Help on Programming.
Thank you and Welcome.
I am trying to make a program work; but when I compile it, I receive a statement as: ELSEIF must be preceded by an IF.
Down below is my code.
I underlined the ELSEIF that the compiler pointed out as "must be precede by an IF"
I do not get it.
I still think I should not be having problem with that.
Please Help
Thank You
Main:
timeCounter=0
PAUSE 4000
timeCounter=timeCounter + 4000
IF (IN2=1)THEN GOTO wewillsee1
ELSEIF (IN3=1)THEN GOTO wewillsee1
ELSEIF (IN4=1)THEN GOTO wewillsee1
ELSEIF (IN1=1)AND(IN2=1)THEN GOTO wewillsee1
ELSEIF (IN1=1)AND(IN3=1)THEN GOTO wewillsee1
ELSEIF (IN1=1)AND(IN4=1)THEN GOTO wewillsee1
ELSEIF (IN2=1)AND(IN3=1)THEN GOTO wewillsee1
ELSE (IN3=1)THEN GOTO wewillsee1
ENDIF
ELSE (IN4=1)THEN GOTO wewillsee1
ENDIF
ENDIF
ELSE
IF (IN3=1)AND(IN4=1)THEN GOTO wewillsee1
ELSE (IN3=1)AND(IN4=1)THEN GOTO wewillsee1
ENDIF
ENDIF
ENDIF
IF (IN1=1)THEN
PAUSE 2000
ELSE
PAUSE 1
END
IF (IN1=1)THEN
IF (IN2=1)THEN
PAUSE 2000
ELSEIF (IN3=1) THEN
GOTO wewillsee2
ELSEIF (IN4=1) THEN
GOTO wewillsee2
ELSE
PAUSE 1
ENDIF
IF (IN1=1)THEN
IF (IN2=1)THEN
IF (IN3=1)THEN
PAUSE 4000
HIGH 15
LOW 14
ELSEIF (IN4=1)THEN
GOTO wewillsee3
ELSE
PAUSE 1
ENDIF
PAUSE 5000
IF (IN1=1)THEN
GOTO wewillsee4
ELSEIF (IN2=1)THEN
GOTO wewillsee4
ELSEIF (IN3=1)THEN
GOTO wewillsee4
ELSEIF (IN4=1)THEN
GOTO wewillsee4
ELSEIF (IN1=1)AND (IN2=1)THEN
GOTO wewillsee4
ELSEIF (IN1=1)AND (IN3=1)THEN
GOTO wewillsee4
GOTO wewillsee4
GOTO wewillsee4
IF (IN3=1)THEN
GOTO wewillsee4
ELSE (IN3=1)THEN
GOTO wewillsee4
ENDIF
IF (IN4=1)THEN
GOTO wewillsee4
ELSE (IN4=1)THEN
GOTO wewillsee4
ENDIF
IF (IN4=1)THEN
GOTO wewillsee4
ELSE (IN4=1)THEN
GOTO wewillsee4
ENDIF
ELSE
GOTO wewillsee4
ENDIF
ENDIF
ENDIF
PAUSE 1000
IF (timeCounter>=9000)THEN
GOTO wewillsee5
ELSE (timeCounter<9000)THEN
PAUSE 1
ENDIF
GOTO Main
wewillsee1:
PAUSE 8000
HIGH 13
LOW 12
PAUSE 5000
LOW 13
LOW 12
GOTO Main
END
wewillsee2:
PAUSE 6000
HIGH 13
LOW 12
PAUSE 5000
LOW 13
LOW 12
GOTO Main
END
wewillsee3:
PAUSE 8000
HIGH 13
LOW 12
PAUSE 5000
LOW 13
LOW 12
GOTO Main
END
wewillsee4:
PAUSE 5
HIGH 11
LOW 10
PAUSE 5000
LOW 11
LOW 10
GOTO Main
END
wewillsee5:
PAUSE 1
HIGH 13
LOW 12
PAUSE 5000
LOW 13
LOW 12
GOTO Main
END
I do not get it.
Please Help
Thank You
Main:
timeCounter=0
PAUSE 4000
ENDIF
ENDIF
ENDIF
ELSE
ENDIF
ENDIF
ENDIF
IF (IN1=1)THEN
PAUSE 2000
ELSE
PAUSE 1
END
IF (IN1=1)THEN
IF (IN2=1)THEN
PAUSE 2000
ELSEIF (IN3=1) THEN
GOTO wewillsee2
ELSEIF (IN4=1) THEN
GOTO wewillsee2
ELSE
PAUSE 1
ENDIF
IF (IN1=1)THEN
IF (IN2=1)THEN
IF (IN3=1)THEN
PAUSE 4000
HIGH 15
LOW 14
ELSEIF (IN4=1)THEN
GOTO wewillsee3
ELSE
PAUSE 1
ENDIF
PAUSE 5000
IF (IN1=1)THEN
GOTO wewillsee4
ELSEIF (IN2=1)THEN
GOTO wewillsee4
ELSEIF (IN3=1)THEN
GOTO wewillsee4
ELSEIF (IN4=1)THEN
GOTO wewillsee4
GOTO wewillsee4
GOTO wewillsee4
GOTO wewillsee4
GOTO wewillsee4
IF (IN3=1)THEN
GOTO wewillsee4
ELSE (IN3=1)THEN
GOTO wewillsee4
ENDIF
IF (IN4=1)THEN
GOTO wewillsee4
ELSE (IN4=1)THEN
GOTO wewillsee4
ENDIF
IF (IN4=1)THEN
GOTO wewillsee4
ELSE (IN4=1)THEN
GOTO wewillsee4
ENDIF
ELSE
GOTO wewillsee4
ENDIF
ENDIF
ENDIF
PAUSE 1000
GOTO wewillsee5
PAUSE 1
ENDIF
GOTO Main
wewillsee1:
PAUSE 8000
HIGH 13
LOW 12
PAUSE 5000
LOW 13
LOW 12
GOTO Main
END
wewillsee2:
PAUSE 6000
HIGH 13
LOW 12
PAUSE 5000
LOW 13
LOW 12
GOTO Main
END
wewillsee3:
PAUSE 8000
HIGH 13
LOW 12
PAUSE 5000
LOW 13
LOW 12
GOTO Main
END
wewillsee4:
PAUSE 5
HIGH 11
LOW 10
PAUSE 5000
LOW 11
LOW 10
GOTO Main
END
wewillsee5:
PAUSE 1
HIGH 13
LOW 12
PAUSE 5000
LOW 13
LOW 12
GOTO Main
END
to
The "IF (IN2=1)THEN GOTO wewillsee1" is a shorthand form of the If statement. This information is published in the PBASIC help file and STAMP manual.
