Error when trying to load program to BS2 board.
I am trying to download a program to my Basic Stamp 2 board but the following error message prevents the download: "Hardware Communication Failure! Check Programming cable and Power source." I complete a syntax check multiple times, and I used several different USB cords. Also, I replaced the battery many of times. I even changed computers to download the program. As far as I can tell, everything from the board to the computer is picking up. The battery Is on, the USB connector is green and ready to go, and the computer is picking up the board. I need help ASAP.
Also, you should check the voltage on the BS2 board to verify you haven't grounded or shorted something to create a low voltage condition.
Do the easiest of the above first... sequence is not as important as getting clear on what is working and what is not.
With the old-style RS232 connection, you can also do a Null Modem check to verify the cable is working right up to the BS2 board.
I suppose that you need not check the USB port at the computer with a memory stick, but that is another option.
Most of the time... people are using a battery that is just too low for communications and programing... especially if they use the 9VDC batteries for power. They run out quickly.
