Servo troubles — Parallax Forums
Servo troubles
CharlotteTCharlotteT Posts: 1
edited 2010-12-28 15:13 in Robotics
I have a brand new Boe-Bot. My servos will only roll in one direction unless I adjust the screw. I can't seem to control the speed either. Does anyone know how to fix t his problem? :frown:
    Did you read the BoeBot manual? Use the screws to STOP the robot when you are sending PULSOUT 750s. Max speeds forward/reverse are PULSOUT 500 and 1000. Left & right servos are turning in opposite directions.
    Any of this sound familiar? If not, read the manual. The BoeBot will do exactly what it is commanded to do; commanding it properly is completely up to you. :)
