BASIC Stamp 2 OEM Module — Parallax Forums
japerjaper Posts: 105
edited 2006-04-26 14:26 in BASIC Stamp
Hello
Some question about the BASIC Stamp 2 OEM Module (Assembled).
I noticed that the "BASIC Stamp 2 OEM Module (Assembled)"
doesn't have any mounting holes.
What are some recommended mounting styles ?
also not knowing that much.
Can the pin outs on this module connect to a ribbon type cable?
One last question i noticed the memory module can be exchanged.
Is it as painless as it looks to increase Logged Data space ?
thanks
japer
  • Steve JoblinSteve Joblin Posts: 784
    edited 2006-04-26 13:08
    Folks have used several methods for mounting the OEM Module...
    One way is to use velcro or double face tape. I have had a lot of success by drilling out the two holes on the DB9 Connector that mount to the board.
    The pinouts are based on a standard .1" center... you can use a header or solder wires directly.
    The memory module is easily exchanged (as is the pre-programmed PIC), but not interchangeable with other chips. That is, if your memory chip is damaged, you can easily replace it, but you can only replace it with the exact same part... you can't just excahnge it a larger size memory chip to add memory... it doesn't work that way.
    Post Edited (Steve Joblin) : 4/26/2006 1:12:52 PM GMT
    edited 2006-04-26 13:19
    Do you 'need' the BS2 OEM module for your project?
    If not, and you want more space for logging data, then I'd suggest you go straight to the BS2pe as it has been built specifically for logging operations. (You'll probably need some sort of carrier board, though)
    Also, while it is possible to 'bit-bang' I2C on all BS2s, the BS2p and later models all have I2C commands built-in, so there's no problem in adding as many EEPROMs as you like.
    Don't visit my new website...
    edited 2006-04-26 13:48
    This topic has come up before.· Here's one of the last threads on this subject.
    http://forums.parallax.com/showthread.php?p=578297
    csavage@parallax.com
  • NewzedNewzed Posts: 2,503
    japer, take a look at this:
    forums.parallax.com/forums/default.aspx?f=5&m=89723&p=1&ord=a[size=-1] [/size]
    Sid Weaver
    Do you have a Stamp Tester yet?
