P2 retail cost?
ke4pjw
Anyone have a ballpark idea of what the retail price of the P2 is going to be?
Terry
Terry
- numbers between 20% more than Prop 1 and under twice Prop 1 have been mentioned.
That'll be sweet!! I was expecting $25++
IIRC the P1 was $12.95 a few years ago.
So it may be wiser to ask how much a Propeller 2 Protoboard might cost in comparison to a Propeller 1 Protoboard.
This certainly won't be a DIP package device and the soldering is going to be rather fine pitched. If you do want to buy chips, you may likely want to take a look at Schmartboards for a way to get the Propeller 2 into actual use.
Personally, I am very excited that the Propeller2's add i/o will mean that a board with parallel SRAM will be quite possible, something like 16Mbytes of 55 nanosecond SRAM that operates at 1.8v. This chip is another $18 USB, but you are getting a lot of expansion potential. Of course you will want an FTDI chip on board, and likelly 8 bits of voltage level shifting to 3.3v or higher.
Will there be a ProtoBoard? I am sure there will. But it Parallax takes the same approach as they did with the Propeller 1, it will only be a DemoBoard and the chips in the first wave of sales.
Others may quickly produce all sort of boards this time as the Propeller 2 is not a complete unknown and the Propeller 1 was.
In the world of Development Boards, Parallax is very likely to produce one, but I doubt that it will be offensively expensive. The big companies seem to take that approach.
BTW, the Propeller 2 certainly doesn't mean the end of using the Propeller 1. I even suspect there are situations where the two might work well together on one board for a variety of reasons.
I think that a P1 with 64 IO pins would be a viable option for a lot of applications.
Propeller 1 is pipelined...
In any case, the Propeller 2 is just as deterministic as Propeller 1.
I would assume this problem is what brought about OOE in the Pentium Pro, with its 14 stage pipeline.
with other powerful processors like the Cortex M4's which are also in the same price range.
http://www.digikey.com/product-detail/en/MKL05Z32VFM4/MKL05Z32VFM4-ND/3831450
There are even 200 MHz multicore variants at $8 single quantity.
The current of > 830mA on the 1.8v rail rules out a lot of battery apps.
Having video capability will see its use in some novelty applications but I do not see it finding much traction in wider commercial applications.
It is rapidly becoming an ARM dominated world.
A P1 update with more RAM and IO in 64pin QFP/QFN would have been a winner, IMHO.
Just a few random thoughts.............
Cheers.
I was referring to the more powerfull versions with floating point in the largest packages.
Propeller can be whatever you need it to be with limits because some things are simply impossible to do in software.
Hi jazzed,
Interesting comment when you consider the big rave about the P1 is the ability to define hardware by using software:)
Anyway I think the point that was being raised is the price ratio to an ARM chip.
It is interesting to note that current consumption of newer ARM devices is going down along with the prices.
Cheers.
Ironic that you quote $2.00 for Cortex M4 chips, then provide a link to M0 chips for $2. Are you intentionally spreading FUD, or did you simply make a mistake?
I did a search on Digikey for ARM9 chips with 96 I/O and they start at $12.38, so from a cost and I/O perspective, the P2 is looking to be competitive. Short of the uber ARM9 chips used in cellphones, I don't think there is a comparable MICROCONTROLLER that compares to the power, cost, and accessibility.
Even the Rpi chip is good for only about 700 MIPS.
Just trying to make a fair comparison instead of coming off as some stir-crazy fanboi.
Indeed, as ARM's go higher-end, there is more opening for the what to put alongside them question.
The RasPi is a good example : For real-time and IO work, they usually add something else.
The Prop really fits in that 'add something else' basket, and allows IO solutions somewhere between a small Micro, and a small FPGA .
Another example of the 'move upwards' comes from Atmel :
The Atmel SAMA5D3 is shipping in a 324-ball BGA package and is in mass production now. Pricing starts below USD $7.00 for 1,000-piece quantities.
$7/1k is quite a good price point, but it still needs memory and mounting , and there is a reason the final Eval Kits are $486.59 & $650.61 (!)
A Prop 2 would sit alongside a large part like that, rather well.
You linked to a Cortex-M0+ core
here is Core M4's 72mhz and above, starting at $6 each (quantity 1)
http://www.mouser.com/Semiconductors/Embedded-Processors-Controllers/Microcontrollers-MCU/ARM-Microcontrollers-MCU/_/N-a85pcZscv7?P=1yztkjiZ1yzmn2iZ1yzonn5Z1z0vyt9Z1z0w7v2Z1z0w7wuZ1z0waa2Z1z0w7v5Z1yzrtskZ1yzoryl&Ns=Pricing%7c0
For my use, I picked up one of those desktop reflow ovens, works well enough for me, however I need to spend some time tinkering with those pop-can solder stencils. I s'pose I should find that special blue paper I bought, which didn't work with my old HP 3330MFP, and see if it works in the 2600n.
Which one did you get? I did a bunch of research on this back in October or so, and found only a few options:
1. The LPKF protoype ovens (very nice, but expensive)
2. The ~$400 ebay Chinese ovens
3. A few higher end (~$800+) Chinese ovens
In the end, I settled on a high end toaster oven and it's been working very well.
Ditto. I can only speak for myself, of course, but I am far more interested in something along these lines, and would have a much better chance of getting it into some real-world designs.
Yes, something like that. It's definitely a niche part. Although, with more memory it could possibly compete with & replace large 8-bit and small-medium 32-bit micros as the sole/main processor in a good number of designs; eg, instrumentation and control applications with modest user-interface requirements.
The M4s have floating point hardware built in, so they will out perform the Prop software emulation, probably by a factor of 20 or more for the same clock speed. The NXPs M4s have an LCD controller and external memory controller so can easily generate 16 or 24 bit VGA.
So in the pricing game the prop is going to have to find some niche, as it just doesn't compare to the ARM variants available, with new ones being introduced probably monthly or more frequently.
Analog ICs are sooo expensive. You can often use an ATTiny (~50c) to replace a simple analog chip (~$2+) - yes it requires a simple program but in volume ICP will be done simply.
The P2 will open up a lot of interesting niche markets with all its features. Remember, they are all sooo programmable using the same chip. The ARMs dont really have analog (at least yet) for general purpose.
P1B with some simple analog might be an interesting concept.
Anyway, I am more interested in getting the P2 than discussing other chips and what's wrong with the P2. If anyone thinks the P2 is not going to work, then why are you here wasting your time???
Ever notice the ever changing tide of ARM parts? Designing a long term project around one is an exercise in ERP.
One of the chief benefits of the P1 and P2 is shelf life. Their commitment to make the parts available for a long life cycle enables you to design without worrying if the particular A4300XYZABC-4 is available in 6 months.
I think you also overestimate the ARM's capability against the P2, the biggest variable is the quality of the programmer; GIGO.
From what I have seen so far it would make an excellent single chip (or low chip count) HID device for automation systems.
The question isn't so much whether it will work, but rather where it fits in, esp. relative to unit pricing.
