Results 1 to 16 of 16
Thread: Index Test
    Default Index Test
    Rich's Parallax and Savage Circuits Search
    I don't like relying on my "Favorites" to find threads here on the forum.
    I'm making an index of threads, I frequently link to or use, here.
    Thanks to Humanoido for the idea of using a Test Forum post as an index.
    This first post with be an index to the index.
    Post #2: Personal Projects Index
    Post #3: FAQ
    Post #4: Machine Vision, Video Overlay, Fonts
    Post #5: Miscellaneous and Unsorted Posts Including:
    Tools for Prop Programming
    Prop to Prop Communication
    Prop Lab Equipment
    Thermistor
    Air Quality
    Encoder
    PWM
    Wireless
    Spinnerete/Ethernet
    GPS
    Auto Pilot
    Gyro
    Display Drivers
    Sound with the Propeller
    Enclosures
    Batteries
    PCBs
    Electronics Information
    Best Practices
    Other
    Prop Plug with Enclosure Ideas
    Math
    DIY Prop Plug
    Medical Links
    Pulse Oximetry
    Post #6: AVR Stuff
    Post #7: Displays
    Post #8: Boards of Interest
    Post #9: Items of Interest
    Post #10: Servo Info., Say It Info. and Quadcopter Information.
    Post #11: E-Books
    Post #12: Robots and Robot Controllers Index
    Ten Nordic Modules for $19 on EBay
    (2/14/13) I'm now including dates of when a link is added. Hopefully this will make it easier for forum members to find new links.
    Default Re: Index Test
    Projects by Duane Degn
    Personal Blog
    (Only three posts as of 8th of November 2011)
    Omni Wheeled Plywood Base Bot (in Retrobot thread)
    Mecanum Wheeled Robot with Machine Vision (Video)
    The above includes my LED array
    __Same Robot on Lets Make Robots
    Stack of 23K256 SRAM chips with 8-bit bus
    QuickStart Roomba
    QuickStart Demos and Projects
    Modifications to Tim Moore's four port serial object
    __Improved version by Tracy Allen (Use this object when you want flow control or more than one port.)
    ____OBEX Version (fullDuplexSerial4port)
    Lab data logging
    Nordic nRF24L01+ driver
    _Mark_T's Audio Streaming Object
    Panic Buttons
    Say It bridge program for Propeller
    Relay powered cell phone dialer
    Buffered 4x4 Keypad Object (I don't really trust this object)
    Wearable Keypad Object
    Serial port merger
    Universe Remote (Using Rayman's PTP, just a picture)
    QuickStart Servo Tester (Video)
    Scribbler 2 Enhanced Obstacle Avoidance (Video)*
    LED Flasher
    Serial Barcode Reader
    Propeller Driving 32 Servos (Video)
    6-Digit 6.5" 7-Segment Display (Clock) (Video)
    Popsicle Stick Hexapod (Video)
    AS5055 Magnetic Encoders (now with software) (Video)
    **Encoder PCB Designs
    **Encoder with Prop and Sigma-Delta
    PropBOE Bot (Video)
    Hexapod Build
    PlayStation 2 With Analog Buttons
    Pulse Oximeter Attempt (Video (poor quality))
    Simple 74HC165 Object
    8x8 RGB LED Array (Video)
    Receive Six RC RX Signals on Any Pins (I only programmed the "any pins" part)
    Polymorph Tutorial (Video)
    (2/14/13)Rover 5 Thread *
    (2/25/13)Spark Fun (Fun with a Spark Gap Igniter)
    (2/27/13)CheapBot (an Inexpensive BSA Robotics Merit Badge Bot)
    *Listed in other places in the index.
    Frequently Asked Questions
    How do I learn to program the Propeller chip?
    Propeller Education Kit (Also in "Help" menu of Propeller Tool)
    This is probably the best place to start. Mostly Spin.
    Learn.Parallax.Com
    This is another good place to start learning about programming the Propeller in Spin. These tutorials use the Propeller Board of Education.
    Propeller Manual v1.0 (older version)
    The older version of the manual include a section on learning to use Spin. This is the way I learned Spin.
    Propeller AppNotes Lots of great information. Make sure and take a look a them. Spin and PASM.
    The Spin Zone: Adventures in Propeller Programming
    Nuts & Volts articles by Jon Williams (JonnyMac) I finally figured out how to program with PASM from these.
    (These also include lots of good information about programming in Spin.)
    Programming and Customizing the Muticore Propeller Microcontroller
    Not really an absolute beginner's book, but lots of good stuff. (Mostly Spin IIRC.)
    deSilva's Tutorial
    This a good one for learning PASM. Potatohead's tutorial is also here.
    Graham Stabler's Tutorials PASM
    I personally haven't read these but they are recommended by others and Graham is a smart guy so they should be good.
    The Hydra Book (Link to the book is near the bottom of the page, under "Downloads & Resources")
    This is a great book. It has lot of information about the Propeller video capabilities.
    Propeller Wiki
    Both Spin and PASM information.
    Propeller Downloads
    How can I tell if my EEPROM is 32K or 64K?
    Use the program attached to post #24 in this thread.
    More explaination.
    How can I interface the Prop with a file on my computer?
    Use Phil's program to read a write to Windows cvs files.
    Also see AppNote #AN018.
    How do I learn to build a robot?
    Robotics with the Boe-Bot (Link to the book is near the bottom of the page, under "Downloads & Resources")
    I like this book but I'm not a fan of Basic Stamps (Propeller are so much better).
    The book still teach a lot about electronics which may be applied to a robot controlled by a Propeller chip.
    If you need help converting any of the lessons to use with a Propeller, just ask on the Propeller Forum.
    I understand Parallax is working on a Prop-Bot. I look forward to it.
    Gordon McComb's Robot Builder's Bonanza 4th Ed.
    Robot Forum
    The Robot Forum is also a good place to learn about robots.
    (3/11/13) Another great resource is the Society of Robots.
    (3/18/13) Great robotics video found on LMR.
    (3/18/13) If you haven't seen Let's Make Robots, go there!
    What are the requirements for the Boy Scouts of America Robotics Merit Badge?
    Merit Badge Wiki
    Forum Questions
    How do I post code in the forum?
    How do I add large inline pictures?
    My method in post #15
    Phil's method in post #7
    How do I make a word or words a hyperlink?
    My tutorial
    Miscellaneous Indices
    Tool for Prop Programming
    PreSpin
    Using eBay USB to Serial Boards as a Prop Plug
    Cheap Prop Plug Alternative
    Prop OS
    (3/20/13)Cluso99's OS
    Prop to Prop communication
    http://forums.parallax.com/showthrea...-Perturbations.
    http://forums.parallax.com/showthrea...-Communication
    Prop Lab Equipment
    Poor Man's Oscilloscope
    EasyADC
    Propalyzer
    Beau's TV Oscilloscope
    Thermistor
    http://forums.parallax.com/showthrea...Harness-Tester
    Thermal Imaging
    Phil's Prop Thermal Imager
    Air Quality
    Chris Nafis Compares Two Particle Counters
    Radon Detector Hack
    Encoder
    http://forums.parallax.com/showthrea...on-sensor-disk
    Graham Stabler's Magnetic Encoder Object
    My AS5055 Project (Object soon to be released)
    (4/13/13)Quadrature Encoder Tip/Walk Through at LMR
    PWM
    PWM With or Without Counters?
    Hard Drive Motor Control
    Wireless
    http://forums.parallax.com/showthrea...grams-via-XBee
    http://forums.parallax.com/showthrea...meter&p=809389
    Martin_H's Wireless Programming Propellers with Wixel
    BlueTooth
    Ron Czapala's BS2 Code for Nordic nRF24L01+ Modules
    Recover a Bricked XBee
    Spinneret/Ethernet
    Javalin's Fix to W5100_Indirect_Driver.spin
    Mike G's Spinneret Manual
    GPS
    Andrew Williams' Propeller Based Handheld GPS with Full Code
    Paul_H's Propeller GPS Datalogger
    Chris Savage's BS2 GPS Datalogger
    (5/30/13) Ragtop's GPS Logger
    Auto Pilot Stuff
    http://forums.parallax.com/showthrea...ow-with-source
    Gyro
    lisy300
    Display Drivers
    http://forums.parallax.com/showthrea...TSC-PAL-Driver.
    Propeller Backpack Custom Character Overlay
    (2/20/13)HDTV Format Information
    SIDcog - The sound of the Commodore 64 ! (Now in the OBEX)
    Phil's Simple Class D Speaker Amp Using a MOSFET Driver
    Phil's Who needs a speaker amplifier when you have a spare H-bridge?
    Tracy Allen's Search for Loud but Small, Thin Audio Speaker
    C3 Audio Concerns I
    C3 Audio Concerns II
    Veho 360 speaker
    Phil's Audio Frequency Shifter
    FTDI Reset Issue
    http://forums.parallax.com/showthrea...=1#post1136037
    (3/20/13)Kye's wav Recorder (OBEX)
    (3/20/13)Kye's wav Player (OBEX)
    (3/20/13)Phil's Goertzel Object with CTMF Decoding
    (3/20/13)Color Organ Thread
    Ultrasound
    (3/20/13)Shared Echo Pins of Multiple Sensors
    Enclosures
    List of Enclosure Websites
    Plastics
    (3/20/13)Mold Making Smooth-On (I haven't used them myself.)
    Batteries
    Some Discussion about NiMH Charging
    Prop on Single LiPo?
    PCBs
    Making your own PCBs and links to pro sites
    (link fixed 6/14/13) Iteads Studio 4-Layer Service 5cm x 5cm
    PCBCart
    OSH Park
    Why Parallax switched from Eagle to DipTrace
    Soldering
    (6/14/13) TonyP's Toaster Oven
    Driving Motors with Transistors (off site)
    Best Practices
    NASA Workmanship Standards
    NASA Perferred Practices for Design and Test
    Other
    http://forums.parallax.com/showthrea...te-White-Board
    http://forums.parallax.com/showthrea...am-Radio-Study
    http://forums.parallax.com/showthrea...hlight=s2.spin
    http://forums.parallax.com/showthrea...opeller-Loader
    http://forums.parallax.com/showthrea...tch-job-object
    Panel Mount Header?
    With Metal Enclosure Ideas
    Sliding Drill Press Vice to help Cut Holes
    Math
    Display Pseudo Real
    Newest F32 Update (not in OBEX)
    uM-FPU64 64-Bit Coprocessor
    (3/20/13)Math Section of Propeller Wiki
    Humidity
    (3/20/13)Sensirion SHT1x & SHT7x Integer Math Object
    Theads I want to reply to sometime
    http://forums.parallax.com/showthrea...-Kit-Questions
    http://forums.parallax.com/showthrea...anging-program
    http://forums.parallax.com/showthrea...-at-home-ideas
    http://forums.parallax.com/showthrea...p-on-propeller
    http://forums.parallax.com/showthrea...is-Old-BOE-bot
    http://forums.parallax.com/showthrea...igital-Readout
    http://forums.parallax.com/showthrea...rse-kinematics
    http://forums.parallax.com/showthrea...ller-BOE-Robot
    http://forums.parallax.com/showthrea...a-s9254-servos
    http://forums.parallax.com/showthrea...t-s-navigation
    http://forums.parallax.com/showthrea...e-amp-Martin_H!
    http://forums.parallax.com/showthrea...30#post1104730
    DIY Prop Plug
    120321
    120528
    Medical Links
    Pulse Oximetry
    TI Site
    http://www.oximeter.org/pulseox/principles.htm
    http://pinouts.ru/PortableDevices/ne...e_pinout.shtml
    Ohio State DIY Pulse Oximeter
    Freescale AppNote
    What you should know about LEDs and PDs
    Ken's Request for SpO2 Code
    Test Photodiode
    LMR Pulse Oximetry
    Photodiode Question
    I'm trying to learn to program AVR chips. Mainly so I can program the ATTiny24 on SparkFun's Nordic FOB(see panic button project for more info).
    I thought I'd list some fo the useful sites I've found here.
    Arduino
    Derek Malloy's Intro to Arduino
    Malloy's Arduino on a breadboard tutorial (video)
    Malloy's AVR Dragon Intro (video)
    AVR Freaks
    Programing Propeller with ATtiny84
    AVR ATtiny84 (Small Chip with lots of Memory)
    AVR ATtiny2313 (Small Chip with UART)
    Other External (to Parallax) Sites:
    Savage Circuits
    Savage Circuits - Completed Projects
    Items of Interest
    Items I own:
    (Just some I want to be able to find quickly)
    Parallax:
    Propeller Boards
    Propeller Protoboards
    USB Propeller Protoboards
    Propeller Professional Development Board
    Propeller Demo Board
    Propeller Backpack
    QuickStart
    C3 Full Kit
    Hydra
    Spinneret
    Parallax Laser Range Finder
    PropBOE
    Ping
    PIR Sensor
    Ultrasound Transducers
    SparkFun:
    Nordic FOB
    nRF24L01+ chip antenna
    nRF24L01+ RP-SMA
    nRF2401A chip antenna
    XBee XSC wire antenna
    XBee XSC RP-SMA
    XBee ZigBee Pro wire antenna
    XBee ZigBee Pro RP-SMA
    XBee ZigBee wire antenna
    XBee ZigBee RP-SMA
    MicroMag 3-Axis Magnetometer
    SoftPot Rotary
    SoftPot 500mm
    Dual Gearbox
    Rover 5
    Tank Treads
    Mecanum Wheels (Vex Mecanum Wheels a lot better than these.)
    Mouse Sensor (Parallax's version is better)
    LinkSprite JPEG Color Camera
    DealExtreme
    6mm 5mW Laser Module
    Items I'm thinking about:
    Holder for 5 AA Batteries
    Futurlec beakout boards for smt parts
    Things Erco had made me buy:
    Ultrasound sensors
    Purple batteries
    Li Ion batteries (AA size)
    Roomba
    Roboni-I
    Vex Mecanum Wheels
    Switching Regulator
    L298N Motor Controllers
    Part Sources
    TNC Scooter
    Electric Scooter Parts
    Micro Fasteners
    Shopping List
    Digi-Key To Buy List (updated 10/11/12)
    74HC573 IO expanders for 144 servo driver
    ATtiny2313
    2.6V regulator
    camera
    grid_eye
    smt ATtiny84 with leads
    optoisolators
    DC to DC chip
    (6/19/13) +/- 30A Current Sensor
    (6/19/13) Also +30A, 20A, 5A
    Mouser To Buy List (updated 5/7/12)
    1mm pitch, 10-wire ribbon cable (to use with 2mm IDC)
    Pololu To Buy (and Already Purchased) List (updated 1/22/13)
    Pololu Motors
    37Dx54L 67:1 Gearbox Motor with Encoder
    37D Motor Brackets
    Mounting Hubs 6mm
    MC33926 H-Bridge
    MC33926 at Digi-Key
    Mdfly.com (updated 7/4/12)
    MP3 Player with SD card holder
    Pogo Pins
    10mm Standoff
    30mm Standoff
    Other Prototyping Stuff
    LED Heatsink
    IR LED 1W
    http://www.mdfly.com/index.php?main_...roducts_id=483
    Servo Stuff:
    Beau's 144 servo controller
    Rayman's Servo Hack
    Rayman's Serial Servo Attempt
    Open Servo
    ZoSuper Modified Servos
    $3 Servo Tester
    Hobby King HX12K Metal Geared Servo
    Hobby King Vigor VS-11 Large Servo
    Hobby King HXT900 Micro Servo
    __LMR HXT CR Tutorial
    Metal Gear 180 Degree Servo
    My Servo Projects (Listed Previously)
    QuickStart Controlling 32 Servos
    Say It Stuff:
    Martin_H's Robot
    SayIt GUI and Example BS2 Code
    SayIt Bridge Program for Propeller
    Prop Voice Recognition
    Chips to use with the Propeller
    TC4427
    QuadCopter Stuff
    Forum Threads
    Jason Dorie's QuadX
    ELEV-8 Build Log
    (5/25/13)Jason Dorie's Code for the HoverFly Sport See Jason's Thread listed below
    ELEV-8 Assembly and Flight
    ELEV-8 Cameras
    ELEV-8 Connector Questions
    ELEV-8 Radio Setup Questions
    ELEV-8 Flight Simulators
    ELEV-8 Batteries
    Another Build Log (by CowboyCoder)
    HackAWeek (MakerDino) Build Log Videos
    (5/25/13) Competing Quadcopter Solutions
    (5/25/13) Parallax and HoverFly: Relationship and Future Plans! (Ken Gracey)
    (5/25/13) Jason Dorie's QuadX Open Source Quadcopter Firmware (Thank you Jason)
    Related Links of Personal Interest
    (5/27/13) HMC5883L 3-Axis Compass at HobbyKing
    (5/27/13) ITG-3205 3-Axis Gyro at HobbyKing
    Airspeed Sensor at DigiKey
    http://www.kkmulticopter.kr/index.html?modea=manual
    http://rcexplorer.se/Educational/kkg...ide/quadx.html
    http://www.hobbyking.com/hobbycity/s...ga328_PA_.html
    MultiWii at HobbyKing
    MultiWii.com
    MultiWii Google Code
    HobbyKing $100 QuadCopter
    Forum Post about $100 Quadcopter
    Large Quad Parts (One I'm slowly building testing)
    Plush-60A
    Turnigy Outrunner
    ELEV-8
    Turnigy 2217 860 kV Outrunner
    Control Board
    PinOuts
    Click image for larger version
    Back
    Hacking Spektrum and Orange Radios
    rcgroup hacking Spektrum remote receiver
    rcgroup hacking Spektrum telemetry
    rcgroup BLDC controller
    rcgroup Flyduino
    Books
    Robot Builder's Bonaza 4th Edition
    Forum
    Amazon Link
    Programming and Customizing the Multicore Propeller Microcontroller
    Ebook
    Intruder Alarms, 2nd Edition, by Gerald Honey
    This ebooks will be here temporarily.
    This book was deleted on March 5, 2012.
    I had uploaded this ebook in response to this thread.
    http://www.scoutstuff.org/bsa/unifor...-web-belt.html
    Robot and Robot Controller Index.
    Robots:
    Scribbler 2:
    Parallax's S2 Product Page
    Parallax's Information and Downloads Page
    Black Masking Tape
    Sneak Peek
    Pen Lifter
    Internal Pen Lifter
    Alphabet for S2”: A Collaborative Project
    XBee Remote
    Early S2 Thread
    Reveals Soul (draws Propeller beanie)
    S2 on Sale
    Expansion Board
    S2 Sound: Audio "Loudness" and Dynamic Range Compression
    (2/14/13)Gwolfe's Custom S2 Software
    PropBOE-Bot:
    Product Page
    Downloard Page
    Learn.Parallax (tutorials on using a PropBOE-Bot)
    Jose's QuickStart BOE-Bot
    Rover 5:
    SparkFun Product Page
    (2/14/13)My Rover 5 Thread in the Robot Forum*
    Roomba:
    Magician Chassis:
    Forum Post
    Robot Parts:
    Dual Gearbox with Motors
    Cheap Omni Wheels
    Treads
    Lynxmotion Tread
    Vex Tank Tread Kit
    Tamiya Tank Tread
    BOE-Bot Tread Kit
    Rover 5 Treaded Robot
    Bicycle chain tread
    Mattracks (for trucks and ATVs)
    (3/13/13)Thread about Treads on Let's Make Robots
    Robot Controllers:
    PJ's Cypherbot with Controller
    Microcontrolled's Stingray Remote
    Microcontrolled's Remote, Version 2
    Propeller Wireless Intelligent Terminal (PWIT) (S2 Remote)
    Paul K's XBee Robot Controller
    TheGrue's Robot Remote
    Robot Navigation:
    Robot Location Thread
    Compass Accuracy & Dead Reckoning
    Autonomous robot's navigation
    6DOF IMU
    Bots to Find Again (robots I want to be able to find again)
    Erco's Trash Bot
    Erco's Retro Bot
    Sphere Robot by Zenta
    Prospero
    Sensors:
    Ultrasound:
    IR-augmented Echo-location with the Ping)))
    IR:
    IR Compound Eye
    IK:
    Martin_H's Arm
    IK thread in Robot Forum
    * Listed in other places in index.
    Last edited by Duane Degn; 03-13-2013 at 06:42 PM. Reason: Added LMR Thread about Treads
    This is a good idea. I've had an index here for some time. If everyone made indices, we would have a powerful resource. Keep at it.
    Humanoido,
    Have you to thank for the idea of using a test forum post as an index. (I just added a line to my first post about this.)
    I considered use the blog area as an index but I like the way forum posts display better than the way blog posts display.
    You also have to add some code to get links to show up in blogs.
    I have a bunch of projects I haven't documented yet. Hopefully I'll have more to add to my personal project index soon.
    Duane
    (4/11/13) Some links I'd like to find again.
    Robot Balances on Ball
    Sea Water Antenna
    Dead Reckoning Robot
    Light Field Display
    SLAM
    Arduino IMU Code
    LED Sensors
    High Altitude Balloon Transmitter
    (4/13/13)LMR Posting Suggestions
    Place Holder
    Nice list, DD!
    Esp. "things erco made me buy"...
    An ounce of testing is worth a pound of speculation.
    Quote Originally Posted by erco View Post
    Nice list, DD!
    I know that list is woefully incomplete.
    I'm hoping if I made an "erco deals I resisted" list, it would be longer than the "buy" list, but I'm not so sure it would be.
  1. Wireless index
    By dandreae in forum Wireless
    Last Post: 04-09-2012, 02:13 AM
  2. Thread Index
    By Mike Huselton in forum Propeller 1 Multicore
    Last Post: 03-23-2010, 02:45 PM
  3. Replies: 5
    Last Post: 11-05-2009, 05:12 AM
  4. SX/B -- Arrays and Bit-Index
    By PJ Allen in forum SX Chips and Programming Tools
    Last Post: 12-19-2006, 02:53 AM
  5. Thread index
    By Newzed in forum General Discussion
    Last Post: 09-02-2006, 10:22 PM
