unload_prop.exe: Propeller EEPROM dump to PC .eeprom file.
I probably should have started with a new thread from the get-go, but this program was developed in answer to another thread, so I posted it there:
····http://forums.parallax.com/showthread.php?p=843565
I used unload_prop successfully before - thanks Phil.
Now I wanted to back up a running image from a PPDB,
didn't realize the file size 0 and wiped it ... :-(((
Luckily I had another board.
Here I get:
The prop is booting and running fine from EEPROM ...
PPDB is original. Crystal says T or I 5.000
Anything I can do?
thanks
What changes would be required to get this to run under a debian style linux?
