Camera Module Recommendation
mynet43
I need a color camera module for a project I'm working on.
A resolution of 320x240 (or a little less) is OK.
It needs to have RGB 565 output.
It will be used to take single frame pictures and transmit them to a display device.
It needs to focus from about 2" to 4"+ and probably needs autofocus within this range.
I'll be using it on an electron microscope, to locate the target before extreme magnification.
Does anyone have a recommendation for a camera module that would work here?
Also, is there software available that would support this type of application?
Thank you for your help and support.
Jim
Jim
There's some info out on the web about how to use this camera if you dig around a little. If you have trouble finding stuff let me know. Despite one thread where a lot complain about not getting it to work, there are a few people who have and have the images to prove it. I have one of these and designed a breakout board based on sigalrm.blogspot.com's work, but using a dual-supply regulator to save board space. I have yet to actually try using the camera, though.
I don't know if a camera module with an onboard buffer exists. It would be much easier for my project idea (a variation on the panorama ball) if a microcontroller could trigger multiple cameras synchronously, then pull the image data asynchronously.
Do you have code to make these cameras work?
The people on SparkFun didn't seem to be able to make them work, because of bad documentation and lack of support.
If you have them working, I'd sure like to see the code. It would be a big help right now.
@Kye,
Thanks for the tickler.
Will the CMUcam4 be able to focus down to 2" and will it have autofocus from 2" to 4"?
I need both of these for this project. I have a moveable target within this range.
I may not be able to wait two months. I have a customer now
Thanks everyone for the great responses.
Jim
It can take the picture though.
Good luck with other options.
The CMUcam4 looks like this. If you could mount something to it,,,
That's a cool looking board. I may play with it for other projects.
Jim
Do you have the code available from the person that got this camera working?
I would be very interested to see how they set the registers and use the commands.
Jim
http://www.dtic.mil/cgi-bin/GetTRDoc?AD=ADA499618
Thank you for the link to the paper.
A couple of notes after reading it:
1. They mentioned that there were around 95 registers affecting the picture that they were unable to use because of insufficient documentation.
2. The code seems to be somewhat incomplete, such as a number of 'include' files that are not shown.
3. The description makes it clear that the picture output is started by a single command. Once this is sent, simply monitoring the clock and H and V signals allow scan lines to be transferred smoothly.
This looks like it should be fairly easy to implement on the Propeller.
Since their goal was to capture gray scale images, it's hard to determine what the picture quality would be in full RGB color.
I really appreciate your sending this. It gives me a good idea how to interface with the camera. Since it doesn't have autofocus, I'll have to keep looking.
Thanks again,
Jim
I don't have code but email the person at sigalrm.blogspots.com -- or search around for other implementations (I think one other person has recently posted a working board & software and such, can't remember where I saw it, though)
Michael
Thank you for the link to that document.
It seems to have detailed descriptions of many of the registers, commands and timing.
Looks really good.
Thanks again,
Jim
http://www.sony.net/Products/SC-HP/cx_news/vol41/pdf/mcb770.pdf
It has autofocus down to 10 cm and seems to be able to output uncompressed data.
Let me know what you think. I plan to try to find out more about it.
Jim
