$5 Line Follower Fun - Page 2 — Parallax Forums
2»
  • And it's working!
    One transistor was installed backwards. While the bot looks like everything is mirror-imaged (the LEDs are), both transistors face the same way.
    Perfect! Glad to hear that. Another satisfied customer. :)
  • It's the first time I've assembled a kit with no instructions. Technically, there were instructions, but a blurry photocopy in Chinese doesn't work for me.
    It's amazing that these kits have been around for a long time, yet Ebay sellers and Banggood just say "no English instructions". If you surf around, you can find plenty of photos of the finished item. IMO the only tricky part is mounting the phototransistors and illuminating LEDs, since they are just hanging down and need to be almost scraping on the ground. Maintaining alignment is very important for calibration, but these are easily bent (and/or pads broken off) in a collision when they go off course. I think the kit should include a simple front bumper to hang off the front skid bolt.
  • Erco - No need to cut the trace when you've got an extra socket laying around.
    Another way to skin that cat! Did you get it working? Simple circuit mod but the pot adjustment is trickier than stock.
  • I didn't need to adjust anything, it just ran better.
    I enjoyed watching these Russian kids building their line follower kits. They're getting the jump on American kids, who are all dancing!
    edited 2017-06-20 01:32
    Just got my July SERVO print magazine, where I describe several non-programming robots including these $5 line followers in the Ask Mr. Roboto column:
    http://servo.texterity.com/servo/201707/?folio=8&pg=8#pg8
    The article looks good IMO, editor Robin does a great job on the layout and is super easy to work with. Once again, I encourage everyone here to submit an article for print publication. SERVO is a robot magazine, and the only game in town now that ROBOT magazine is gone. Hopefully it will survive and thrive for a while, but there are no guarantees. So right now. WRITE NOW!
    Several forumistas have written for SERVO: Carol Hazlett, Bill Henning, Geo Leeman, Chris Savage, to name a few. It's a nice way to "give back" and get paid to help fund your future projects. Just get in the habit of taking photos and documenting your projects along the way. So much easier than taking your bot apart afterwards to take internal detail photos and trying to remember the tricky parts.
    The editors are wide open to subject matter, most anything of general interest. Tech articles, tutorials, construction tips, combat weapons, product reviews, whatever. Check out the writer's guidelines at http://www.servomagazine.com/index.php/writers-guidelines and get crackin'! Tell 'em Mr. Roboto sent you.
    edited 2017-06-27 22:13
    Simple mods allow these $5 line followers to track towards light. Two different implementations shown.
    edited 2018-04-05 02:07
    I just had to be the first kid on the block to have this stealthy line follower jet, even though it costs $10. I'll really soup it up for max speed.
    https://www.ebay.com/itm/202273586488
    edited 2018-04-05 04:57
    Looks like it uses those nice narrow tires. Wish they sold just those (and the gearbox motor). Everyone sells the weakling motors with the fat tires, and those robots have terrible steering problems. The narrow tires are better.
    What, analog control, no MCU?
    Where ya been. Heater? LM393. Analog. Old skul.
    Bah, kids and their new fangled op-amps.
  • Aren't the 'tires' just O-rings? There are cheap O-ring kits on Ebay and other places. Of course, that doesn't help with the gearbox and motor supply issue. :)
  • ceptimus wrote: »
    O-rings mounted on a wheel. The wheel has the proper molded double-D shaft hole, for specific use with the gearmotors. These wheels are not nearly as widely available as the wide-track tires normally sold with these motors.
    The LFR kits with gearmotor modules use foam tape for assembly. Simple and quick but it just falls off after a month or so, and the sticky mess is hard to clean up and repair. I'm not normally a fan of worm gears, but these alternative kits (same price, as low as $4) work great and will last much longer if properly assembled.
    Uh... strike that, reverse it.
    Free coasting (no binding) may be efficient, but it stops these $4 worm drive LFRs from following the line! Live & learn.
    Down to $3.44 now! How low can they go???!!! Time to build a swarm of line followers!
    https://www.ebay.com/itm/Intelligent-Tracking-Smart-Car-Robot-Kits-with-TT-Motor-Wheel-Electronic/153026637942
    Mini treaded line followers, $5 for one, or $7.50 for two. https://www.ebay.com/itm/112845468455
    Act fast, ad says only 3 items and 3 hours left!
    edited 2018-06-10 04:06
    These li'l dudes arrived today and work great. They really hug the line and acquire it easily. I was about to make a video, but turns out there are plenty already. Comes with 4 watch batteries installed.
    Building & tweaking some of these cheap analog Line Following Robots for an upcoming Maker Faire. I can't believe how popular these were last time, I plan to give some away at the Faire.
    edited 2019-11-02 16:12
    Under $4 for the first time in a while. $3.29 for 4+, but that's hoardin'. :)
    Stocking stuffers for budding roboticists? "Tis the season all too soon.
    https://www.ebay.com/itm/362780819611
    Edit: I just noticed this is a new version of the chassis PCB. It uses metal brackets to hold the gearmotors, and there is a third LED in the center of the board. Hmmm...
    800 x 800 - 39K
  • ceptimusceptimus Posts: 135
    edited 2022-06-04 12:15
    I've been reverse engineering the D2-6 (the fancy one with the STC15W201S microcontroller and the Bluetooth interface). The micro runs 8051 code that can be compiled using SDCC which, unlike the Keil compiler, is licence-free. I don't have access to the original code, but once I've worked out exactly what it does, I shall reprogram it for better line-following performance. It's easy to reprogram the chip once you have a hex file: you just use the free stcgal program and a serial interface (FTDI or similar). I'll post links to my source code and resulting hex files if and when I've improved the robot's performance.
    With the standard firmware, the line following mode just does full-speed forward on both motors, and then full-speed reverse on one of them when a sensor sees the edge of the line. But the Bluetooth-steered mode uses PWM control of the motors. The PWM runs at a frequency of 427 Hz. The Bluetooth outputs serial to the micro at 9600,N,8,1 The commands are just individual bytes, with a weird encoding format as follows:
    Byte Function
    0 All stop
    1-19 Ignored
    20-31 Forward slow->fast
    32-35 Ignored
    36-47 Reverse slow->fast
    48-51 Ignored
    52-63 Spinning on the spot, to the left slow->fast
    64-67 Ignored
    68-79 Spinning on the spot, to the right slow->fast
    80-83 Ignored
    84-95 Fast forward turn to the left gentle->hard
    96-99 Ignored
    100-111 Fast forward turn to the right gentle->hard
    112-115 Ignored
    116-127 Fast reversing turn to the left gentle->hard
    128-131 Ignored
    132-143 Fast reversing turn to the right gentle->hard
    144-255 Ignored
    Line following using PWM control should be much faster than the naiive 'forward or reverse' mode. Time will tell...
    Great sleuthing, ceptimus! I also did some work on the D2-6 a while back. Its line following abilities are actually worse than the cheap D2-1 BECAUSE it uses its H-bridge to reverse:
    I replaced the processor (vs your clever reprogramming it) and had some fun:
    Here's a demo of the stock unit:
    edited 2022-06-05 12:35
    I've decided to write my own Android app to send commands to the car in (what I think is) a more sensible format. It will still send single-byte commands. 4-bits of x-axis using the range -7 to +7, and 4-bits of y-axis in the same format. This uses 225 (15x15) patterns from the available 256, leaving 31 bytes for 'special functions'.
    When either the x-axis or y-axis is 8 (binary 1000) (which is not used for the range -7 to +7) then the other axis can hold one of 15 codes, plus there is 1 extra code where both the x and y-axis hold the special binary 1000 pattern.
    An obvious choice for one of the special codes will be to instruct the robot to perform an erco figure-8 challenge manoeuvre. :)
    I'm not sure how well the robot will be able to do a figure-8 without some encoder feedback from the wheels (or their motors); I suspect not very well. A hardware upgrade would be to add some sensors to optically detect the passing of the four holes that are present in each of the wheel drive gears. The microcontroller has only one spare input, but another I/O could be stolen by deleting one of the two LEDs at the rear of the robot, which are currently only really used to indicate 'operating mode'. The operating mode could be indicated just as well by a single flashing LED: e.g. flash-flash-flash-pause for mode 3.
