RF Problems
I have the 28004 receiver from the Parallax web site.
I am only getting 3.5 v from OUT1 and OUT3.· I am getting full voltage, 4.96, from OUTs 2,4,5.·
This is directly out of the pins on the module not after going through other wiring.
What gives?
What gives?
Sid Weaver
Do you have a Stamp Tester yet?
Sid Weaver
But that begs the question, what if was only when it was connected?
Thanks for your help.
Post Edited (ajs2001tx) : 10/1/2005 4:38:00 PM GMT
How are you supplying +5VDC power to this receiver? Is this module mounted in/on a breadboard or on a PCB of any sort? Is the ground on the receiver and the ground on the Stamp common? If not, it shoud be when it's in normal operation.
Bruce Bates
