BS2, BS2P Command differences — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2004-04-17 15:07 in General Discussion
I see there are additional commands available for the "P" series. Is
there a chart or table somewhere that shows the differences?
Dave
  • ArchiverArchiver Posts: 46,084
    edited 2004-04-14 18:04
    Open the help file. The PBASIC Command Reference (in the Contents pane)
    shows all the instructions and which processors they work with.
    You will find that there are no syntax differences between instructions
    that work on the BS2 and the BS2p -- but there may be a difference in
    required parameters (due to processor execution speed). One of the most
    frequent requirements for a parameter change is for SEROUT and SERIN.
    Since the new compiler lets us add conditional compilation structures, I
    have this fragment built into my template:
    #SELECT $STAMP
    #CASE BS2, BS2E, BS2PE
    T1200 CON 813
    T2400 CON 396
    T4800 CON 188
    T9600 CON 84
    T19K2 CON 32
    T38K4 CON 6
    #CASE BS2SX, BS2P
    T1200 CON 2063
    T2400 CON 1021
    T4800 CON 500
    T9600 CON 240
    T19K2 CON 110
    T38K4 CON 45
    #ENDSELECT
    Inverted CON $4000
    Open CON $8000
    Baud CON T9600
    This lets me handle SEROUT/SERIN parameter differences between members
    of the BS2 family without issue.
    -- Jon Williams
    -- Applications Engineer, Parallax
    -- Dallas Office
    Original Message
    From: dersonquilter2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ocMT7qEhN3C6OzoI5XaC_ruFHS5ynMWCXi6kAttgGZ4R5k-egiLJjP4DrxOOIakV1G6cWuUWIytdz_U5-tQZc84]dersonquilter2@y...[/url
    Sent: Wednesday, April 14, 2004 10:56 AM
    To: basicstamps@yahoogroups.com
    Subject: [noparse][[/noparse]basicstamps] BS2, BS2P Command differences
    Dave
    edited 2004-04-15 02:13
    Thank you, John. You mention "template". This sounds like something I should be
    using. Can you tell me how?
    Dave
    #SELECT $STAMP
    T1200 CON 813
    T2400 CON 396
    T4800 CON 188
    T9600 CON 84
    T19K2 CON 32
    T38K4 CON 6
    #CASE BS2SX, BS2P
    T1200 CON 2063
    T2400 CON 1021
    T4800 CON 500
    T9600 CON 240
    T19K2 CON 110
    T38K4 CON 45
    #ENDSELECT
    Inverted CON $4000
    Open CON $8000
    Baud CON T9600
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: dersonquilter2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6GmEgbMPYVmVVhZK6VERPN459Tg2tuIBOMtVXTrP5yq5u8D-ves9YEgLt-FbZb2WSi-7qG3ClJs1ua6YJFpA5m81]dersonquilter2@y...[/url
    Dave
    To UNSUBSCRIBE, just send mail to:
    basicstamps-unsubscribe@yahoogroups.com
    from the same email address that you subscribed. Text in the Subject and Body of
    the message will be ignored.
    Yahoo! Groups Links
    Do you Yahoo!?
    Yahoo! Tax Center - File online by April 15th
    edited 2004-04-15 02:35
    Sure.
    Create a blank programming template includes a bit of a framework that
    promotes sound programming (I'll post mine in the files section and you
    can modify it as you like). Once you have the file saved, follow these
    steps:
    1. Click Edit >> Preferences...
    2. Click "Files & Directories" tab
    3. Click "Browse" button next to the "New file template" field
    4. Locate your file, then click "Open"
    5. Click "OK" to close the preferences dialog
    Now when you select File >> New (or use the icon on the toolbar) the
    template code will be loaded in. Makes life easy.
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: David Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZgaqBpbiUSc1ShPeKL94TobO4ez65N1yIhEn5NlrLkPjhvJ1AQCulvEORIu4xaqd8oDBT5vj-_euFjdZDWw]dersonquilter2@y...[/url
    Sent: Wednesday, April 14, 2004 8:13 PM
    Subject: RE: [noparse][[/noparse]basicstamps] BS2, BS2P Command differences
    should be using. Can you tell me how?
    Dave
    #SELECT $STAMP
    T1200 CON 813
    T2400 CON 396
    T4800 CON 188
    T9600 CON 84
    T19K2 CON 32
    T38K4 CON 6
    #CASE BS2SX, BS2P
    T1200 CON 2063
    T2400 CON 1021
    T4800 CON 500
    T9600 CON 240
    T19K2 CON 110
    T38K4 CON 45
    #ENDSELECT
    Inverted CON $4000
    Open CON $8000
    Baud CON T9600
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: dersonquilter2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZgaqBpbiUSc1ShPeKL94TobO4ez65N1yIhEn5NlrLkPjhvJ1AQCulvEORIu4xaqd8oDBT5vj-_euFjdZDWw]dersonquilter2@y...[/url
    Dave
    Yahoo! Groups Links
    Do you Yahoo!?
    and Body of the message will be ignored.
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2004-04-15 21:28
    Thank you again, Jon. I am a pretty meticulous hardware man, trying to continue
    this with my programming.
    Jon Williams <jwilliams@p...> wrote:Sure.
    steps:
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: David Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ivV16hq6Ty9s3_X_kJwcHaBaaFasNgaF7wI-WB0AtqIiu5ImWbCLaKi9PjewkYNnYWgocNolj6BHysGygbMjgPdtYw]dersonquilter2@y...[/url
    Dave
    #SELECT $STAMP
    T1200 CON 813
    T2400 CON 396
    T4800 CON 188
    T9600 CON 84
    T19K2 CON 32
    T38K4 CON 6
    #CASE BS2SX, BS2P
    T1200 CON 2063
    T2400 CON 1021
    T4800 CON 500
    T9600 CON 240
    T19K2 CON 110
    T38K4 CON 45
    #ENDSELECT
    Inverted CON $4000
    Open CON $8000
    Baud CON T9600
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: dersonquilter2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ivV16hq6Ty9s3_X_kJwcHaBaaFasNgaF7wI-WB0AtqIiu5ImWbCLaKi9PjewkYNnYWgocNolj6BHysGygbMjgPdtYw]dersonquilter2@y...[/url
    Dave
    Yahoo! Groups Links
    Do you Yahoo!?
    Yahoo! Groups Links
    abuse@p....
    Yahoo! Groups Links
    Do you Yahoo!?
    edited 2004-04-15 22:10
    Hey I want in on this, where is the "files section"?
    KF4HAZ - Lonnie
    continue this with my programming.
    > steps:
    > -- Jon Williams
    > -- Dallas Office
    Original Message
    > From: David Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wK3B1wgx0jU6-4l0Fe8MXHtAFpVEgiI10V5Ne2O4wgGFp826l40ZA5_ihJuSb-739vxVrnm9nBbrSZdELB0]dersonquilter2@y...[/url
    > Dave
    > #SELECT $STAMP
    > T1200 CON 813
    > T2400 CON 396
    > T4800 CON 188
    > T9600 CON 84
    > T19K2 CON 32
    > T38K4 CON 6
    > #CASE BS2SX, BS2P
    > T1200 CON 2063
    > T2400 CON 1021
    > T4800 CON 500
    > T9600 CON 240
    > T19K2 CON 110
    > T38K4 CON 45
    > #ENDSELECT
    > Inverted CON $4000
    > Open CON $8000
    > Baud CON T9600
    > -- Jon Williams
    > -- Dallas Office
    edited 2004-04-15 23:42
    Thank you for that. Sloppy programming is the bane of my existance and
    I am striving to wipe it out. In case I didn't mention it, we have a
    nice little doc called "The Elements of PBASIC Style" that will give you
    some good guidelines.
    -- Jon Williams
    -- Parallax
    Original Message
    From: David Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kgfikJeW_YDbhXHFdMCyjmZx9ruM2S3HMhS5edG1i4e1Daz6-IQLTg85gmE1rEr_ssddL6k_y_lvN_3ZGwXsI_8F]dersonquilter2@y...[/url
    Sent: Thursday, April 15, 2004 3:29 PM
    steps:
    3. Click "Browse" button next to the "New file template" field 4. Locate
    your file, then click "Open" 5. Click "OK" to close the preferences
    dialog
    -- Jon Williams
    -- Dallas Office
    Original Message
    Dave
    #SELECT $STAMP
    T1200 CON 813
    T2400 CON 396
    T4800 CON 188
    T9600 CON 84
    T19K2 CON 32
    T38K4 CON 6
    #CASE BS2SX, BS2P
    T1200 CON 2063
    T2400 CON 1021
    T4800 CON 500
    T9600 CON 240
    T19K2 CON 110
    T38K4 CON 45
    #ENDSELECT
    Inverted CON $4000
    Open CON $8000
    Baud CON T9600
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: dersonquilter2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kgfikJeW_YDbhXHFdMCyjmZx9ruM2S3HMhS5edG1i4e1Daz6-IQLTg85gmE1rEr_ssddL6k_y_lvN_3ZGwXsI_8F]dersonquilter2@y...[/url
    Dave
    Yahoo! Groups Links
    Do you Yahoo!?
    Yahoo! Groups Links
    abuse@p....
    Yahoo! Groups Links
    Do you Yahoo!?
    Yahoo! Groups Links
    abuse@p....
    edited 2004-04-15 23:45
    http://groups.yahoo.com/group/basicstamps/files/
    You'll need to login to Yahoo to get to the files.
    -- Jon Williams
    -- Dallas Office
    Original Message
    [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=t4rX86jDqd7Ron7PomdwsIvLh0f6ueHti98ujyRU0EoWCmNQwJGApA4bB1nygxAUQzVB0iKmHGFrK9MgvyJLX78Jtdg]techsupport@f...[/url
    Sent: Thursday, April 15, 2004 4:11 PM
    Subject: Re: [noparse][[/noparse]basicstamps] BS2, BS2P Command differences
    KF4HAZ - Lonnie
    > you can modify it as you like). Once you have the file saved, follow
    > these
    > steps:
    > Locate your file, then click "Open" 5. Click "OK" to close the
    > preferences dialog
    > -- Jon Williams
    > -- Dallas Office
    Original Message
    > From: David Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YSIawW94Le8bY2-uhEgob-JeEykZwHYV0hLd0M4uMu8TLaiA4DsChpQWZ7e9afZd17QTRBzbXE6DA74Jvj2Xb7Ltvg]dersonquilter2@y...[/url
    > Dave
    > pane) shows all the instructions and which processors they work with.
    > instructions that work on the BS2 and the BS2p -- but there may be a
    > difference in required parameters (due to processor execution speed).
    > One of the most frequent requirements for a parameter change is for
    > SEROUT and SERIN. Since the new compiler lets us add conditional
    > compilation structures, I have this fragment built into my template:
    > #SELECT $STAMP
    > T1200 CON 813
    > T2400 CON 396
    > T4800 CON 188
    > T9600 CON 84
    > T19K2 CON 32
    > T38K4 CON 6
    > #CASE BS2SX, BS2P
    > T1200 CON 2063
    > T2400 CON 1021
    > T4800 CON 500
    > T9600 CON 240
    > T19K2 CON 110
    > T38K4 CON 45
    > #ENDSELECT
    > Inverted CON $4000
    > Open CON $8000
    > Baud CON T9600
    > -- Jon Williams
    > -- Dallas Office
    Yahoo! Groups Links
    abuse@p....
    edited 2004-04-16 16:11
    It would be great if we could expand upon this (maybe as a group
    project) and include constants or variables to account for the
    differences with:
    COUNT
    DTMFOUT
    FREQOUT
    PULSOUT
    PWM
    RCTIME
    Kenny
    edited 2004-04-16 20:46
    I have just uploaded a ZIP of examples that cover the instructions you
    list below, as well as a couple you didn't. All programs use
    conditional compilation so that the program perfoms the same on any
    BS2-family BASIC Stamp.
    -- Jon Williams
    -- Dallas Office
    Original Message
    From: Kenny [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lDvkBZrBz1NRKkVp4kXhPdrPuxUbP3BEpkR5_IWNyESMBu5L2TBaHVG7WG073U-NttOYzt55bNAKhQ]gapdev@y...[/url
    Sent: Friday, April 16, 2004 10:12 AM
    Subject: [noparse][[/noparse]basicstamps] Re: BS2, BS2P Command differences
    differences with:
    COUNT
    DTMFOUT
    FREQOUT
    PULSOUT
    PWM
    RCTIME
    Kenny
    >> the instructions you list
    Thanks Jon, that is perfect!
    Kenny
