Tachyon V4 "DAWN" - exploring new worlds
1202123252630
  • MJBMJB Posts: 1,139
    edited 2017-08-07 - 13:42:04
    just wanted to have a current IoT5500 setup and loaded latest Tachyon + EXTEND
    here is the output with the strange message on top.
    loaded with TeraTerm 921600 + 20 ms line delay
    EDIT !! - different line delays give different errors
    EDIT 2 - at 50ms line delay for paste it takes for ever - but no errors
     Propeller .:.:--TACHYON--:.:. Forth V4.5 DAWN 450170727.1400 Cold start - no user code - setting defaults
     Setting up dictionary
    0000.01F0:   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................ ??? in LOCATE$ at DROPYTHEN
    ..    ok seed  not found
       End of source code, 0001  errors found  Load time = 0 cycles at 96MHz = 0.000us
    Code bytes used = 7488
    CODE:$3880 = 13952 bytes
    NAME:$5928 = 6872 bytes
    DATA:$770C = 252 bytes
    FREE:      = 8360 bytes
     Data Stack (0)
     ok
    ..  errors W@ 0= IF SAVEROMS THEN
                        COPY ROMS from $3DC4 for 3,200
     ok
    ..  0 U@ DROP  ok
     .  FORGET SAVEROMS
    ..  errors W@ 0= IF AUTORUN BOOT THEN
    ..  I2C400 ?BACKUP BACKUP  ok
    ..  REBOOT
    *** MODULES ***
    1B40: EXTEND.fth          Primary extensions to TACHYON V4.5 kernel  - 1708030-1000
    AUTORUN BOOT
    FREQ = 96.0MHz
    *** INITS ***
    Loading cog 3 E50A F32
    *** ROMS ***
    E01C: VGA32x15    848
    E37C: HSUART      392
    E514: F32        1900
    F29C: MONO16      196
    F370: F32        1900
    *** I2C ***
    $A0 EEPROM
    I/O =  31:UHU~ 27:U~~~ 23:~~~U 19:~~U~ 15:D~~~ 11:~~~~ 7:~~~~ 3:~~UU
    INTERCOM: &00.00.00.00 @2,000,000
    CODE:$37EE = 13806 bytes
    NAME:$5934 = 6860 bytes
    FREE:      = 8518 bytes
     Data Stack (0)
    2001/01/01 MON 00:00:00
    ..  WORDS
     DICTIONARY WORDS @5934
     BOOT DEFER !DEFER ?DEFER defstk ,WORD$ FSQRT FSIN F/ F* F- F+ F> >F FCMD fnumB fnumA result f32cmd LOADCOG FINDROM NEXTROM lsroms .rom romsz roms OK KEY: EVAL$ tib tibwr ID! ?? .FREQ .AUTO .INTERCOM INTERCOM! PPBAUD! .TIMERS .TASKS .INDEX .VARS ~V WWORDS ~W .MODULES ~M +NFA CTYPE PRINT$ MLEN$ NFA>BFA MU@ MW@ MC@ MC@++ EE? .ES lsi2c ~I ~R lsio ~p !POLLS +POLL ?POLL polls TIMER.TASK TIMERJOB _job !RTC CountDown .TEMP 'F 'C STAMP@ .DT .ASMONTH .DATE .DTF .TIME .DAY DAY DAY@ SUN SAT FRI THU WED TUE MON DATE! SDT! DT! TIME! DATE@ TIME@ DEC>BCD BCD>DEC RTC RTC@ RTC! WRRTC RDRTC <RTC> <RTC NORTC RTCEE MCP79410 =rtc DS3231 @rtc rtcbuf! rtcbuf@ rtcbuf @day @date @time runtime WATCHDOG wdt TIMEOUT? ALARM COUNTUP +TIMER TIMEOUT ttint tid timers TIMER AUTORUN EE BACKUP ?BACKUP CONBAUD ECOPY EFILL ELOAD ESAVE ep I2CPINS EEPROM ESAVEB E! E@ EW@ EW! EC@ EC! ENDRD EERD @EEWAIT @EE eeadr I2C400 I2C100 ~D I2CFAST FI2C@ nakI2C@ I2C@ ackI2C@ I2C! I2C!? I2CSTOP I2CSTART I2C> <I2C> <I2C ?I2C i2cflg RECLAIM LEDS LED ansi LEDPIN brg DHT DHT? DHTBYTE DHTBIT htsav rh htref htck DISTANCE PING MODPINS SETPINS SPIPINS MASK? @SPISCK @SCL @CNT @CE @MISO @MOSI @SCK *SDA *SCL BLINK MUTE HZ KHZ MHZ HZCON FRQ DAC! BPIN APIN PLLDIV PLL DUTY DIFF CTR! CTRMODE NCO CTR@ ~C CTR B A _ctr SERIN ISERIAL ~S SERIAL ~S ISEROUT SEROUT TXSER SERBAUD baudcnt +VECTOR ~v REVECTOR (FORGET) FORGET STRIP (STRIP) lsini ?INITS INIT -INIT +INIT ~I inits .HEAD$ ?ANSI MARGINS BOLD REVERSE ATR PLAIN CURSOR ERLINE ERSCN CLS XY .PAR CUR PAPER COL PEN ESCB HOME ESC AEMIT _ansi white cyan magenta blue yellow green red black PRINT& ~1 .EMIT U.R .DEC PRINTDEC .DECX D. .DP PRINTNUM (.NUM) (SEP) RADIX> >RADIX RADIX radix COGINIT TASKREGS RUN TASK? RND LONGFILL 3++ 3@ 3! @3 2++ 2@ 2! @2 1++ 1@ 1! @1 C~~ W~~ ~~ C-- C++ W-- W++ -- ++ W>L B>L B>W W>B L>W >W RELEASE LOCAL X4 X3 X2 X1 @X @x4 @x3 @x2 locals AVG OUT PIN! ELAPSED? =CNT CNT@ P! P@ VSCL VCFG PHSB PHSA FRQB FRQA CTRB CTRA DIRB DIRA OUTB OUTA INB INA CNT PAR SPR STRING TABLE VAR LEFT$ RIGHT$ MID$ +CHAR APPEND$ $= COMPARE$ LOCATE$ $! COPY$ NULL$ boot CON] CON [CON ~c NULLOUT MB KB R@ INVERT DROP; MOD 2OVER 3DUP 2SWAP @. => <= DS DS+ clong cword cbyte A> >A A@ astk FALSE 0-1 TRUE .. WAITHI WAITLO s |< ] =[ LONGS BYTES LONG WORD BYTE ORG BREAK CASE SWITCH@ SWITCH QUIET NUM>STR NUM$ NUMBER LIMIT >| WW! U@ U! ulong ANYCASE PUBLIC PRIVATE UNSMUDGE IMMEDIATE @HATR CLKMHZ CLKFREQ EXTEND.fth NOP DUP 2DUP OVER DROP 2DROP SWAP ROT -ROT NIP 3DROP ?DUP 3RD 4TH >R R> !RP !SP AND ANDN OR XOR ROL ROR SHR >> 8>> SHL << 8<< 2/ 2* 4* SAR SPLIT9 REV MASK >N >B 0= NOT 1+ 1- + - 2+ 4+ 2- MIN MAX * UM* U/ U/MOD / UM/MOD64 UM/MOD32 */ UM*/ ABS ?NEGATE NEGATE FROM BY ADO FOR NEXT LOOP +LOOP I J LEAVE FOR@ FOR! BY! LP! IF ELSE THEN ENDIF BEGIN UNTIL AGAIN WHILE REPEAT IC! IC@ C@ W@ @ C+! C! C@++ W+! W! +! ! C~ W~ ~ BIT? SET? SET CLR BIT! CMOVE ERASE FILL <CMOVE RESET 0EXIT EXIT ?EXIT CALL JUMP (WAITPNE) RUNMOD (WAITPEQ) (EMIT) (EMITX) LOADMOD COG@ COG! COGSTOP pCOGINIT COGID REBOOT CLK CLKSET DELTA WAITCNT LAP .LAP LAP@ CLOCK CLKIN CLKOUT H L P T F SHROUT SHRINP OUTSET OUTCLR OUTPUTS INPUTS HIGH LOW FLOAT PIN@ IN SPIWRB SPIWR16 SPIWR SPIRD SPICE 0<> <> WITHIN U> = > < U< 0< HEX DECIMAL BINARY READBUF KEY WKEY (KEY) KEY! doKEY EMIT CLS SPACE SPACES EMITS BELL CR <CR> TAB TABS XTAB SPINNER .HEX .BYTE .WORD .LONG @PAD HOLD >CHAR #> <# # #S <D> PRINT$ CTYPE LEN$ U. .DP PRINT . ZPRINT CREATE CREATE$ GETWORD SEARCH FINDSTR NFA>BFA CFA>NFA NFA>NFA @NAMES names WORDS UNSMUDGE ALLOT ALLOCATED HERE , || | [W] [B] W, EXECUTE VER .VER TACHYON END CONSOLE ECHO us ms seconds second DISCARD TASK REG BUFFERS COLD RAM DUMP: DUMPX DUMP DUMPW DUMPL DUMPC DUMPA DUMPAW QD DEPTH .S DEBUG .STATS IDLE NOOP --- \ '' ( { } IFDEF IFNDEF " (") ." PRINT" (.") == org @org byte word long bytes words longs ALIGNORG ALIGN : pre pub pri ; RETURN [C] ' ['] NFA' OFF ON 0-1 ALIAS GRAB [WS2812] [SDRDF] [SDRD] [SDWR] [SDIO] [SSD!] [PWM32] [PWM32!] [PLOT] [ROL3] [CAP] [WAV] [MCP32] [RCTIME] dmm errors uhere uthere flags prompt uauto keypoll lastkey rxpars rx id keytable @WORD uemit ukey base num uswitch undef V4 *end*
     ok
  • @mjb - try giving TeraTerm 2 stop bits although it shouldn't really need it. The line delay can be dropped down as low as 6ms which is the delay I use. Maybe I will have to see what's happening with it.
    I loaded up quite a few modules and it still fits. Now if I perform an extra COMPACT operation to move the latest dictionary names from hub to EEPROM then that will give me over 4k free even after all this baggage. The 1-wire includes the ROM scan operations from MJB which allows multiple 1W devices to share the same wire.
    5E12: EASYNET.fth         WIZNET NETWORK SERVERS 170708.0000
    55A4: W5500.fth           WIZNET W5500 driver 170708.0000
    5226: 1WIRE+.fth          1-wire interface + support & diagnostics 150520:0000 PBJ,MJB
    5032: WAVEPLAY.fth        Tachyon Wave file player - 170523-0000
    4A5E: VGA.fth             VGA text driver 170726-0000
    37F6: EASYFILE.fth        SDHC card + FAT32 Virtual Memory Access File System Layer V1.2 170807-1600
    AUTORUN
    FREQ = 96.0MHz
    *** INITS ***
    INIT#0 3D70
    INIT#1 5010 !VGA
    INIT#2 6216 EASYNET
    *** ROMS ***
    E01C: VGA32x15    848
    E37C: HSUART      392
    E514: F32        1900
    *** I2C ***
    $A0 EEPROM
    $A2 EEPROM
    I/O =  31:UHUU 27:U~~U 23:D~~D 19:~~~~ 15:U~~U 11:~~~~ 7:UDUD 3:U~U~
    CODE:$626C = 24684 bytes
    NAME:$631C = 4324 bytes
    DATA:$7DE2 = 2002 bytes
    FREE:      = 176 bytes
    P2 --- The LOT --- TAQOZ INTRO & LINKS --- P2 SHORTFORM DATASHEET --- TAQOZ RELOADED - 64kB binary with room to spare
    P1 --- Latest Tachyon with EASYFILE --- Tachyon Forth News Blog --- More
    paypal.png PayPal me
    Brisbane, Australia
    edited 2017-08-07 - 14:35:48
    loading in EASYFILE at 50ms gives
    HMS is not in WORDS list, so not defined
    in the source it is there ...
    trying at 115200 now ... and 100ms line delay
    EDIT ... still fighting ...
    EDIT2
    no success
    give up for now ... :-((
      ??? in FCLOSE at sector E )   Propeller .:.:--TACHYON--:.:. Forth V4.5 DAWN 450170727.1400 ok
    ..    ok
       End of source code, 0001  errors found  Load time = 626260736 cycles at 96MHz = 6.523sec
    Code bytes used = 4280
    CODE:$48AE = 18094 bytes
    NAME:$5096 = 9066 bytes
    DATA:$7AD2 = 1218 bytes
    FREE:      = 2024 bytes
     Data Stack (0)
     ok
    ..  ' MOUNT +INIT  ok
    ..  ?BACKUP BACKUP  ok
    ..  SD1656 SDPINS  ok
    strange that ?BACKUP seems to backup even with listed errors ... ???
  • Peter JakackiPeter Jakacki Posts: 8,850
    edited 2017-08-07 - 14:39:51
    @mjb - I just tried TeraTerm with 10ms line delay and 2 stop bits at 921600 and it loaded EASYFILE fine. I will check it further.
    BTW - if you are powering your board from the same serial USB port then there shouldn't be any problems but beware ground currents which seem to upset the poor FTDI chips.
    961 x 356 - 31K
    Brisbane, Australia
  • AleAle Posts: 2,358
    #11 Arduino (is that a language?)
    no, it is not.
    It is a framework.
  • Ale wrote: »
    no, it is not.
    It is a framework.
    Yes, I was rather bemused by the fact that both the readers and the magazine treated it as a "language" :)
    Brisbane, Australia
    I have the IoT5500 on a breadboard with breadbord regulator and PropPlug-clone running from one single USB port.
    I was wondering if the Wiz5500 might draw too much power?
    When I put the NW cable in somtimes I get reboots.
    So I had it umplugged for the SW buildt.
    edited 2017-08-07 - 18:09:10
    I have EASYFILE
    pub EASYFILE.fth PRINT" SDHC card + FAT32 Virtual Memory Access File System Layer V1.2 170807-1600 " ;
    loaded
    --- Close the current file
    pub FCLOSE
    	--- flush and clear sector (-1)
    	FLUSH sector ~~
    	--- clear file pointer
    	_file @FILE ~
    	--- blank out file name
    	NULL$ FILE$ $!
    	--- wipe dir entry
    	dirbuf 32 ERASE
    shouldn't this be
    FLUSH @sector ~~
    bit difficult to revers engineer with all the
    SECTOR
    @sector
    @sectors
    but I think I get it now.
    AND it seems to work with the change
     Data Stack (0)
    Mounted 504B.6474-3035.6234          NO NAME     FAT32   15,927MB (32,768/cluster)
    ..  ls
    NO NAME
    COMPACT .FTH   EXTEND~1.FTH   FRED    .TXT   LIFE    .FTH   SEE     .FTH
    ..  QV SEE:FTH
    ..  QV SEE.FTH
    0000.0000:  TACHYON V4..FORGET SEE.fth.: SEE.fth.PRINT" Tachyon+ decompiler
    0000.0040:  " ;..@org W@ 2 ALIGN org.word indent.8 words ifs..pri +IF..ifs B
    0000.0080:  EGIN DUP W@ WHILE 2+ REPEAT..W! indent C++..;..pri -IF..ifs BEGI
    0000.00C0:  N DUP W@ 3RD <> WHILE 2+ REPEAT..W~ DROP indent C--..;..pri ?IF.
    ok - next step
    I obviously need to COMPACT
    this is in seperate file now.
    After loading and running the listing shows the modules printed twice
    *** MODULES ***
    AUTORUN BOOT
    FREQ = 96.0MHz
    *** INITS ***
    INIT#0 3D70 MOUNT
    *** ROMS ***
    E01C: VGA32x15    848
    E37C: HSUART      392
    E514: F32        1900
    F29C: MONO16      196
    F370: F32        1900
    *** I2C ***
    $A0 EEPROM
    I/O =  31:UHU~ 27:U~~U 23:~~~U 19:~~U~ 15:D~~~ 11:~~~~ 7:~~~~ 3:~~UU
    CODE:$48B0 = 18096 bytes
    FREE:      = 2022 bytes
     Data Stack (0)
    ..  COMPACT ???
    ..   ACHYON V4 ( V4.5 )   Propeller .:.:--TACHYON--:.:. Forth V4.5 DAWN 450170727.1400
       End of source code, 0000  errors found  Load time = 434263920 cycles at 4294MHz = 0.000sec
    Code bytes used = 422
    CODE:$4A56 = 18518 bytes
    NAME:$5006 = 9210 bytes
    DATA:$7AF4 = 1252 bytes
    FREE:      = 1456 bytes
     Data Stack (0)
    ..  pub TACHYON TACHYON ~H ;
    ..  pub END              END ~H ;
    73F2 *end*
    *** MODULES ***
    AUTORUN BOOT
    FREQ = 96.0MHz
    *** INITS ***
    INIT#0 3D70 MOUNT
    *** ROMS ***
    E01C: VGA32x15    848
    E37C: HSUART      392
    E514: F32        1900
    F29C: MONO16      196
    F370: F32        1900
    *** I2C ***
    $A0 EEPROM
    FREE:      = 2022 bytes
     Data Stack (0)
    so now EASYNET ...
    edited 2017-08-07 - 20:21:59
    @D.P. - do you have a current running IoT5500 image?
    I need a stable base before I go into changing EASYNET again ...
    complicated enough
    after
    COMPACT
    BACKUP
    : +FTP ; --- used CREATE +FTP before but not sure it worked
    I paste in EASYNET.FTH
    ..  BACKUP BACKUP |
    ..  FL EASYNET.FTH
    ..  OFF ANYCASE
    ..  ( Please define +FTP to IFDEF compile FTP and HTTP servers )
    ..   ??? in ?TELNET at FILEIN eller .:.:--TACHYON--:.:. Forth V4.5 DAWN 450170727.1400
    ..   ??? in ?EASYNET at ocket
       End of source code, 0002  errors found  Load time = 130166544 cycles at 4294MHz = 0.000sec
    Code bytes used = 3244
    CODE:$570A = 21770 bytes
    NAME:$6878 = 2952 bytes
    DATA:$7B92 = 1410 bytes
    FREE:      = 4462 bytes
     Data Stack (0)
    ..  ' EASYNET +INIT
    ..  ?BACKUP BACKUP /
    again, 2 errors listed but still ?BACKUP performed ??
    after reboot
    *** MODULES ***
    52CA: EASYNET.fth         WIZNET NETWORK SERVERS 170708.0000
    4A5E: W5500.fth           WIZNET W5500 driver 170708.0000
    AUTORUN ÿ
    FREQ = 96.0MHz
    *** INITS ***
    INIT#0 3D70
    INIT#1 56B4 EASYNET
    *** ROMS ***
    E01C: VGA32x15    848
    E37C: HSUART      392
    E514: F32        1900
    F29C: MONO16      196
    F370: F32        1900
    *** I2C ***
    $A0 EEPROM
    FREE:      = 4462 bytes
     Data Stack (0)
    *** Tachyon Forth EASYNET Network Servers and EASYFILE File Server ***
     ... ready!
    NETWORK STATUS:
    LINK DOWN
    HARDWARE: WIZnet W5500 V4
    SRC IP    192.168.000.099
    MASK      255.255.255.000
    GATEWAY   192.168.000.001
    MAC       02.FF.35.F2.33.B4.
    SKT HH:MM:SS MODE  PORT  DEST TXRD TXWR RXRD RXWR RXSZ  IR STATUS            IP ADDR
    #3  00:00:52 TCP  10001           .    .    .    .    . 00 14 LISTEN
    * WEB, FTP, and TELNET servers running *
    now set my NW config ...
    but still wondering about the 2 errors and the ?BACKUP performed anyhow ???
    my NW config set -- OK
    but when plug the NW cable into the router - not touching the IoT setup,
    then the terminal freezes
    the propplug blinks when I press keys
    the yellow LED is on
    the green LED blinks short some times
    I have the breadboard powered via active USB hub - should be enough ...
    *** MODULES ***
    AUTORUN ÿ
    FREQ = 96.0MHz
    *** INITS ***
    INIT#0 3D70
    INIT#1 56B4 EASYNET
    *** ROMS ***
    E01C: VGA32x15    848
    E37C: HSUART      392
    E514: F32        1900
    F29C: MONO16      196
    F370: F32        1900
    *** I2C ***
    $A0 EEPROM
    FREE:      = 4462 bytes
     Data Stack (0)
     ... ready!
    NETWORK STATUS:
    LINK DOWN
    SRC IP    192.168.001.111
    GATEWAY   192.168.001.001
    ..  ipconfig ???
    ..  ifconfig
    NETWORK STATUS:
    LINK DOWN
    #3  00:01:55 TCP  10001           .    .    .    .    . 00 14 LISTEN
  • Hi there eager people - currently not using bleeding edge tachyon. This is working for me as there was some trouble with line delays on linux with minicom 115200 8n1:
    /usr/local/bin/bstc.linux -b "tachyon.binary" "./tachyon.spin.utf-8" -Ox -DDEF96MHz -DBAUD115200
    /usr/local/bin/bstl.linux -d /dev/ttyUSB0 -p 2 "./tachyon.binary"
    gnome-terminal -e "minicom tachyon -b 115200 -D /dev/ttyUSB0 --color=on"
    ascii-xfr -s -l 10  EXTEND.FTH > /dev/ttyUSB0
    ascii-xfr -s -l 10  EASYFILE.FTH > /dev/ttyUSB0
    ascii-xfr -s -l 50  COMPACT.FTH > /dev/ttyUSB0
    echo "COMPACT" > /dev/ttyUSB0
    echo "OFF ANYCASE" > /dev/ttyUSB0
    echo "BACKUP" > /dev/ttyUSB0
    ascii-xfr -s -l 50  EASYNET.FTH > /dev/ttyUSB0
    ascii-xfr -s -l 50  myEXT.FTH > /dev/ttyUSB0
    echo "&192.168.1.124 SIP" > /dev/ttyUSB0
    echo "&192.168.1.1 GATEWAY" > /dev/ttyUSB0
    echo "RESET" > /dev/ttyUSB0
    Hope it helps, regards
    proplem
    I Am One With the Forth and the Forth Is With Me
  • @MJB,
    I will try to build a stable 5500 on a IOT RSN. Will update.
    D.P wrote: »
    @MJB,
    @Peter_Jakacki
    as soon as I plug the NW cable in - the terminal hangs
    when I unplugged again after a while it seemes to react again ... strange ...
    last 2 times it did a reboot after I unplugged the remote end of the NW cable again ...
    so does not look like a loose cable at the breadboard.
  • In the current build files I get this error in easynet.fth after doing the following on a IOT5500 module (P8) mounted on a PPDB using a wall wort supply
    1. Load the spin file at 115200
    2. Load extend using TeraTerm 8N1 50ms line delay
    3. Load easyfile.fth
    4. Load compact.fth
    5. Run COMPACT and backup
    6. Load easynet.fth
    Here is the easynet error, I did comment the FL easynet.fth at the top and also each time I tried to define +FTP I had problems. The system ping but no FTP, Telnet or HTTP
    ..  OFF ANYCASE  ok
    ..   ??? in ?TELNET at FILEIN eller .:.:--TACHYON--:.:. Forth V4.5 DAWN 450170727.1400 ok
       End of source code, 0001  errors found  Load time = 379386112 cycles at 96MHz = 3.951sec
    Code bytes used = 3270
    CODE:$5724 = 21796 bytes
    FREE:      = 4436 bytes
     Data Stack (0)
     ok
    ..  ' EASYNET +INIT  ok
    edited 2017-08-08 - 12:30:38
    Re loading errors - I've done a little investigation and found that TeraTerm seems to run too efficiently at 921600 baud, which is normally a good thing except that the characters it sends are back-to-back without any gaps other than the stop bits. When I try this on minicom there seems to be around 100us or more between characters but it might be the terminal emulator itself since even TeraTerm is running on top of WinXP in VirtualBox inside Linux.
    So I tried this with GtkTerm which only goes up to 115200 baud but it was back-to-back like TeraTerm so it pointed back to minicom. Again I fired up minicom at 115200 this time and there it was, the 100us or more delay between characters.
    Ok, I will look at my side of things to see if I can speed it up a bit more. I do have the FL mode which loads to a file first and then compiles source from the file but this only works once we have EXTEND and EASYFILE loaded. Maybe it might be better to drop back to 115200 baud for compatibility perhaps but I've got a feeling that this is because I paste the text and minicom is using an inefficient method for getting another character. Perhaps I might modify the minicom source and fix up a few other things while I'm at it.
    Regarding those errors with "sector" vs "@sector" and FILEIN etc I think this is because the Dropbox files that are used aren't the very latest. Is there a better way of synchronizing them perhaps?
    Brisbane, Australia
  • I fear, proplem will bite the table ;-)
    no reason to reason if you feel feelings: in love with the propeller
    How-2-TACHYON
    BritishAccentAlwaysFascinating
  • I prefer 115200 and repeated flawless compilations, I can wait. V3 is very stable in this regard.
    @Peter_Jakacki
    in EXTEND I found those 'interresting' code sections
    pub 2OVER 4TH 4TH ;
    I would have expected
    pub 2OVER ( a b -- a b a b ) OVER OVER ;
    and
    IFNDEF R@
    pub R@						R> R> DUP >R SWAP JUMP
    this is a 'trick' leaving the ';' out at the end ??
    because JUMP goes somewhere else anyhow and no EXIT needs to be compiled?
  • @MJB - The 2OVER is an OVER for a double so n1 n2 n3 n4 --> n1 n2 n3 n4 n1 n2 where n1 n2 is a double.
    A Tachyon Forth definition doesn't need a ; to "unsmudge" since the creation of the next word also does an "unsmudge" automatically.
    Brisbane, Australia
    edited 2017-08-10 - 16:16:15
    might be good to add a comment then
    pub 2OVER ( n1 n2 n3 n4 --> n1 n2 n3 n4 n1 n2 )	4TH 4TH ; --- OVER for DOUBLE handling
    --- like  DOUBLE stack ops:
    2DROP
    2DUP
    2SWAP
    in this case then you leave it out to save the compilation of the additional EXIT because there is the JUMP anyhow - right?
    we would not want to leave all the ; out since it would overflow to the next definition even if "unsmudge"d automatically.
  • @MJB - all those 2 words were traditionally "double operators" but since all data is untyped in Forth a 2DROP is used to drop 2 singles or 2DUP used to dup the top 2 singles etc. 2OVER however could never be just OVER OVER as that is essentially a 2DUP operation so 2OVER is only for doubles. The same goes for 2SWAP.
    With regard to leaving out the ; perhaps I should have stated that ; has two purposes normally: that of appending an EXIT to the routine and also of unsmudging and validating the name. In Tachyon Forth we allow one definition to fall through into the next if desired so the unsmudging is also done by CREATE used in : and pub/pri/pre etc. In the case of the code in question I could have put a ; after the jump but it is already redundant. The same holds true of endless BEGIN AGAIN loops, they don't really need a ; at the end either.
    Brisbane, Australia
  • I downloaded Tachyon V4.5 earlier today, compiled it using PropellerIDE on a Linux PC, then downloaded the result to two different Propeller Boards (Activity Board WX and Propeller Keyfob). Using the terminal in PropellerIDE at 115200 Baud, I get garbage on a reset. Similarly on a Mac with CoolTerm, I can't get either board to produce proper output. The source indicates the console is on the usual pins at 115200 Baud. Suggestions?
  • D.PD.P Posts: 790
    edited 2017-08-11 - 05:58:27
    Make sure this section in the spin file matches your clock source and baud
    CON { *** CLOCK MODES *** }
    '{ 5/10MHZ CRYSTAL
    _clkmode        = xtal1 + pll8x
    _xinfreq        = 10_000_000            ' <--- AUTOMATIC 5 or 10MHz operation change at boot
    sysfreq         = 80_000_000
    { 6MHZ CRYSTAL
    _clkmode        = xtal1 + pll16x
    _xinfreq        = 6_000_000
    sysfreq         = 96_000_000
    baud            = 115200                ' <-- user change - tested from 300 baud to 3M baud
    'baud            = 921600
  • Both boards have 5MHz xtals and the section you listed in the spin file is unchanged (automatic 5MHz/10MHz and 115200 Baud)
  • Mike,
    The 5Mhz section is commented out.
    Uncomment that section and comment the 6Mhz section.
  • That was it! I looked there over and over again and missed it every time. Ooof! Thanks
  • Mike GreenMike Green Posts: 22,925
    edited 2017-08-11 - 23:23:28
    Interesting. On the Activity Board, I can load EXTEND.FTH, EASYFILE.FTH, and COMPACT.FTH. With the keyfob, I can load EXTEND.FTH then the following repeats indefinitely
    Propeller .:.:--TACHYON--:.:. Forth V4.5 DAWN 450170727.1400.[5n
    *** MODULES ***
    AUTORUN BOOT
    FREQ = 80.0MHz
    *** INITS ***
    *** ROMS ***
    E01C: VGA32x15 848
    E37C: HSUART 392
    E514: F32 1900
    F298: MONO16 196
    *** I2C ***
    $3A unknown
    $A0 EEPROM
    I/O = 31:UHU~ 27:DDU
    edited 2017-08-12 - 08:47:07
    Sounds like that hardware must have a pin that ends up reseting the Prop when it checks the state of the I/O pins.
    Try commenting out line 2073 in EXTEND with a \ like this:
    \	CR BOLD PRINT" I/O = " PLAIN red PEN lsio PLAIN
    Do you have a schematic for this keyfob? Maybe the offending pin is on P25 or P24 just where it killed the lsio operation.
    Brisbane, Australia
  • Hello Peter, it would bring the world forward to fix the sd-card issues. I now ordered some sandisk sd cards, but still there is some bad feeling: will it work. While I like NEON, we are hanging in the dawn ;-)
    How-2-TACHYON
