scribbler programming problem
I·recently programming a scribbler for obstacle avoiden. What i want is when Scribbler is detecting the obstacle, it will stop and 'singing' and it will continue run after the obstacle move away. The problem is the Scribbler just keep 'singing' until the end of song then it continue running even the obstacle is moving away in the middle of song. Can u suggest the idea how can solve this problem?
Parallax Scribbler Robot is supported at a different location than the other Parallax products. You can find their support forum here:
http://forums.scribblerrobot.com/forums/
Good luck with your problem.
Bruce Bates
<!--StartFragment -->
