Propeller Serial Loader? — Parallax Forums
davidsaundersdavidsaunders Posts: 1,559
edited 2013-09-26 07:55 in Propeller 1
I know that there used to be a thread about this though I can not find it for searching.I am looking for the details of the serial comms for loading the Propeller. There are two reasons for this, first I would like to be able to compile my Prop projects on RISC OS on my Raspbery Pi (no problem) and load it into the Prop. Second I would like to creat a couple Prop based peripherials for the Raspberry Pi and be able to reload them (using a software controled power disconect to the prop from the RPi) on with new firmware with out reprogramming the ROM.So if any one could point me in the correct direction it would be much apreciated. I knew that I should have printed out that information while it was still fresh on the forums.
    edited 2013-09-25 09:16
    Maybe you are referring to this program by Chip Gracey?
    Propeller-Loader
    There are also threads that depend on using the Propellent dll. For example,
    PropLoader-Propeller-Firmware-Loader
  • davidsaundersdavidsaunders Posts: 1,559
    edited 2013-09-25 09:24
    Not quite. There was a much older thread about the actual signalling. This is what I am after, while I could disect Chips code I would prefer to just find the thread that gives all of the details. As I remember a couple of people used the information to create a couple of loaders that did not require any specific DynaLib.My intention is to make a link from the Raspbery Pi GPIO that produces the signal in software under RISC OS. If I could find the thread this would be easy.I do remember that the link is not exactly proper serial, it just uses the timing of serial data to implement a unique protocal for data transfer. Though I do not remember the exact details.
    edited 2013-09-25 09:32
    Here's some information:
    BOOT SEQUENCE
    PC:	set 115200-8-N-1
    	DTR low
    	wait at least 10ms
    	DTR high
    	wait 100ms (+-10% tolerance)
    	send $F9 (%0100111111 timing calibration)
    	LFSR: taps = $B2, initialy = "P"
    	send bitwise LFSR[250] ($FF/$FE)
    	send $F9[250+8] for bitwise responses ($FE/$FF)
    	receive bitwise LFSR[250] + version[8] within 50ms
    		if timeout or mismatch, done (hardware not found error)
    	send encoded command long (up to 3 bits sent per serial byte):
    		0 = shutdown
    		1 = load ram, then run
    		2 = load ram+eeprom+verify, then shutdown
    		3 = load ram+eeprom+verify, then run
    		if command 0, done (okay)
    	send encoded length long
    	send encoded data longs
    	send $F9 every 10ms for bitwise response(s):
    		if command 1-3,	receive bitwise checksum pass/fail within 10(?) seconds
    					if timeout, done (connection error)
    					if checksum fail, done (checksum error)
    		if command 1,	done (okay)
    		if command 2-3,	receive bitwise program pass/fail within 5 seconds
    					if program fail, done (program error)
    				receive bitwise verify pass/fail within 2 seconds
    					if verify fail, done (verify error)
    				done (okay)
    CHIP:	<reset>
    	wait for up to 150ms @20MHz for $F9 + bitwise LFSR[250]
    		if timeout or mismatch, EEBOOT
    	use incoming $F9 bytes to convey bitwise LFSR[250] + version[8]
    	receive encoded command[32]:
    	    if command 0, 4+: SHUTDOWN
    	    if command 1..3:
    		receive encoded length[32]
    		receive encoded data[32], dump into $0000..length<<2-1
    		fill length<<2..$7FFC with $00
    		write dbase @$0008 structure: long[dbase-4] = $FFF9FFFF, long[dbase-8] = $FFF9FFFF
    		bytewise sum $0000..$7FFF for checksum verify
    			if checksum failure, convey error on next $F9, SHUTDOWN
    			else, convey okay on next $F9
    		if command 1, LAUNCH
    	    if command 2-3:
    		program eeprom from ram
    			if eeprom timeout (10ms @20MHz), convey error on 2nd $F9, SHUTDOWN
    		verify eeprom against ram
    			if verify fail, convey error on 2nd $F9, program $0004 to $00 in eeprom, SHUTDOWN
    		if command 2, SHUTDOWN
    		if command 3, LAUNCH
    EEBOOT:		read eeprom into ram
    		LAUNCH
    LAUNCH:		if word at $0004 is not $0010, SHUTDOWN
    		setclk(byte[15] & $78)
    		wait 50ms at 20MHz
    		setclk(byte[15])
    		launch interpreter from $0004 in current cog
    SHUTDOWN:	dira=0, setclk($01)
    Note that the "encoding" mentioned involves encoding the bits into bytes or 3 bits to a byte in a self-timing fashion. The start bit of the serial channel is part of the encoding of the 1st bit. That's always low so we have either 001 or 011 for a bit cell representing a 0 or 1 respectively. If you're using one bit per byte, that's 001111111 or 011111111 including the start bit. Without the start bit, that's $FE or $FF. Packing the bits 0,1,0 into a byte gives you 001011001. Without the start bit, that's $59.
    I hope this explanation is correct ... I'm doing it from memory. Correct me if I'm wrong.
    edited 2013-09-25 09:43
    @Mike:Unfortunately with the new forums the text in a code block overflows everything after the post up until the end of the code listing, and as such is unreadable, also the forum ignores my CR so no way for me to seperate submited paragraphs :-( . Though I can not read your post, thank you anyway. Do you by chance know when they changed the forums to break this in NetSurf?? It used to look like it is suposed to, and work correctly.
    edited 2013-09-25 10:01
    davisaunders,
    I would like to create a couple Prop based peripherials for the Raspberry Pi and be able to reload them (using a software controled power disconect to the prop from the RPi) on with new firmware with out reprogramming the ROM
    That is just the way I am heading. Except using Raspbian. To that end I have been busy building propgcc and SimpleIDE for the Raspberry Pi.
    http://forums.parallax.com/showthread.php/150441-SimpIeIDE-for-Debian-%28x86%29-and-Raspbian-%28Raspberry-Pi%29
    If you fetch the source code of the Propeller GCC package in there you will find a Propeller loader written in C.
    https://code.google.com/p/propgcc/
    No idea if that code is useful in creating a RISC OS version.
    I'm curious how are you building Propeller code under RISC OS?
    edited 2013-09-25 10:04
    davidsaunders,
    ...also the forum ignores my CR so no way for me to seperate submited paragraphs :-( . Though I can not read your post, thank you anyway. Do you by chance know when they changed the forums to break this in NetSurf??
    It was some long while ago that the CRs stopped working for me in the Chrome browser. It's very annoying as I have to switch to Firefox to post here.
    edited 2013-09-25 10:07
    @Heater:
    Currently by hand one byte at a time. I am working on throughing together a simple SPIN/PASM compiler in BBC BASIC (so as to save development time), though I only work on that on spare spare time, main spare time is spent playing with other RISC OS coding, and doing real Prop stuff (coded by hand).
    edited 2013-09-25 10:28
    davidsaunders,
    You Sir, are a rock. I take my hat off. I haven't been into that much since writing 6809 assembler in hex back in the early eighties.
    There is a Propeller loader written in Python the code is here:
    https://github.com/wendlers/install-propeller-toolchain/blob/master/patches/spinloader
    I also attached it to this post.
    Can't find the original forum post for that but there is another thread discussing a Python loader here:
    http://forums.parallax.com/showthread.php/99366-Python-Downloader-modified-for-MacOS
    edited 2013-09-25 10:52
    Thank you Heater, I think I can sort it out from that bit of Python. It seems as if every one is trying to get me into Python :-) I am just glad that it is easier to folow than C, or C++, though still not as easy as ARM Assembly, PASM, or SPIN.
    edited 2013-09-25 10:57
    @Mike Green:
    Thank you for your help, I managed to copy it out successfully (dificult with overlapping text). And it is helpful information.
    edited 2013-09-25 11:05
    No way am I pushing Python.
    I like Python and Spin but that white space block delimiting still drives me nuts.
    edited 2013-09-25 13:32
    @Heater:
    Thank you for the links. After folowing them, and the links in those threads (and wasting most of the afternoon :-) ) I have been able to peice togather all of the information that I needed. No more emulating windows to load a Prop :-) .
    edited 2013-09-25 14:11
    There is also C code that Steve (jazzed) Denson wrote that is part of propeller-load that knows how to load a Propeller chip. If you'd like, I can extract that code from the propgcc repository and post it. I believe it comes with a small sample program.
    edited 2013-09-25 14:45
    @David Betz:
    I would apreciate that much. The more information the better, as I can not find the original thread and am down to examining a bunch of source.
    edited 2013-09-25 15:15
    @David Betz:
    Here it is. You can build the test program like this:
    cc -o pload -DMAIN PLoadLib.c osint_linux.c
    This is on the Mac or Linux. You can build it using mingw under Windows as well but you'll have to include osint_mingw.c instead of osint_linux.c.
    ploadlib.zip
    edited 2013-09-25 16:09
    David Betz wrote: »
    :-) . A bit more work than that on RISC OS, though thank you much.
    Also so that you know on RISC OS the "." charactor is a directory seperator, so dots in forign file systems are converted to "/" (so that PloadLib.c becomes PloadLib/c [PloadLib.c would refer to the file "c" in the relitive subdirectory PloadLib]). Thank you.
    ploadlib.zip
    Thank you much, this will help greatly.
    edited 2013-09-25 17:45
    Ugh. Why did they do that?
    edited 2013-09-25 18:00
    Well, RISC.OS comes from ACORN who invented the ARM chip. They just wanted to be different:)
    edited 2013-09-25 18:53
    Heater. wrote: »
    Is it too late to shoot them? :-)
    edited 2013-09-25 20:32
    Catalina has a loader "payload" that might help.
    Also, recently (a month or two ago) I asked about the wireless loading to hub ram. I noticed that there are multiple resets that occur in PropTool for downloading so that does not work with what I wanted.
    Chip also produced some download code for a prop to download another prop.
    What I was after is to be able to download code by putting the prop into a "special program" mode so that PropTool could download a binary without actually resetting the prop. I am interested to see what you come up with because it could be an alternative to what I am trying currently.
    edited 2013-09-26 05:22
    RISC OS does things as made sence. Remember this was from the mid 80s, there were no standards for that yet. Some OSes used "." as a seperator, some "/", some, "\" some "#", some "%", some ":" and a few others. Who is to say which is correct just because most OSes today use "/" that does not mean that is the only way.
    It will just be something simple that bit bangs the Raspberry Pi's GPIO pins to load the Propeller, and it is being written in BBC BASIC V (The real version [on RISC OS the OS it is made for]), this so that I have a good WIMP (GUI in RISC OS terms) user interface, as well as a way to send it data from another task.
    edited 2013-09-26 05:23
    To note:
    I am still waiding through the sources, attempting to make sure that I get it 100% correct.
    edited 2013-09-26 05:43
    davidsauders,
    What's this about bit banging the Pi's GPIO pins to load the propeller? There is a perfectly good UART on the Pi's GPIO header.
    That is what I have been using to download code to the Propeller with a modified version of the Propeller loader that comes with propgcc.
    The only bit banging I do is to wiggle a GPIO pin to reset the Propeller. Normally we would just use DTR or CTS, one of which is also on the GPIO header but I wanted to use a pin nearby the UART Tx and Tx and I have no idea how to drive DTR anyway:)
    edited 2013-09-26 06:13
    Heater. wrote: »
    davidsauders,
    Well I want know that I got it correct, and beings as it is not exactly a true serial signal, bitbanging just made sence.
    And that works greate for you as all of the tools are written to use the Linux DeviceFS for serial IO. I will eventually redo it in Serial, though that will be after I know that it is working correctly.
    Yes using a GPIO is simpler. you could probe the HW directly (if you drop out of Linux and go bare metel or just start using RISC OS).
    The Propeller and the RPi are a perfect match, so long as you do either Baremetel, DexOS, or RISC OS on the RPi :-) .
    edited 2013-09-26 06:30
    What is the advantage of using RISC OS over Linux on the RaspberryPi?
    edited 2013-09-26 06:41
    davidsaunders,
    The Propeller and the Pi are a perfect match. However I'm not about to give up all my Debian luxuries: ssh, bash, vim,gcc, nginx, node.js, Free Pascal etc etc. If I want to do assembler, that is what the Prop is for:)
    David Betz,
    I have never tried RISC OS, I should, but after you have seen how slowly X runs on the Pi you might like it for it's speed. I have no idea what modern apps it might have available, like browsers and such.
    edited 2013-09-26 06:44
    Heater. wrote: »
    davidsaunders,
    David Betz,
    I'm more of a command line guy. I probably wouldn't even try running X on a Pi (if I had one).
    edited 2013-09-26 06:52
    David Betz wrote: »
    Depends on your application. RISC OS is natively a single tasking system, with a cooperative multitasking layer in the WIMP that uses the MMU to swap the address space in order to run multiple tasks at the same base address. Nothing special there. The big advantages are the ability to single task where you have to, and the ability to easily get down and dirty and directly play with the Hardware with out the OS getting in the way, while you still have a good OS with a good GUI, with all of the bells and whistles of a modern OS. The only thing really lacking is a good modern web borwser, and that is an application not the OS, though NetSurf goes a long way toward correcting this (they are working on adding Java Script and HTML5 [Slow process]), and there is a 2.x version of FireFox available if you like the slow bloated stuff.
    .t.
    Also RISC OS runs much faster than Linux. Though I guess that this is to be expected as RISC OS is designed for the ARM specificly.
    Though I would guess that for those on this forum the biggest advantage is that there are many available Assemblers, and the best ARM C compiler that runs natively on the ARM, that being Norcroft C. As well as the fact that RISC OS is very well documented, and the RPi distrobution comes with all of the documents needed to understand the entire OS. And it is possible for a single person to understand the Entire OS in detail.
    Sorry for having to use code sections to create Line breaks, I do not know what was changed or when that seems to have broke the way these forums work with NetSurf.
    edited 2013-09-26 06:54
    Did I list X under my "luxuries" :)
    However SimpleIDE runs there OK.
    edited 2013-09-26 06:55
    Thanks for the explanation of RISC OS. Sounds like it might be interesting to try.
