or reading, well documented code, suchs as yours, it would stand to reason:
    Make high & Low lever routines and pass params back and fourth.
    It would make for taking your examples and using them directly.
    Anyway, the heart of my questions are in the addressing of these eeproms:
    My intent is to hang 4 additional eeproms off the propellers 28/29 I2C bus, and how I would address them vs addressing the root eeprom (the propellers eeprom)...
    I can't tell by your example how you would change the address of the eeprom...
    KK
    Post Edited (Kaos Kidd) : 5/30/2006 4:34:56 PM GMT
    edited 2006-05-30 16:52
    Hi Fred,
    Thanks for your input.
    If you noticed, I stated in Example 21 to use one EEPROM with this code.· I am concerned that
    a short condition could occur on the bus with several devices.· Perhaps you should use
    220 ohm resistors at· SLC and SDA to protect the Propeller from a bus short.
    If Beau thinks this could be a problem, I will add these resistors to the schematic in Example 21.
    What do you advise, Beau?
    Dave
    Kaos Kidd said...
    Dave:
    edited 2006-05-30 18:01
    Sorry, Fred, I forgot to answer your question.
    You must select the bus addresses on your new EEPROMs through Spin code.
    Example 21 hard-wires the address.· You may not use 000 as the bus address
    for any of your added EEPROMS because it is being used by the Propeller EEPROM.
    You must also use 29/28 for your SDA, and SCL, if you can access them.· If
    not, perhaps·Parallax can suggest the best way to get at·them.
    If you are building up your system from "scratch" this should not be
    a problem: you will be able to access 29/28.
    Since I·believe in Murphy's Law and since I have never done this,
    please·take·my answer as a likely solution.· I try not to
    recommend something unless I·have duplicated the situation.
    Dave
    Fred asked:
    Post Edited (Dave Scanlan) : 5/31/2006 7:42:18 PM GMT
    edited 2006-05-30 19:02
    Dave,
    As a safety precaution that would probably be just fine. Although the 220 Ohm resistors are suggested to keep a 5V I/O minimized to about 20mA
    if there is a problem (short). Keeping the same theme with 3.3V this would be equivalent to using a 160 Ohm resistor. Probably doesn't matter, a
    220 Ohm resistor would functionally work just the same.
    Beau Schwabe
    IC Layout Engineer
    edited 2006-05-31 15:49
    Thanks, Beau.
    Two resistors R1 and R2 have been added to the schematic in Example21.· These are not necessary if
    only one device is using the I2C bus.· These two resistors will compensate for any potential
    bus short when using more than one device.
    Dave
    Dave,
    edited 2006-06-10 07:10
    ··································· EXAMPLE 22
    ······················· RFID READER WITH VIDEO OUTPUT
    ''           Parallax RFID Reader
    ''    ____________________________________
    ''   |                                    | R1: 1K Ohms
    ''   |                                    | (Limits current to P1)
    ''   |          ______________            |
    ''   |         |              |    GND    |&#8226; ------> Ground
    ''   |         |              |    SOUT   |&#8226; --R1--> P1-Demo Board Ver. C
    ''   |         | _____________|    ENABLE |&#8226; ------> P0-Demo Board Ver. C
    ''   |                             Vcc    |&#8226; ------>+5V DC
    ''   |____________________________________|
    ''                           EXAMPLE 22
    ''                 RFID READER WITH VIDEO OUTPUT
    ''IMPORTANT: Do not connect RFID +5 volt supply to the Propeller.
    ''WHAT'S NEW IN THIS EXAMPLE:
    ''    RFID READER
    ''        -- This device reads Radio Frequency ID tags.
    ''    SERIN_CHAR
    ''        -- SERIN_CHAR is a method used to input serial data from
    ''           RFID tags.
    ''DIFFICULTY LEVEL: Easy
    ''PURPOSE:
    ''   1. Illustrates how to connect an RFID reader to the Propeller.
    ''   2. Illustrates how to read and display RFID tag data using
    ''      the Parallax RFID reader.
    ''Submitted by Charlie Johnson, June 10, 2006, [noparse][[/noparse](C) C&C, Inc.]
    ''Modified, elaborated and posted by Dave Scanlan
    ''File: Example22_RFID_ReaderWithVideoOutput.spin
    ''CORRECT OUTPUT:
    ''               Video Display
    ''   | RFID TAG VALUES IN HEX AND ASCII   |
    ''   | XXXXXXXXXX                         |
    ''   | XXXXXXXXXXXXXXXXXXXXXXXX           |
    ''   | XXXXXXXXXX                         |
    CON
      RX_Pin = 1
      Enable_Pin = 0
      Out = %1
      Low = 0
      High = 1
      CR = 13
    VAR
      Byte Index
      Byte  Rx_Data[noparse][[/noparse]12]            'Holds RFID tag's 12-byte record
    OBJ
      VideoDisplay: "TV_Terminal"  'Declare VideoDisplay
      BS2: "BS2_Functions"         'Declare BS2
    PUB Start
      DirA[noparse][[/noparse]Enable_Pin] := Out
      VideoDisplay.Start(12)       'Instantiates VideoDisplay
      BS2.Start(31, 30)            'Instantiates BS2
      VideoDisplay.Str(String("RFID TAG VALUES IN HEX AND ASCII"))
      VideoDisplay.Out(Cr)
      Repeat
        OutA[noparse][[/noparse]Enable_Pin] := Low    'Enables RFID
        Index := 0
        Repeat 12                  'Gets 12 bytes from RFID reader
          Rx_Data[noparse][[/noparse]index++] := BS2.SERIN_CHAR(RX_Pin, 2400, BS2#NInv, 8)
        VideoDisplay.Str(@RX_data) 'Displays 10 RFID hex digits.
        Index := 0
        Repeat 12
          VideoDisplay.dec(RX_Data[noparse][[/noparse]Index++]) 'Displays full RFID in ASCII
        OutA[noparse][[/noparse]Enable_Pin] := High    'Disables RFID
        BS2.PAUSE(1_000)            'Pause for 1 second
        VideoDisplay.Out(3)
        VideoDisplay.Out(5)
    '' ADDITIONAL INFORMATION
    '' -- Be careful to not connect the RFID +5 volt supply to the Propeller
    '' -- Thanks for the contributions of Marty Hebel to BS2_Functions.
    '' -- Dave Scanlan does not support implanting RFID chips into humans.
    '' -- This example is intended for educational use only.
    Post Edited (Dave Scanlan) : 6/17/2006 8:23:43 PM GMT
  • NewzedNewzed Posts: 2,503
    edited 2006-06-18 14:19
    Dave, I just ran Charlies_RFID_Demo program.· My TV screen displayed:
    0415146F24
    10485249534952347050
    Sid
    edited 2006-06-18 20:07
    Sid,
    If you ran the exact same code as in Example 22, your output "should" have displayed the tag values correctly.
    I have tested this code repeatedly using 15 different RFID tags.· I used both the new and old versions of the demo boards.
    QUESTION: IF OTHERS HAVE RUN THIS CODE, DID·CODE RUN CORRECTLY OR INCORRECTLY?
    Newzed said...
    0415146F24
    Sid
    edited 2006-06-18 20:16
    Dave, I switched from Charlies RFID Demo code to the Example 22 code.· I now
    have a blue background!
    I ran about 10 tags and they all displayed the numbers correctly with both
    programs.·
    Sid
    edited 2006-06-18 20:48
    I wanted to display the ASCII numbers in binary so I changed:
    to read
    VideoDisplay.bin(RX_Data,8)
    All I got was·twelve 0000 1010 binaries.· What am I not doing?
    Sid
