"All the lower COM ports were in use, but I remapped it to COM1. I'll have another go." - probably not a good idea to re-map it to COM1 ... See my note in post #59
I remapped mine to COM1 and it seems to work. This is on a Dell laptop. Maybe it doesn't have any actual COM ports.
COM1 and COM2 are usually reserved for a legacy MOUSE and are sometimes hardwired into the mother board.
I think its still possible even to redirect these (it seems to be a higher level handle style thing, not tied to traditional interrupts and i/o ports), but yes agreed, moving COM5~9 probably makes more sense.
It should be OK to redirect COM1-2 as long as there is no physical serial port on the computer
Watch out for COM3/COM4, sometimes USB serial converters will show up as COM3/4, so if you move them and later plug in the adapter that used to be there, you may have issues.
I don't have any tips. I just stay in PNUT, myself. It's minimal, but reliable. No scroll bars.
Actually I was hoping that a *minor tweak* might be considered for PNUT which only involves that it check if it's own copy of the file has been updated and if it hasn't then check to see if the file itself has been updated (by another editor) and reload if necessary before compile.
I've got the whole source for Tachyon sitting in there and it's very awkward trying to edit this large file in PNUT as you would know. Surely this tweak would be a good and simple solution?
Handling a file changing externally is not a minor tweak. Especially on Windows.
I am having a major lust for new silicon about this P2 emulation platform..... very difficult to ignore. Even with only 6 cogs, it is attractive and exciting.
Is there a description of jmptask somewhere? I'm trying to understand Chip's monitor code and how it handles the serial interface.
There are 4 program counters in each cog. They are initialized as follows:
PC0 = $000
PC1 = $001
PC2 = $002
PC3 = $003
At first, the task register, which is 32 bits (16 two-bit fields), is cleared to 0, making all time slots execute task0.
JMPTASK sets up to all four PC's at once, using a bit field in S and an address in D.
JMPTASK #substart,#%1111 ...would set all PC's to substart
JMPTASK #substart,#%1000 ...would set PC3 to substart
JMPTASK #substart,#%0100 ...would set PC2 to substart
JMPTASK #substart,#%0010 ...would set PC1 to substart
JMPTASK #substart,#%0001 ...would set PC0 to substart
Until SETTASK is executed (initialized to $00000000), only PC0 is running, making the cog seem normal.
SETTASK #%%3210 ...would enable all tasks. If no JMPTASK was done, PC1..PC3 would begin execution from $001..$003 (better have some JMP's there)
When you do an immediate SETTASK #, the lower 8 bits of immediate data are replicated four times to fill 32 bits. To get more granularity, you could do a register, instead of an immediate, and 32 unique bits would be loaded into the task register, which rotates right after each instruction completion, with the 2 LSB's determining which task to execute next.
Do you have a DE2-115 running? Those boards are made in Taiwan.
1) copy your code to a Untitled.spin
2) launch pnut.exe
3) hit F10
You could automate all but the F10.
For me to change pnut.exe, I could just make it always reload the file if a certain mode was set, right?
This of course isn't a bit deal as there are far more important things which is why I said it's a minor tweak which you must be used to and it's just another line or two and recompile. What harm could it do if it always reloaded a file before compile? If local changes have been made it should come up with the normal save prompt which is fair enough but this one minor tweak means PNUT can just do what it does best and that is compile and load while we can pick our external editors to suit.
What if we launch pnut.exe with a command switch that tells it to compile, download, and then shut down if there were no problems? That would be totally hands-free then. Would that work for you?
I'm compiling a large file but find that if I place my welcome string at the end of the code that it doesn't print. My obj file is 29K but the BIN file is only 2K.
Wouldn't that make it more complicated as we now have to tell it which file to open when it can already be open? I am finding it very necessary to use an external editor (CONTEXT) just so I can navigate and also UNDO all those little oopsies.
What for external editor You use?
I use NotePad++ that have that possibility's. ---> look on attached PDF
I'm running this on WINXP inside of VirtualBox running in LinuxMint 14 so I use CONTEXT as an editor. Normally I would use medit in Linux. As I said, this is not a big deal as I can work around, but then if it's not a big deal to have PNUT close and open it's current file so as to perform a reload then that's all I need.
Only $1F8 longs are being loaded.
What we are doing is just loading what is actually the 'loader' that would perform further loading, decryption, etc. I will have to make a re-loader program to download, in lieu of the $1F8 longs which are now being sent, which will then load the user code in, up to the top of memory, if there is so much.
It seems to be working on COM1, and loaded the code into the emulated cog. I'll follow your suggestions later, when I've had a play with it.
Chalk up another success with the DE0-Nano. It was I who first suggested using it!
NOT yet !!
We all wait for complete instruction's set
PC0 = $000
PC1 = $001
PC2 = $002
PC3 = $003
Here's an example program:
org jmp #task0 jmp #task1 jmp #task2 jmp #task3 task0 settask #%%3210 'turn on all tasks :loop notp #0 'toggle P0 jmp #:loop task1 notp #1 'toggle P1 jmp #task1 task2 notp #2 'toggle P2 jmp #task2 task3 notp #3 'toggle P3 jmp #task3I think detecting changes may be the hard part.
I think I might have a solution for you.
For each compile:
2) launch pnut.exe
3) hit F10
TESTLP mov dirc,txmask mov X,nameptr call #PRT_STR mov X,#1 shl X,#24 djnz X,$ jmp #TESTLP nameptr long @NAME+s PRT_STR rdbyte tos,X wz PRT_STR_ret if_z ret call #TRANSMIT add X,#1 jmp #PRT_STR ' <TACHYON KERNEL ------------------------ > ' then NAME byte $0D,$0A,"TACHYON P2 Forth ",0What for external editor You use?
I run native winXP
Let me see what I can do.
