problem with eeprom codes
Why does my eeprom coding keep showing that my value stored is 255??
http://www.flickr.com/photos/45199419@N02/4152646708/·-> this is the problem
http://www.flickr.com/photos/45199419@N02/4152646680/·-> this is the codes i use
"255" aka $FF aka "all ones" is the 'erased' state of an eeprom.
If you're reading the 'Memory Map', it doesn't tell you what's in the eeprom, it tells you what the IDE is going to write to the eeprom.
