FemtoBasic Editor
I knew this would happen once I started working more with FemtoBasic - it needs an editor when writing programs. Something like EDIT 80 to go into line 80 and change code, along with other commands for insertion, deletion, etc. Is there anything available or some techniques that can be used? Keep in mind that I use only the HYDRA and must keep ability to read and write to the main board and memory cards.
EDIT: Found the answer...
Thanks to OBC, a link for an editor is here.
http://forums.parallax.com/showthread.php?p=790443
humanoido
Post Edited (humanoido) : 5/4/2009 2:31:31 PM GMT
humanoido
