Code help with 4 bit LCD and running out of memory.
I am a relative noob at this and have cobbled together examples of code to manage to get my batch of sx28's to do what I need (kindof)
I am using a sx28 @ 50Mhz in conjunction with the 4 bit lcd code example I found on here (4x16).
My main objective is timing measurement based on a pulse which the sx measures. There are 2 modes which this is done, one if a pulse which derives a time and the 2nd derives rpm which can be seen by my horrible methods to get to the correct numbers.
Timing wise I am expecting pulses in the region of 14~16 Hz which are converted to be either 45.x seconds or 25000 RPM by either 168000 / pulse width or pulse width * 718 and then dividing down to get the correct numbers. This also use WORD var so eat memory.
My mode select needs to be a interrupt but at present my other code is too hungry to do this at present. Can anyone suggest better examples ?
I have tried to optimise the code as much as possible using arrays but I have found my limit ! Am considering using stamp / propeller.
edit
lcd.sxt is this (wont allow to upload)
' LCD.sxt - LCD Input / Output Subroutines
' Version 1.04 - 11/12/2005 - JJC
' Summary:
' These routines are used to communicate with a parallel LCD panel.
' I used RB.4-RB.7 to free up RB.0-RB.2 for ADC type work.
' Assumptions:
' LCD is using 4 pin parallel interface.
' LCD is wired as:
' 1 Ground
' 2 +5vdc
' 3 connect to ctr tap 10K Pot for contrast control
' 4 SX RA.0 (Register Select) = LCDRS
' 5 Ground
' 6 SX RA.1 (Enable) = LCDE
' 7 Ground
' 8 Ground
' 9 Ground
' 10 Ground
' 11 SX RB.4
' 12 SX RB.5
' 13 SX RB.6
' 14 SX RB.7
' 15 backlight control (not used in this program)
' 16 backlight control (not used in this program)
' IO Pins
' LCDRS var RA.0 ' Recieve/Send pin for LCD Module
' LCDE var RA.1 ' Enable pin for LCD Module
' Constants
' see LCD-con.sxt
' Variables
' see LCD-var.sxt
' Subroutine Declarations
' see LCD-sub.sxt
' LCD SUBROUTINES
LCDInit:
LCDData = $30 ' Write a 3 out to the display 3 times.
LCDPulse
LCDPulse
LCDPulse
LCDData = $20
LCDPulse ' Now go to 4-bit mode ($30 for 8 bit mode)
LCDPulse ' this is another command
LCDData = $80 ' Tell it to use the 2-line mode
LCDPulse ' Note: 1x16 modules only work in 2 line mode
LCDcmd LCD_Blink ' Blink cursor
LCDcmd LCD_CursorOn ' Activate cursor
LCDclear ' subroutine to clear LCD
LCDSize = LCD_Width * LCD_Lines ' set max len cursor index
return
LCDClear:
' Clear the screen
LCDcmd 1 ' 1=Clear Screen
LCDCol = 0 ' set column position to zero
pause 10 ' allow LCD time to catch up
return
LCDCmd:
' Send the character to the LCD device as a command
LOW LCDRS ' LCD Register Select 0=command, 1=normal letter
LCDout __PARAM1
HIGH LCDRS
return
LCDOut:
' Send the character to the LCD device as a letter
' This routine sends the upper 4 bits first then
' sends the lower 4 bits.
LCDChr = __PARAM1 ' Write to the LCD (4 bits at a time).
LCDData = LCDChr & $F0
LCDPulse
LCDChr = LCDChr << 4
LCDPulse
return
LCDPos:
' Set the cursor to the specified position
' Note: that all displays think that
' line 2 starts at pos 64 even if
' they don't have that many characters.
LCDCol = __PARAM1
LCDCol = LCDCol // LCDSize
LCDP1 = 0
LCDP2 = LCDCol // LCD_Width
If LCDCol >= LCD_Width then
LCDP3 = LCDCol / LCD_Width
LOOKUP LCDP3,0,64,LCD_Width,80,0,LCDP1
endif
LCDP1 = LCDP1 + LCDP2
LCDP1 = LCDP1 + $80
LCDcmd LCDP1
PAUSE 1
return
LCDPulse:
' Pulse the Enable Bit
PULSOUT LCDE,5,100
return
edit
' Summary:
' Assumptions:
' LCD is wired as:
' 1 Ground
' 2 +5vdc
' 5 Ground
' 7 Ground
' 8 Ground
' 9 Ground
' 10 Ground
' 11 SX RB.4
' 12 SX RB.5
' 13 SX RB.6
' 14 SX RB.7
' IO Pins
' Constants
' see LCD-con.sxt
' Variables
' see LCD-var.sxt
' see LCD-sub.sxt
' LCD SUBROUTINES
LCDInit:
LCDPulse
LCDPulse
LCDPulse
LCDData = $20
return
LCDClear:
' Clear the screen
return
LCDCmd:
LCDout __PARAM1
HIGH LCDRS
return
LCDOut:
LCDPulse
LCDPulse
return
LCDPos:
LCDCol = __PARAM1
LCDP1 = 0
endif
LCDP1 = LCDP1 + $80
LCDcmd LCDP1
PAUSE 1
return
LCDPulse:
PULSOUT LCDE,5,100
return
