PNut/Spin2 Latest Version (v53 - Added OFFSETOF, fixed other NEXT/QUIT {level} bug) - Page 31 — Parallax Forums
1282931333477
    msrobots wrote: »
    DOC instead of DEBUG and some switch to just compile that?
    Interesting.
    Yes, and I am going to simplify the syntax used by these displays.
    I will post an animation soon that I made.
    edited 2020-09-08 04:09
    You really need to make a single program (or even dll) combining the debug screens with PST.
    Then Pnut, PropTool and others could use all of it. And the serial port sharing could work like it does with PST now.
    Maybe support two serial ports, one for Terminal and one for Debug, but basically if combined the PST is just another screen?
    Another thought I have is that the SEND thing needs a corresponding RECEIVE.
    Enjoy!
    msrobots wrote: »
    Enjoy!
    I've thought about a RECV counterpart to SEND, but I've had a hard time figuring it, because you cannot control WHEN anything comes, so it seems like it would be hard to make it not block execution.
    edited 2020-09-08 05:52
    I made a little program that illustrates the hub RAM interface to the cogs. This was done using the PLOT display.
    Here is a video of it running. This demonstrates what is hard to explain, even with a picture:
    Here is the program:
    _clkfreq = 10_000_000
    PUB go() | i, j, k
      debug("`plot myplot size 600 650 update", dly(300))
      debug("`myplot offset 300 300 polar -128 -32 linecolor $FFFFFF textsize 16 textstyle 1")
      k~
      repeat
        debug("`myplot clear")
        debug("`myplot text 300 0 30 3 $FFFF7F 'The Eggbeater Interface'")
        if k & 16
          j++
        repeat i from 0 to 7	'draw spokes if RAMs are still
          debug(ifnot(k & 16), "`myplot linesize 12 100 ", sdec_(i*16), " to 200 ", sdec_(i*16), " linesize 3")
        debug("`myplot fillcolor $003F7F ovalfill 0 0 200 200")
        debug("`myplot text 24 0 11 '16K x 32' text 0 0 'Hub RAMs' text 24 64 11 '(address LSBs)'")
        repeat i from 0 to 7	'draw RAMs and cogs
          debug("`myplot fillcolor $007F7F ovalfill 100 ", sdec_(i*16-j), " 50 50 text '", i | "0", "'")
          debug("`myplot fillcolor $7F0000 ovalfill 200 ", sdec_(-i*16), " 80 80 text 'Cog", sdec_(i), "'")
        k++
        debug("`myplot update")
        waitms(20)
    Polar coordinates made this really easy.
    Evanh, do you know if I have the cogs ordered properly in that animation?
    After I get this voice chorus thing done, I will improve the DEBUG syntax for the graphical displays, so that the backtick (`) character keys a string that doesn't need quotes and subsequently keys number printing and expressions, so that this:
    ...will be able to be typed like this...
    debug(`myplot fillcolor $007F7F ovalfill 100 `sdec(i*16-j) 50 50 text '`(i | "0")')
    It's a little too complex the way it currently is.
  • evanhevanh Posts: 17,163
    Huh, what? Scurries through the webpage source for a URL ... downloads vid ... views with VLC ... :)
    Oh, I've generally assumed that incremental cog numbers see incremental slot numbers - with rollover. So, yeah, I would've drawn the cog order opposite to that.
    edited 2020-09-08 22:42
    evanh wrote: »
    Only one way is correct. I will look through the Verilog to figure it out. I need to get my head around it again.
  • @cgracey, I'm not sure what I'm doing wrong, but I tried running your Eggbeater code and this is what I get (see screen print attachment) and P62 is blinking.
    2047 x 1369 - 173K
  • I think what you've drawn is technically correct, because cog 0 can indeed access momory 0, then 1, etc. However, I would have drawn the rotating memory to go clockwise, because theres something mentally jarring about counterclockwise movement (is this thing going to unscrew and fall off?)
    If you're going clockwise with the rotor, I think it makes sense to go clockwise with the cogs too, maybe cog 1 should be near '1 o'clock' and go clockwise from there. This isn't as big a deal though
    If you make the above two changes I think the LSB memory numbers end up going counterclockwise
    CJMJ wrote: »
    Sorry. I need to get you the latest PNut.exe. I'll have it here soon...
    Tubular wrote: »
    Ha, good point. I'll change it. I still need to find out if I've got it right, otherwise. Getting into that Verilog code is like committing to do something physically difficult.
  • The problem seems to be the "debug("`myplot clear") " call in the endless repeat loop. The windows become nonresponsive.
  • If I comment out everything inside the repeat loop, the windows can be closed normally.
  • Just to be clear. In my test, I commented out everything inside the repeat EXCEPT the clear call and that's when the windows became nonresponsive.
  • I'm not sure if you need to get into the verilog. You know from experience you can read address xx0 then address xx1, from a single cog perspective (eg cog 1), so the diagram just has to match that
  • Ok. This works fine (see attachment). It's something inside the commented block that's cause the problem. I wonder if it's just me?
    1554 x 900 - 78K
    CJMJ wrote: »
    I know, but you are using an old version of PNut.exe that doesn't run these latest examples. I will post it here shortly.
  • Duh! My bad! Maybe you should post a disclaimer "Don't try this at home!" laughing on the inside. Your examples were so cool, I wanted to play with them. In the words of Marvin, "Now, I'm so depressed."
    Here is an interim version v34yy which has the latest DEBUG stuff in it:
    https://drive.google.com/file/d/1eZibHAHx_S67KOr4UFtRSD2wFH_c_2TI/view?usp=sharing
  • Crikey! Windows Defender wants to delete PNut again! Rev"yy" still works until I reboot.
  • JonnyMacJonnyMac Posts: 9,787
    edited 2020-09-09 18:57
    Rename it YYZ -- maybe WD will think it's Canadian and therefore "nice." :)
  • LOL
    edited 2020-09-10 03:06
    @JonnyMac
    JonnyMac is right on :) LOL
    edited 2020-09-10 04:51
    The latest, v34z, is posted at the top of this thread. Lots of new DEBUG display stuff.
    This .zip includes the pitchbending chorus demonstrated today on the early-adopter meeting.
    edited 2020-09-10 06:59
    Just tried the debug windows in WIne on Linux Mint 20, and it works!
    Great stuff!
    It was great seeing the pitch blending stuff.
  • @"Peter Jakacki" OT, that wallpaper in the background - is it a picture from your window of your home town view ?
  • @"Peter Jakacki" are you saying that WINE works for PNut P2 downloads with USB serial and everything nicely under Linux? Are you using Loadp2 or the loader in PNut itself?
    Perhaps we might have hope for the official PropTool to work with this method as well?
    I also wonder if the Mac can have similar luck... has anyone got that going yet? I might have to try it out too. This could avoid a lot of the VM overheads and a real Windows install which can be handy if anything to just avoid all the MS auto-update nonsense.
  • rogloh wrote: »
    WINE is 100% borked on MacOS because the idiots at Apple removed 32bit compatibility in 10.15. You can obviously install Linux in a VM or with bootcamp and run WINE on that, which is still probably preferable to doing the same with Windows.
  • Maciek wrote: »
    Close, it reminds me a bit of some of the view around here except for one salient feature.... :)
    @rogloh - yep, WIne is much improved these days, I can run just about anything. I have USBx mapped as COMx using "ln -s /dev/ttyUSBx COMx" etc. I'm just using PNut as is, no external loaders.
    6729 x 3637 - 4M
