How to connect an open collector output to bs1 Input
Hi there ,
I have an Autonic photoelectric sensor with an 12V Open Collector output (either NPN or PNP) that I would like to connect to a BS1. I guess that I can’t connect it directly to a PIN on then BS1. One solution would be to put a mechanical relay in between, but I am not to keen on that since it will be switching several hundred times every day. I was wondering if I could connect a transistor between the PIN and ground and have the Photo sensor output connected to the Base of the transistor?
Would this work and which transistor would you recommend or is there a better way?
/PeterH
the data sheet for the sensor can be seen here http://www.autonics.com/upload/data/K-15~16(BA).pdf
/PeterH
I'd stuff in some extra components because I'm part of the nefarious circuitry cabal (see attached.)
Post Edit -- Hey, I show the same GND symbol on the Autonic and Stamp, but they don't have to be common (if that's not desired.)
Post Edited (PJ Allen) : 12/13/2009 11:45:29 PM GMT
Leon
Amateur radio callsign: G1HSM
[noparse][[/noparse]We all know how obscenely expensive resistors are.]
I don't like it, because now it's 12V, but then it'll 24V and next week...
Post Edit --
I like mine because if things change and you biff the opto it's no big deal.
Post Edited (PJ Allen) : 12/13/2009 11:53:59 PM GMT
/PeterH
