Problem loading F32.hex
Mike Green
in Forth
I use CoolTerm for a terminal program for Tachyon at 115300 Baud. I have the distribution archive for Tachyon P1 v5v7. The kernel loads fine using PropLoader. CoolTerm loads EXTEND.FTH with no errors, then loads TV.hex and UART.hex. F32.hex does not load and I don't understand why. "SAVEROM" echos to the screen, then the hex dataloads with one or more lines of hex data (":hhhhxxxxxxx") filling the display lines. After the last line of hex data, things just sort of stop. With TV.hex or UART.hex, each input hex line appears on a separate screen line and the module is saved at the end (and appears in the "lsroms" list. F32.hex does not appear in the list. Any suggestions?
The best way to diagnose your problem would be to reproduce the effect you are observing.
What P1 hardware (board) do you use ?
Are you sure that what you are trying to load fits the board resources (EEPROM) ?
Did you maintain exactly the order of the file loading you described above ?
I'm away from my P1 board today so maybe I could check what's going on tomorrow but I can't promise that for sure.
I've tried this with both a QuickStart board and an Activity Board WX using the USB serial port. Both have the same amount of EEPROM. I used PropLoader to load the kernel and CoolTerm to load EXTEND.FTH, then TV.hex and UART.hex all of which worked. Finally, F32.hex failed.
Check if F32.hex has windows line end.
If not, save it with the windows line end.
I do not remember now which I had problems with,
but by saving with windows line end, it worked.
That was it frida. It had been saved with Linux (LF) line endings. Changing to Windows (CRLF) line endings fixed the problem. Thanks.
