LCD Graphics/Text Driver for cheap SPI LCD's with optional Touch screen support
Cluso99
                    4.0" TFT SPI 480x320 LCD ST7796 -Spin2 and PASM Driver & Demo
Touch and non-touch versions
Previously "4.0in TFT SPI 480x320 LCD ST7796 Driver and TCS2046 touchscreen support"
P2 Quick Byte
https://parallax.com/320x240-lcd-driver-for-ili9341-controller-and-xpt2046-touch-screen/
Update 10-Mar-2021 v3.01 Now supports many SPI LCD boards of various resolutions and optional Touch Panel code from Mike Roberts, and includes changes by Greg LaPolla for 3.2 in 320x240 ILIp341 SPI LCD
Routines for
Supports these LCDs and similar
Update 31-Jan-2021 v207-TS (actually v208): @mwroberts added TCS2064 touchscreen support
V2.0: First release - Software Driver and demo
v204: Uses the new DRVx instructions rather than the older OUTA/DIRA.
v205: Better demo (still has circle bug)
v206: On RetroBlade2 P42-47
v207: Circle bug fixed
It’s based on my 1.44” ILI9163 LCD Driver (hence v2.0)
https://forums.parallax.com/discussion/comment/1509348/#Comment_1509348
and my P1 version
https://forums.parallax.com/discussion/159911/color-lcd-driver-for-cheap-1-44-spi-128-128-v1-1-red-and-black-pcbs/p1
Specs:
* P2 PASM COG (CPU) supporting...
o clear screen
o set foreground and background colors
o set window (x,y start and end)
o fill window
o set column and row (x,y start)
o draw characters in 6*8 and 8*8 fonts (both fonts loaded into the pasm cog)
o also supports low level LCD calls to directly manipulate the LCD
* P2 SPIN2 COG (CPU) supporting...
o supports above pasm calls plus
o draw strings (6*8 and 8*8 fonts)
o draw line (x,y start and end with color)
o draw circle (x,y center, diameter, color)
o fill rectangle (x,y start and end, color)
o draw round clock face and hour/minute/second hands - includes sample program to redraw hands each second
Note: I am still using the old DIRA/OUTA methods to drive the LCD, so currently it's limited to the P0-31 I/O pins. Fixed in v204
Uses I/O (later versions use P47-42)
Enjoy
Driven by my RetroBlade2 on pins P42-47
P2 Quick Byte
Routines for
- Draws Text with both 6x8 and 8x8 fonts
 - Draws Lines
 - Draws Circles
 - Draws Rectangles
 - Draws filled boxes
 - Draws an analog clock face
- 4.0 in 480x320 ST7796S SPI LCD with/without Touch
 - 3.2 in 320x240 ILI9341 SPI LCD with/without Touch
 - 1.44 in 128x128 ILI9163 SPI LCD (no Touch)
- 3.5 in 480x320 ILI9488 SPI LCD with/without Touch (one on order)
 - 2.8 in 320x240 ILI9341 SPI LCD with/without Touch
 - 2.4 in 320x240 ILI9341 SPI LCD with/without Touch
 - 2.2 in 320x240 ILI9163 SPI LCD (no Touch)
 - 1.3 in 240x240 ST7789 SPI LCD (no Touch) (one on order)
and my P1 version
Specs:
o clear screen
o fill window
' LCD Connector: ' PIN_VCC ' 3v3 ~59mA or 5V ~113mA power supplied by power supply ' PIN_GND ' GND pwr supplied by power supply PIN_CE = 0 ' Serial clock enable pin PIN_RST = 1 ' Reset pin (can be reset by software) PIN_DC = 2 ' Data / Command selection pin PIN_SDA = 3 ' Serial Data MOSI pin PIN_CLK = 4 ' Serial Clock pin PIN_LED = 5 ' LED backlight enable pin (hi to enable - ~2.4mA) PIN_SDO = 6 ' Serial Data MISO pin (not used)
Enjoy
Powered from 5V = 113mA
Powered from 3V3 = 59mA (vreg not bypassed on LCD board) - DO NOT power (or GND) from a P2 pin! (This works for the 1.44" LCD)
LED 2.4mA @ 3V3 so can be safely connected to P2 pin
You may have noticed i need to rotate 90 degrees and invert. The screen pixel size doesn’t seem to be working as it should either. But this was a 5 minute job and I didn’t really expect to be able to use the ILI driver so easily. I will try and make it as parameterised as possible.
Next is to convert some lcd commands to use 16bit parameters for row and column addressing etc (was 8bit for the smaller LCD).
How fast with the SPI bus run? Will it do QPI too?
Are you planning on using P2 ADC to do the touchscreen?
I'd like to see how well that works...
My clock happily ticks by every second, but it’s small an in the corner.
The touch has an onboard chip and IIRC which converts to SPI. it’s capacitive touch and also came with plastic pen.
My current code requires a change in my pixel counter mailbox from 16bit to 32bit. I’ve already changed the x and y start and end addresses from 8bit to 16bit (the old code was for 128*128/160 pixel screens). I’ve been doing the changes as I get time. My demos work, drawing 6*8 and 8*8 characters (yes both supported concurrently and both fonts inbuilt), drawing lines, boxes with fill, circles, and my clock face. When filling boxes (and clearing the screen) your code gives two x,y addresses and the code needs to calculate and pass (to the pasm driver cog) the number of pixels in that box and this needs to be >16 bits that I allowed. This is used in the clear screen routine too.
There is bug in drawing the circles which I suspect is to do with the maths overflowing as the x or y position cannot be greater than ~160-170 so I'm posting it while I think about the problem some more.
This is my code
PRI drawCircle(xc, yc, dia, rgb) | i, x, y, d ' Draw Circle d^2 = x^2 + y^2; y = SQRT(d^2 - x^2) (Pythagoras theorum) repeat i from 0 to dia-1 x := i y := SQRT((dia*dia) - (x*x)) 'plot incrementing x axis drawPixel(x+xc, y+yc, rgb) drawPixel(xc-x, y+yc, rgb) drawPixel(x+xc, yc-y, rgb) drawPixel(xc-x, yc-y, rgb) 'plot incrementing y axis drawPixel(y+yc, x+xc, rgb) drawPixel(yc-y, x+xc, rgb) drawPixel(y+yc, yc-x, rgb) drawPixel(yc-y, yc-x, rgb)20 lines are 80 chars of 6*8 font followed by 20 lines of 60 chars 8*8 font
I cant find any link on post 1 for the code for this display.
Have just received mine.
I see you say your ILI9361 code worked so I can try mine as is, but I would like to compare.
Dave
Can you see all the ZIP files at the bottom of the first post? You may need to refresh. I notice sometimes they disappear.
Gosh! You're right!
Why does that happen?
Nice clean elegant code- makes mine look positively grubby.
Thanks Cluso99
I went about it a different way- not so much room on the prop1.
Like the way you implemented the mailbox.
And the 5X7 font is handy.
On the 2 inch display I used the prop1's built in font table- much bigger- easier to see.
Dave
Thanks for you kind words.
I need the small font to get 80 chars wide. An 8*12 font might be better and there’s room as LUT is not used.
I have been looking at scrolling but it seems I can only achieve horizontal because I’ve flipped the display to 480x320 w-h. Will have to ultimately do it in code. Project for another day.
Hi @Cluso99
I added a driver for the 2046 touchscreen chip into your st7796 driver and added a demo into your st7796 demo.
I used the same pins you used.
It seems to work pretty good, I'm curious to see what you think...
@mwroberts
Thanks so much for doing this! Looks great :)
I will update the title!
Here is an update just for text 8x8 font with 60 characters of 40 lines with auto-scrolling
Hi
OH good you've figured out the auto scrolling. Must take a look and update my flexbasic version.
Dave
If anyone has experience with these or similar LCD controllers, I’m looking for how to use the internals to scroll.
There might be two ways. Best to use the ic scrolling feature but first looks seem to be able to only scroll when in portrait mode and I’m in landscape. Second is to read back the pixel data and rewrite to the new locations as this saves keeping an external copy. With the external copy, colour formatting gets lost.
Any help appreciated.
I have been trying to utilise the LCD chip to perform the scrolling. Seems it might be only be able to do vertical scrolling in portrait mode
I'm running in landscape mode (a simple 1-bit config change) but alas the v scroll now shifts horizontally.
If anyone has seen code to drive the scrolling without doing it manually outside the chip then please let me know.
I have just posted a text only version where the LCD Driver is decoupled from the formatting object. It also uses a serial port as well.
P2 Serial and LCD (60x40 text) Drivers using a common Formatting Object and Buffers
https://forums.parallax.com/discussion/172881/p2-serial-and-lcd-60x40-text-drivers-using-a-common-formatting-object-and-buffers/p1
Caveats:
Latest code posted on this theread
https://forums.parallax.com/discussion/172924/multiport-serial-lcd-text-drivers-with-common-format-i-o-object-similar-to-jm-fullduplexserial/p1?new=1
I need to get time to test it and put it into my latest LCD driver
V3.01 code now posted in the first post and in P2 Quick Bytes
Now supports many cheap SPI LCDs from 1.44in 128x128 to 4.0in 480x320. Larger ones should also be possible. Optional Touch support has been added.
Thanks to Mike Roberts and Greg LaPolla for their contributions.
