MG90S Servo.. Ain't No Stoppin' Us Now
I just got four metal gear 9 gram MG90S servos from a US seller. They work OK, but there is no mechanical stop. You can just rotate them endlessly by hand. Never seen that before. I thought the internal mechanical potentiometer would get torn up if it went beyond maybe 270.
Ever seen that, or do I have the only four ever made?
That is all.
Could it be that the potentiometer resistive element is a full 360 degrees with the input voltage connections 180 degrees apart? That would allow the wiper to rotate continuously but would make it harder to determine the position of the wiper since both halves of the potentiometer would traverse the same voltage range.
The other explanations that come to mind are multi turn potentiometer, optical/hall encoder, or the potentiometer gear slipping when it reaches the stop. Be interesting to take one apart to find an explanation.
Whenever I get 2 minutes!
2 minutes for @erco
Enjoy!
Photo of potentiometer in LX-16A servo
