Best way to store a string in a SPI Eeprom?
In the App-kit 8K-Eeprom program, the BS2 writes and retrieves a
value from a given address.
Is there a fast code of sending a whole string (not passing the
block off course) and then retrieve it the same way?
I use BS2p.
Thanks for some solutions.
Reason: Forum Migration
Since you're using the BS2p you might consider a change to I2C memory,
as the built-in I2C commands will simplify EEPROM access.
-- Jon Williams
-- Applications Engineer, Parallax
-- Dallas Office
-----Original Message-----
Sent: Saturday, August 09, 2003 5:16 PM
To: basicstamps@yahoogroups.com
Subject: [basicstamps] Best way to store a string in a SPI Eeprom?
I use BS2p.
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Hello,
Don't forget that some I2C EEPROMs have page write buffer boundaries. For
example the Microchip 24LC32A has a page write buffer of 32 bytes. If you
start writing at address 16 then you can only write 16 bytes before the
page write buffer rolls over. To use the whole buffer you have to start
writing at 32 bytes boundaries (0, 32, 64, etc..).
This caused me quite a bit of headache when I first tried using one. I
skimmed over it when I read the spec sheet!
Chuck Chargin Jr.
>-- Jon Williams
>-- Dallas Office
>From: stein_frostad [mailto:Stein_Frostad@m...]
>I use BS2p.
>abuse@p....
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I'm impressed of the inbuilt functions in BS2p. I try to utilize
them as often as possible.
The data flash AT45DB041 from ATMEL, is a SPI memory holding 2048
pages * 256 bytes (0.54 Meg) and also has two 264-bytes SRAM data
buffers. I was hoping to try out this circuit in the future, but
first I should understand the use of the regular SPI Eeprom. In fact
I have not even checked the price or accessibility from ATMEL, but
my regular IC-shop doesn't sell ATMEL. I know that Tracy Allen has
written that he has used this memory.
I was asking how to use the shiftout/shiftin to store and retrieve
string to the Eeprom.
This DEMO-code works, but is there a better way instead of clocking
in the char one byte at the time. Then perhaps I don't have to send
one char at the time to the LCD.
CON and VAR from 8K Eeprom APP-kit
EEwrite:
low CS ' Activate the EEPROM.
shiftout DATA_N,CLK,msbfirst,[WriteEE]' Send write opcode.
Eeaddr=8191
For Index= 0 to 13
EEaddr=EEaddr+1
Gosub Send_addr ' Send the address.
Lookup index,["This is a test"],Result
shiftout DATA_N,CLK,msbfirst,[Result] ' Send the data.
Next
high CS ' Deactivate the EEPROM.
return ' Return to program.
EEread:
shiftout DATA_N,CLK,msbfirst,[ReadEE] ' Send the read opcode.
EEaddr=0
For Index=0 to 13
EEaddr=EEaddr+1
shiftin DATA_N,CLK,msbpre,[INdata]' Get the data.
Debug Indata
LCDOUT 1,MoveCrsr+Index,[INdata]' LCD must then show one
char at the time.
Next
--- In basicstamps@yahoogroups.com, "Chuck Chargin Jr."
<cchargin@e...> wrote:
> Hello,
boundaries. For
bytes. If you
before the
start
one. I
> Chuck Chargin Jr.
memory,
> >-- Jon Williams
> >-- Dallas Office
> >I use BS2p.
Subject
> >abuse@p...
Subject and
Using SHIFTOUT I'm afraid you will have to do it a byte at a time. Part
of the reason for this is that SHIFTOUT allows you to shift other than
8-bit values, so you cannot use "string" designations (slash parameter)
in SHIFTOUT like you can in other routines (I2COUT, for example).
-- Jon Williams
-- Parallax
Sent: Sunday, August 10, 2003 6:39 AM
Subject: [basicstamps] Re: Best way to store a string in a SPI Eeprom?
EEwrite:
Eeaddr=8191
For Index= 0 to 13
EEaddr=EEaddr+1
Next
EEread:
EEaddr=0
For Index=0 to 13
EEaddr=EEaddr+1
Debug Indata
char at the time.
Next
> Hello,
boundaries. For
bytes. If you
before the
start
one. I
> Chuck Chargin Jr.
memory,
> >-- Jon Williams
> >-- Dallas Office
> >Is there a fast code of sending a whole string (not passing the block
> >I use BS2p.
Subject
> >abuse@p...
Subject and
abuse@p....
EEPROM self-increments its address within each block, so you don't
necessarily have to send the address for each byte. However, like
I2C, you have to respect the block boundaries, otherwise you will end
up overwriting in circles back at the beginning of the same block.
The block size is usually quite small, like 16 or 32 bytes. (The
ATMEL dataflash blocks are 264 bytes).
Say you want to send a word data, then use
GOSUB send_addr
shiftout dpin,cpin,msbfirst,[word_data\16] ' sixteen bits
Strings? The idea is to send the address and initiate a new block
only when the string crosses block boundaries. Remember that it
takes a few milliseconds for eeprom to write data, so if you can
write a whole block at once, you can save a lot of execution time.
Suppose a string is stored (buffered) starting at address 0 in the
SPRAM of the BS2p, and that the string is N bytes long, which may be
more or less than the blocksize. The string needs to be moved to
eeprom, starting at address held in ADDR0. Suppose the blocksize=32
bytes.
' {$PBASIC 2.5}
for i=0 to N-1 ' N bytes in string
addr=addr0+i ' address of next byte in eeprom
if addr // blocksize = 0 OR i=0 then gosub send_addr ' do this
only to start a new block write.
get i,char ' from SPRAM
shiftout DATA_N,CLK,msbfirst,[char] ' Send the data, but don't
close the write
next
high CS ' close the final write.
end ' would normally update ADDR0=ADDR0+N
send_addr: ' start new block
high CS ' close last write
' should check the eeprom status byte here, to allow it to complete
the write!!! or PAUSE 9
low CS
shiftout dta,clk,msbfirst,[WREN] ' write enable opcode.
high CS ' register it.
low CS ' Activate EEPROM.
shiftout dta,clk,msbfirst,[WrEE] ' write opcode.
high CS ' register it low CS
' send address
shiftout dta,clk,msbfirst,[ADDR\16]
return ' with address open for writing
There may be better ways to code it, with an inner loop that does not
test for the beginning of the block. This kind of routine also is
good for erasing eeprom, say, because you can send cycles of 16 $FFFF
to the whole memory array, and burn each block in multiples of 32
bytes.
-- Tracy
>EEwrite:
> Eeaddr=8191
> For Index= 0 to 13
> EEaddr=EEaddr+1
> Next
>EEread:
> EEaddr=0
> For Index=0 to 13
> EEaddr=EEaddr+1
> Debug Indata
>char at the time.
> Next
>> Hello,
>boundaries. For
>bytes. If you
>before the
>start
>one. I
>> Chuck Chargin Jr.
>memory,
>> >-- Jon Williams
>> >-- Dallas Office
>> >I use BS2p.
>Subject
>> >abuse@p...
>Subject and
>Subject and Body of the message will be ignored.
Thanks Tracy, your help is really appreciated.
I just got hold of a free sample Atmel IC as well.
Stein.
end
block.
> GOSUB send_addr
block
be
blocksize=32
> bytes.
> ' {$PBASIC 2.5}
this
don't
> close the write
> next
complete
> low CS
> ' send address
not
$FFFF
> bytes.
> -- Tracy
clocking
send
> >EEwrite:
> > Eeaddr=8191
> > For Index= 0 to 13
> > EEaddr=EEaddr+1
> > Next
> >EEread:
opcode.
> > EEaddr=0
> > For Index=0 to 13
> > EEaddr=EEaddr+1
> > Debug Indata
> >char at the time.
> > Next
> >> Hello,
> >boundaries. For
> >bytes. If you
> >before the
to
> >start
> >one. I
> >> Chuck Chargin Jr.
> >memory,
> >> >-- Jon Williams
> >> >-- Dallas Office
Eeprom?
a
> >> >I use BS2p.
> >Subject
to
> >> >abuse@p...
> >Subject and
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
