FlexProp: a complete programming system for P2 (and P1) - Page 22 — Parallax Forums
1192022242562
  • JRoarkJRoark Posts: 1,215
    edited 2021-08-15 19:26
    @ersmith
    Issue #1: There seems to be some mischief compiling without optimization in FlexBASIC 5-9-1-Beta. This code:
    FUNCTION BCDToDec(BCD as ulong) as ulong
    '   BCD to Decimal
    '   Converts a BCD number into decimal
        dim tmp as ulong
        dim i as long
        tmp = 0
        i = 7
        do
            tmp = tmp + ((BCD AND &HF000_0000) >> 28) * (10 ^ i)
            BCD = BCD << 4
            i -= 1
        loop until i = -1
        return tmp
    END FUNCTION
    produces these errors from the first line after the DO statement:
    D:/Flex2Gui/flexgui/P2 Libs/CommonLibP2.p2asm:183: error: Unknown symbol __system____builtin_powf
    D:/Flex2Gui/flexgui/P2 Libs/CommonLibP2.p2asm:187: error: Unknown symbol __system___float_mul
    D:/Flex2Gui/flexgui/P2 Libs/CommonLibP2.p2asm:191: error: Unknown symbol __system___float_add
    Similar errors get thrown in other functions when dividing:
    D:/Flex2Gui/flexgui/P2 Libs/CommonLibP2.p2asm:692: error: Unknown symbol __system___float_div
    This behavior seems to be of recent origin and only occurs with optimization turned off. Any other level of optimization compiles fine.
    Issue #2: Comparisons of 64-bit numbers gets wonky in DO/LOOPs if left-most argument is a function call returning 64-bits.
    This code works fine: (Note: the function GetCnt64() just returns the 64-bit system counter as a ulongint. Works fine)
    SUB PauseMS64(count as ulongint)
    ' Pauses until COUNT milliseconds has elapsed then returns to caller
        dim bailOutCnt as ulongint
        bailOutCnt = GetCnt64() + (count * (CLKFREQ / 1_000))
        do
            'do nothing
        loop until bailOutCnt <= GetCnt64()
    END SUB
    This code below differs by one line and throws the error: Bad number of parameters in call to _int64_cmpu: expected 4 found 3
        do
            'do nothing
        loop until GetCnt64() > bailOutCount   ‘ <~~~ reversed argument position
    END SUB
    The only difference between these two is the order of the vars/func for the comparison test in the LOOP closure.
  • @JRoark said:
    @ersmith Is there any way in FlexBASIC to define a string constant that does not contain "typeable" characters? What I'm looking for is a constant for a CR (or LF, or a BS, etc), but this doesn't work:
    CONST cr = chr$(13)
    CONST cr$ = 13
    In the first case, the compiler doesn't know about CHR$() as it relates to making a constant, and in the other it just assigns the value of 13. If the text was "typeable", then it would be easy:
    CONST greeting = "How ya doin?"
    I'm confuzzified.
    No, unfortunately there is no way to insert non-printable characters in a literal string, and a BASIC CONST string can only be a literal.
    What are you trying to accomplish? Could you use a VAR or a DIM SHARED instead?
    I got myself wrapped-up in thinking the "clean" way of doing it would be to use CONST for consistency, but as you suggested I finally settled on using a DIM SHARED at the module level. Works a treat.
  • There's a new release of FlexProp, version 5.9.2, available on Patreon (it's been there for a while now actually!) and now on github. This version is a kind of preview of the 6.0.0 release, which is still some way away. There are some notable new features, including:
    • P1 ROM bytecode support exposed in the GUI now (the compiler has supported it for a little while, thanks to @Wuerfel_21 's contribution). The P1 ROM bytecode works very well for Spin1, and fairly well for Spin2 on P1, C, and BASIC. Due to the nature of the interpreter there are a few features missing, notably inline assembly support.
    • Support for BRK debugging on P2 (allowing debug of PASM code); this was also contributed by @Wuerfel_21 , she's been very busy!
    • A new kind of bytecode for P2 (not the same as the "official" P2 bytecode). Called "nu" code, this has an interpreter that's custom built for each application. The Nu compiler and interpreter are still under active development, and should not be used in production code yet -- the final version will be smaller and faster than what's there now.
    • A smaller and simpler runtime library is used for many cases (e.g. simple serial prints). This is detected automatically, no command line options are required.
    • Automatic locking of access to the serial port for PRINT and printf, so C and BASIC programs running on multiple COGs will (generally) work better.
    • BASIC improvments: multiple items in CASE, and _SameTypes() and _HasMethod() builtins for doing generic programming.
    • Many bug fixes.
  • Also, there's a major change to the Mac OS GUI: it's now built as a complete binary application (similar to the Windows one) and comes with Tcl/Tk 8.6, instead of relying on the system one. This fixes a number of annoying bugs in the (obsolete) Tcl/Tk distributed with MacOS, but probably introduces new bugs :).
    edited 2021-09-18 14:19
    @ersmith I just now installed the latest Windows version of Flex 5.9.2 obtained from the Patreon page. After compiling I get a TCL error. "APPLICATION ERROR: Version conflict for package "TCL" Have 8..."
    Here is the logfile it generated:
    version conflict for package "Tcl": have 8.6.11, need 8.7-
        while executing
    "package require Tcl 8.7-"
        (file "D:/Flex2Gui/flexgui/tcl_library/tcl9.0/msgcat/msgcat.tcl" line 15)
        invoked from within
    "source D:/Flex2Gui/flexgui/tcl_library/tcl9.0/msgcat/msgcat.tcl"
        ("package ifneeded msgcat 1.7.0" script)
        invoked from within
    "package require msgcat 1.6"
        ("uplevel" body line 2)
        invoked from within
    "uplevel \#0 {
        if { $::tcl_platform(platform) eq {windows} } {
        if { [catch { package require registry 1.1 }] } {
        (file "D:/Flex2Gui/flexgui/tcl_library/tcl8.6/clock.tcl" line 21)
        invoked from within
    "source -encoding utf-8 [file join $TclLibDir clock.tcl]"
        (procedure "::tcl::clock::format" line 3)
        invoked from within
    "clock format $now -format %c"
        (procedure "doCompile" line 20)
        invoked from within
    "doCompile"
        invoked from within
    ".toolbar.compile invoke "
        invoked from within
    ".toolbar.compile instate !disabled { .toolbar.compile invoke } "
        invoked from within
    ".toolbar.compile instate pressed { .toolbar.compile state !pressed; .toolbar.compile instate !disabled { .toolbar.compile invoke } } "
        (command bound to event)
    This error does not seem to hinder the compiler from working. It seems to get thrown when the compiler has already finished and control is being returned to TCL.
  • @JRoark : I think you've somehow mixed up two installations of FlexProp. The new one (flexprop 5.9.2) doesn't even have a tcl9.0 subdirectory inside tcl_library. I'd suggest re-installing; if you can't start fresh, then rename (at least) the "src", "bin", and "tcl_library" directories to something else before unpacking 5.9.2 over them.
    Roger that! I havent done a fresh install-from-scratch in about two years, so its probably way past time. Thanks for the help.
  • bigtreemanbigtreeman Posts: 32
    edited 2021-09-23 00:33
    Hi, I'm using github compiled Flexprop v5.9.2
    I have found the flexprop clock initialisation
    seems to only use mmmmmmmmmm pll multiplier
    and not dddddd xtal divider
    I've written a one liner bit of test code to get it accurate to the 1Mhz
    using both the ddd divider and mmm multiplier
    changing the clkfreq
    CON
    _xtlfreq = 25_000_000
    _clkfreq = 120_000_000 -> 250_000_000
    ' rdmode ( -- m )
    rdmode rdlong x,#@clkmode
    jmp #pushx
    120 Mhz -> rdmode .bin --- %000000010000000000000011_11111000 * 4 = 100
    130 Mhz -> rdmode .bin --- %000000010000000000000100_11111000 * 5 = 125
    140 Mhz -> rdmode .bin --- %000000010000000000000100_11111000 * 5 = 125
    150 Mhz -> rdmode .bin --- %000000010000000000000101_11111000 * 6 = 150
    160 Mhz -> rdmode .bin --- %000000010000000000000101_11111000 * 6 = 150
    170 Mhz -> rdmode .bin --- %000000010000000000000101_11111000 * 6 = 150
    180 Mhz -> rdmode .bin --- %000000010000000000000110_11111000 * 7 = 175
    190 Mhz -> rdmode .bin --- %000000010000000000000110_11111000 * 7 = 175
    200 Mhz -> rdmode .bin --- %000000010000000000000111_11111000 * 8 = 200
    210 Mhz -> rdmode .bin --- %000000010000000000000111_11111000 * 8 = 200
    220 Mhz -> rdmode .bin --- %000000010000000000000111_11111000 * 8 = 200
    230 Mhz -> rdmode .bin --- %000000010000000000001000_11111000 * 9 = 225
    240 Mhz -> rdmode .bin --- %000000010000000000001000_11111000 * 9 = 225
    250 Mhz -> rdmode .bin --- %000000010000000000001001_11111000 * 10 = 250
    I don't think this is correct. I'm using the algorithm that Chip gave in the forums, and it uses both the pll multiplier and xtal divider. I don't have a 25 MHz system to test with, but you can see the generated values in the .p2asm file. They're given as comments near the beginning of the file, e.g.:
    con
        _xtlfreq = 25000000
        _clkfreq = 120000000
    dat
        nop
        cogid   pa
        coginit pa,##$404
        orgh    $10
        long    0   'reserved
        long    0 ' clock frequency: will default to 120000000
        long    0 ' clock mode: will default to $11017fb
    What I get for some of the values you tried are:
    120 MHz -> clkmode = $11017fb
    130 MHz -> clkmode = $11019fb
    140 MHz -> clkmode = $1101bfb
    150 MHz -> clkmode = $10005fb
    160 MHz -> clkmode = $1101ffb
    Were you using TAQOZ to print the clock modes? Perhaps the forth runtime changes something in the calculated values?
    Oh, for that matter it may not be using the calculated values at all -- my test program was in Spin2, but TAQOZ is pure assembly, so it won't (generally) have the clock set for it automatically. How are you getting flexspin's calculated clock frequencies into the TAQOZ code?
  • Just found the nasty bit of stuff which mucks up the clock,
    it's getting the flick
    I'm sorry, I don't understand this comment... did you miss posting some of the text, perhaps?
  • I've posted FlexProp version 5.9.3 binaries on the usual sites (github and Patreon). This version supports the new Spin2 floating point operators, and a few miscellaneous bug fixes.
    the Taqoz compile time changes things,
    I've read so much code lately to find how the P2 works,
  • AribaAriba Posts: 2,697
    Eric
    There seems to be something wrong with the floating point implementation.
    I get always one of these errors:
    error: applying round to a non float expression
    error: Cannot handle expression yet
    The following minimal Spin2 code produces both errors:
    CON
      _clkfreq  = 160_000_000
    PUB go(): i,f
      f := 1.0e+6
      i := round(f /. 10.0)
    Andy
  • pik33pik33 Posts: 2,417
    I experimented with this code and it is round() not compiling as expected.
    i:=round (10.2) compiles
    i:=round(j) doesn't compile and causes these 2 error comments
    i:= f/. 10.0 compiles
  • Yes, round() seems to be broken. I'll get a fix in soon, but for now you can work around this by adding -Dround=_float_round on the command line. You may get some warnings about round being redefined in some header files, but you can ignore those.
    It's not only round(), also trunc() and float() don't like expressions inside parentheses.
    Andy
  • round(), trunc() and float() are all fixed in github (source code) now. The workaround for older flexspin versions is to always use the all-caps versions (ROUND, TRUNC, FLOAT) and to add the following defines to the command line:
    -DFLOAT=_float_fromint -DROUND=_float_round -DTRUNC=_float_trunc
    Thank you, Eric
    I will try that workaround.
  • __deets____deets__ Posts: 216
    edited 2021-10-14 10:17
    I try to register a timer ISR because I don't want to waste a full COG on letting a few LEDs blink. This works if I run the PASM2 method into an endless loop. But the moment I remove that & return, the ISR is not executed anymore.
    con
       SD_STATUS_PIN = 25
       SYSTEM_STATUS_PIN = 24
    pub main()
      setup_timer()
      repeat
        pinhigh(SD_STATUS_PIN)
        waitms(100)
        pinlow(SD_STATUS_PIN)
        waitms(100)
    pri setup_timer()
            org
            drvl     #SYSTEM_STATUS_PIN
            mov      ijmp1, #int1
            getct    t1
            addct1   t1, period
            setint1  #1
    .loop   jmp #.loop ' comment this out
            ret
    int1    addct1   t1, period
        drvnot   #SYSTEM_STATUS_PIN
        reti1
    period  long    clkfreq_/10
    t1      long    0
            end
    Any pointers?
  • Addct1 sets only a single value for the timer. Only a single event is generated when the system clock counter reaches that value. You have to update the timer in your int1 ISR by executing another addct1.
    BTW, you can blink LEDs without any cog resources by setting the pin to PWM smart pin mode. By using large values for the base period you can set PWM frequencies in the second range.
  • @ManAtWork I do update the timer, it does work when the main “thread” loops endlessly.
    Thanks for the PWM hint, I’d obviously prefer that. I did in fact try that based off an example but the period was too small. I only managed 200us or so. Do you have an example?
    edited 2021-10-14 14:15
    @deets said:
      repeat
        waitms(100)
        waitms(100)
    I suspect that a repeat construct without any further parameters, and followed by an indented-code-section will get assembled as an infinite Pasm2-REP-loop, and can't be interrupted in any way.
    There resides the problem; if you substitute the endless-repeat construct by a jmp/loop-one, it'll work, as expected.
    Hope it helps
    Henrique
  • ManAtWorkManAtWork Posts: 2,331
    edited 2021-10-14 13:54
    Oh, I see. I've overlooked that because the indentication gets messed up when quoting code. Then it must have something to do with the spin interpreter's implementation of waitms(). It probably also uses addct1. That's the danger of mixing spin and assembler in the same cog.
      wrpin #P_PWM_SAWTOOTH+P_OE,#led_pin
      wxpin ##5000<<16+(clkfreq/10000),#led_pin
      wypin ##2500,#led_pin
    sets the base period to 100µs and the frame period to 5000 which should mean 500ms total cycle time. 2500 is half of the frame period and means 50% duty cycle.
    PS: BTW, wrong thread/off topic. If you like to discuss more smart pin related stuff please start a new thread.
  • The Parallax Propeller 2 documentation states that one of the conditions for an interrupt to be processed is that REP can’t be active.
    So, I think @Yanomani has probably identified the problem. If you can examine the executable code for a REP instruction you should be able to confirm.
  • Flexspin's generated code isn't supposed(tm) to be interrupt-safe. So, ye, it may take arbitrary time for an interrupt to actually fire. Though adding an option to disable REP optimization is probably easy and would solve the biggest issue.
    Also, you really really really really really really don't want to define your interrupt handler in inline ASM, it WILL get overwritten with whatever gets loaded into FCACHE next.
  • @ManAtWork : Unfortunately as @Wuerfel_21 says Flexspin's generated code is not interrupt-safe, and using interrupts in the same COG as compiled code is not supported.
  • I appreciate the insights. I read somewhere that spin is IRQ friendly - I guess that’s PNut then. Is there a way to safely store PASM and state somewhere? Or should I just declare spin state & it will be accessible?
  • @deets
    have a look to Chip's sample ... he is reading the ADC with PASM in the spin program, in the background, using interrupts IIRC.
    I can't remember exactly where the sample is, perhaps also included in the pnut archive.
