Propeller Platform board?
                                  in Propeller 1
                    Is the Propeller Platform board still available somewhere?
Or Martin's DNA board?
I found a Propeller Platform article in the March 2012 issue of Nuts & Volts.
"The Spin Zone
Adventures in Propeller Programming
CAN We Talk? "
Is this the board/project in question?
I have a copy of the files if you can't find/get them...
From May of 2009, files can be downloaded on that page, but not the full article.
The PCB design is in ExpressPCB format so to move to other CAD programs, you would need to place an order from PCBExpress and then request a gerber package, which is now done for free after you place an order. See the question about converting to gerber:
https://www.expresspcb.com/faqs/
That they are. But the magazine wants the viewer to be a subscriber to view the full article and decide for themselves.
Mascot asleep!
Thank you, Martin.
I sent an email to the address listed in the Wiki, but haven't heard back form that.
I'll take the last one, if I may.
Richard
PS: New email sent
With board Real Time Clock, and Micro SD card.
I thought it would be the industry standard by now.
So what is the current latest greatest Propeller board now?
DNA Wiki page:
1mgh.com/wiki/Dna
Rays page:
rayslogic.com/Propeller/Products/PPE/PPE.htm
Propeller Platform by Jonnymac
Propeller Platform SD by Gadget Gangster (very few made it to the wild)
Propeller Platform SD+RTC by Gadget Gangster
Propeller Platform USB by Gadget Gangster (was the standard for a while and also sold through Mouser and Adafruit)
NEW Propeller Platform USB by Martin Hodge which became
Propeller Platform DNA and Propeller Platform DNA w/RTC by Martin Hodge
and a bit of a fork:
Propeller Platform Express by Rayman
But the question was - what is available today?
@Martin?
Got your email.
Check in the mail
I tend to think like yeti, the less on the board that you did not put there the better. eventually it will get in the way. My first board was the GG USB, but running long wires to a breadboard got a bit flaky at times. Then just jammed a prop into the 3 row Jameco breadboard that the wires were running to and the GG did not get much use from there. Just use the layout in the prop ed manual. Wire carefully and as short a wire as possible. Be sure to wire VSS/VDD on BOTH sides of the prop and place the bypass caps (220 or 470uF 10V) on the power bus and .1uF on each side of the prop as close to the chip as you can. You will have all the room in the world to wire up your ideas. Lately, I have been using a PPDB to test smaller parts of a project, since the schematic seems to show the only hard connections are the eeprom and the USB plug. Otherwise it seems to be a bareboard that you can hook up the on board extras as needed. But then the sections will end up relocated to the big board when the project takes up more than the PPDB has room for.
Anything since?
Should come straight through now.
