SMD Crystal Oscillator for Hand Soldering...
cbmeeks
in Propeller 1
I'm working on a design that will use a SMD Prop and, naturally, I want a SMD crystal oscillator too.
I can easily hand solder the LQFP Prop but I'm not sure what oscillator to get.
I found this one on Mouser because it seems to have small "notches" near the pads that I presume I could put an iron to in order to reach the pads underneath.
https://www.mouser.com/ProductDetail/Ecliptek/EC2600TS-5000M-TR?qs=sGAEpiMZZMt8zWNA7msRCuuLuz0BJnoljNA9np1S7NJeG/UBOTGZcQ==
I don't really want to deal with reflow ovens or hotplates at the moment so hand soldering only. Perhaps I could make the pads on the board larger, pre-tin then, then hold the oscillator down while heating up the pad. But this seems like a hack.
What do you guys suggest?
Thanks!
Thanks!
It is no hack, KiCad has hand solder SMD footprints that have larger pads.
7x5 is quite large these days, and you could look at SOT23-5 oscillators too.
Do you have a particular recommendation? I'm not looking for microscopic. But it would look silly if the oscillator was twice as big as the Prop. lol
Just design your board for SMD, hand solder-paste it if you have to but stencils are so cheap these days. I turn my oven on max with both top and bottom elements and after it's warmed up I placed the pcb on the middle tray for 4 minutes. BTW, the oven timer I leave jammed on and just have a digital kitchen timer beep me after 4 minutes (or use your phone). Use some folded foil as a "plate" for the pcb when placing and removing it. This also helps it to cool faster.
Much like many wood workers enjoy using hand tools for everything.
Here is an early P2D2 test pcb in the oven, before P2 chips were available, and the result. Not hard at all.
Not to mention my current work area doesn't have the room for yet one more piece of equipment.
What's wrong with designing it the way *I* want it to be? Instead of designing it the way you think it should be? I'm not missing out on anything. This is a hobby for me. Not my profession.
Goodness gracious...I'm just asking for crystal oscillator suggestions...
Goodness gracious indeed.
Takes up a lot of space, but works well.
Easily soldered by hand.
@Rayman
Thanks for the suggestion. I actually like that one better than the one I found earlier. Even if it is ginormous compared to the Prop. lol
But if I did start, I'll certainly do some research before I buy.
Many of the things I build/design (like my Potpourri6502 computer) are geared towards hand soldering because I find it fun.
I can solder some pretty small components by hand using only my normal eyeglasses. As you can see in the two pics, they are quite small. I think they are 2012 IIRC. I soldered many of those by hand sometime ago.
If I had a lot of those, then yeah...I would consider an oven. But until I do that, I just don't see the need.
2512 are giant, but good for high power or voltage...
Don't tin both pads before placing the device, though, as it will not sit level. And don't use too much heat or time on the second pad, else you'll melt the joint on the first pad. If your joints look globbed instead of filleted, use solder wick — either pre-tinned or with a little flux — to clean them up. Neatness counts!
But, Phil's instructions work for that size too...
0805 is a comfortable size, I think.
I do larger boards too but I find that the foil helps avoid hotspots and I even place a foil baking dish over the boards to even it out too. But do you have any particular convection ovens in mind? I mainly work with 0603 parts now although I have reels of 0805s that I hardly use anymore, they look HUGE compared to 0603 which are actually quite easy to work with.
I like your idea of using foil to even out the heat, although I typically like to watch the solder melt and the joints fuse, in case I have to turn off the oven before time-out.
You could look at the Osc used on FLiP ?
There was a thread on that, and a part code for better RFI, a while back...
Addit: I find this comment...
“SIT8918BEL13-33E-5.000000G 3.3V ±50ppm -40°C ~ 105°C 4.7mA 2.50mm x 2.00mm $0.96288/1000
Hehe, look, it is the lower slew variant, & the same part code Tracy Allen confirmed with FLiP+GPS
- which make sense to be a default for a 5MHz Osc”
Addit: and if you want better stability, Mouser stock the slightly larger
ECS-3225S33-050-EN-TR Miniature Crystal Oscillator HCMOS Tight Stability 3.3V 5MHz ±15ppm -40 to 85°C 3.2x2.5x0.9mm SMD T/R
You can design a PCB that can accept 2520 and 3225 cases.
My method was to use a dab of ZephPaste on each pad which will hold the part in place and a very gentle bit of hot air from an old re-purposed Radio Shack solder removal tool for heat and an aquarium pump for the air source. Replaced some 0603 H smd fuses this way. Also, mounted some SMD only parts on TI and AdaFruit PCBs for use on breadboards. Cost about $30 or so vs spending $$$$$ for a fully kitted out Zephtronics rework station.
That's pretty much how I do it. I recently recapped my Amiga 600 (many SMD parts) and was quite proud that my fillets looked like curved ramps going up to the pin. All hand soldered. No magnification other than eyeglasses.
Now, will I be able to do that in a few more years? Probably not. lol
