Schmitt Trigger
Hello,
I need to buy a schmitt trigger for a prop project, to convert a sine wave to a square wave. I tried various op amps (lm358, lf411, 741) with no success. The frequency I need is about 430 khz. Can someone suggest any ICs?
Curtis
Curtis
As I stated in your other thread, a Schmitt trigger will introduce a phase shift. You will not get an accurate phase measurement from a Schmitt-triggered waveform.
I have been following this (i think it relates to the ultrasound thing Curtis is working on?) for a bit, and if the phase shift is known or measurable, it can probably be monitored and applied as a constant offset possibly in real time. It may be that the unit may need to determine that value for cal purposes at run time anyway. What I am most curious is just what is the range of measurement that Curtis is trying to measure.
Random thoughts of an enquiring mind,
Frank
My research showed that the schmitt trigger may do the job, but I am not as well versed as you all in this field. Thanks for the honest dialog. My purpose is to make an instrument with one single ultrasonic transducer and bring it to the surface of cultural materials (artifacts) in order to view and analyze defects. I would like to start with a 40 khz sensor and move forward to higher frequencies. Does there exist any other method for converting sinewaves to square waves without introducing an additional phase shift other that what is changing because of the defects in the material tested? In my last project, I used eddy currents to analyze defects in metals and also recover polished off engravings. I did this by measuring the voltage (amplitude) changes as the coil (probe) passed over a material. I never could measure phase shift which would have given me more data.
Curtis
I'll try the method phil suggested. I printed the thread (I/Q) detector and will read it more carefully and learn it.
Curtis
