Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Autonomous robot's navigation
    Default Autonomous robot's navigation
    Hello,
    Now I work at associative video memory. The method still in developing (now it version 0.5)
    but it gives good results already today.
    I am dealing with research of computer vision in parallel with my main job
    at "Impulse" more than three years (it is my hobby).
    About me
    In the beginning my achievements were insignificant and little part of ideas has worked properly.
    But I did not surrender. I generated big quantity of hypotheses and then test it.
    The most ideas did not work indeed but those that worked were similar to particles of gold
    in huge quantity of dross. My associative video memory method is working indeed.
    ============================- Common information -==========================
    Algorithm AVM uses a principle of multilevel decomposition of recognition matrices,
    it is steady against noise of the camera and well scaled, simply and quickly
    for training, also it shows acceptable quick-action on a greater image resolution
    of entrance video (960x720 and more). The algorithm works with grayscale images.
    The detailed information about AVM algorithm can be looked here:
    Associative video memory
    AVM SDK v0.5 with examples of using and tests for comparison
    of characteristics of the previous and new versions:
    http://edv-detail.narod.ru/AVM_SDK_v0-5.zip
    Demonstration video how to train AVM:
    http://edv-detail.narod.ru/Face_training_demo.avi
    AVM demo with the user interface (GUI), installation for Windows:
    http://edv-detail.narod.ru/Recognition.zip
    Connect the web-camera and start AVM demo after installation of "Recognition.exe".
    After starting the program will inform that there is not stored previously data
    of training AVM and then will propose to establish the key size of the image
    for creation of new copy AVM. Further train AVM using as an example Face_training_demo.avi.
    ========================- Robot's navigation -=========================
    I also want to introduce my first experience in robot's navigation powered by AVM.
    Briefly, the navigation algorithm do attempts to align position of a tower
    and the body of robot on the center of the first recognized object in the list
    of tracking and if the object is far will come nearer and if it is too close it
    will be rolled away back.
    See video below:
    YouTube - Robot's navigation by computer vision (AVM algorithm), experiment 1
    YouTube - Robot's navigation by computer vision (AVM algorithm), experiment 2
    I have made changes in algorithm of the robot's control
    also I have used low resolution of entrance images 320x240 pixels.
    And it gave good result (see "Follow me"):
    YouTube - Follow me (www.edv-detail.narod.ru)
    Robot navigation by gate from point "A" to "B"
    See video below:
    YouTube - Navigation by gates (www.edv-detail.narod.ru)
    First an user must set the visual beacons (gates) that will show direction where robot has to go.
    Robot will walk from gate to gate. If the robot recognize "target" then he come nearer and stop walking.
    Navigation application (installation for Windows):
    Navigator package description
    The package consists of three parts: the robot control driver, the pattern recognition application (GUI), and a dynamic link library "Navigator".
    Compilation of pattern recognition application will need wxWidgets-2.8.x and OpenCV_1.0. If someone has no desire to deal with the GUI, then the project already has compiled recognizer (as EXE) and you will be enough to compile Navigator.dll, which contains the navigation algorithm. Compilation of Navigator.dll needed only library OpenCV_1.0. You can build project by compiler Microsoft Visual C ++ 6.0 (folder vc6.prj) and by compiler Microsoft Visual Studio 2008 (folder vc9.prj).
    After installation (and compilation) libraries wxWidgets-2.8.x and OpenCV_1.0 need to specify additional folders for the compiler:
    Options / Directories / Include files:
    <Install_Dir> \ OPENCV \ CV \ INCLUDE
    <Install_Dir> \ OPENCV \ CVAUX \ INCLUDE
    <Install_Dir> \ OPENCV \ CXCORE \ INCLUDE
    <Install_Dir> \ OPENCV \ OTHERLIBS \ HIGHGUI
    <Install_Dir> \ OPENCV \ OTHERLIBS \ CVCAM \ INCLUDE
    <Install_Dir> \ WXWIDGETS-2.8.10 \ LIB
    <Install_Dir> \ WXWIDGETS-2.8.10 \ LIB \ VC_LIB \ MSW
    <Install_Dir> \ WXWIDGETS-2.8.10 \ LIB \ VC_LIB \ MSWD
    <Install_Dir> \ WXWIDGETS-2.8.10 \ INCLUDE
    <Install_Dir> \ WXWIDGETS-2.8.10 \ INCLUDE \ MSVC
    Options / Directories / Library files:
    <Install_Dir> \ OPENCV \ LIB
    Source code of the "Navigator" (for English community) can be downloaded here:
    edv-detail.narod.ru/Navigator_src_en.zip
    For compilation of the source code you can use the "MS Visual C ++ 2008 Express Edition". It is all official and free.
    For connection of robot to Navigator program you have to adapt the control driver (.\src\RobotController) to your robot.
    It's simple: the application Recognition.exe interacts with the robot driver "through shared memory (gpKeyArray). And all you need to do - it is a timer (method CMainWnd:: OnTimer) to send commands from the "gpKeyArray" to your robot.
    The chain of start commands will be transmitted to robot for "power on" (cmFIRE, cmPOWER) when you start navigation mode. Respectively command "power off" (cmPOWER) will be transmitted when navigation mode will be disabled.
    And most importantly: the commands cmLEFT and cmRIGHT should not activate motion in itself but only in combination with the commands "forward", "back" (cmFORWARD, cmBACKWARDS).
    If you have adapted control driver to your robot then you are ready join to navigation experiments.
    So, let's have a fun together :)
    Congratulations, very impressive videos! I'll have to take some time and watch all of your many Youtube videos. Your work is much more advanced than mine and most typical forum posts, and you will definitely cause some excitement here with your amazing achievements. What hardware are you using? Da svidanye and S'Rozhdestvóm Khristóvym!
    As the robot I used radio-controlled model of the tank, preliminary adapted to computer control (but description in Russian).
    Video was captured by USB TV Tuner from radio camera that was installed on robot body.
    Navigation program has worked on PC with Intel Core 2 duo E6600 processor.
    For more information (news) see also: forums.trossenrobotics.com/showthread.php?t=3510&page=2
    I made more convenient implementation of algorithm AVM for C# and also I prepared detailed documentation "Library AVM SDK simple.NET".
    Just print file .\AVM_SDK_simple.net\bin\Go.png and show it against camera for recognition in example 2.
    Default Re: Autonomous robot's navigation
    RoboRealm company begins distribution of "Navigator" plugin within RoboRealm software.
    Yeremeyev: Are you the "third party" who developed the AVM Navigator module? Congratulations! I must learn more about it.
    Eric
    Thanks Eric!
    The Navigator plugin ("third party") is my developing and I made it specially for using within RoboRealm software.
    Now AVM Navigator v0.7 is released and you can download it from RoboRealm website.
    In new version is added two modes: "Marker mode" and "Navigate by map".
    Marker mode
    Marker mode provides a forming of navigation map that will be made automatically by space marking. You just should manually lead the robot along some path and repeat it several times for good map detailing.
    Navigation by map
    In this mode you should point the target position at the navigation map and further the robot plans the path (maze solving) from current location to the target position (big green circle) and then robot begins automatically walking to the target position.
    For external control of "Navigate by map" mode is added new module variables:
    NV_LOCATION_X - current location X coordinate;
    NV_LOCATION_Y - current location Y coordinate;
    NV_LOCATION_ANGLE - horizontal angle of robot in current location (in radians);
    Target position at the navigation map
    NV_IN_TRG_POS_X - target position X coordinate;
    NV_IN_TRG_POS_Y - target position Y coordinate;
    NV_IN_SUBMIT_POS - submitting of target position (value should be set 0 -> 1 for action).
    Examples
    Quake 3 Odometry Test
    Navigation by map
    Visual Landmark Navigation
    AVM Navigator v0.7.3 is released!
    Navigator package is updated now and you can download next modification of AVM Navigator v0.7.3 from your account link.
    Changes:
    - The new "Back to checkpoint" algorithm was added in "Navigation by map" mode.
    http://www.youtube.com/watch?v=wj-FKhdaU5A
    - Also new "Watching mode" was developed.
    And robot can move to direction where motion was noticed in this mode.
    http://www.youtube.com/watch?v=c1aAcOS6cAg
    Also common usability was improved.
    By the way I received new video from user that succeed in "Navigation by map":
    http://www.youtube.com/watch?v=214MwcHMsTQ
    His robot video and photo:
    http://www.youtube.com/watch?v=S7QRDSfQRps
    http://roboforum.ru/download/file.ph...2484&mode=view
    http://roboforum.ru/download/file.ph...2280&mode=view
    http://roboforum.ru/download/file.ph...2281&mode=view
    I believe that you also will have success with visual navigation by AVM Navigator module ;-)
    Yet another video from user whose robot has extremely high turn speed but AVM Navigator module could control robot navigation even in this bad condition!
    http://www.youtube.com/watch?v=G7SB_jKAcyE
    His robot video:
    http://www.youtube.com/watch?v=FJCrLz08DaQ
    It is a testing of new robot for AVM Navigator project:
    http://www.youtube.com/watch?v=F3u0rTNBCuA
    Beautiful job! Amazing robot navigation.
    BTW, your robot's voltage display reminded me to update an old thread I started: http://forums.parallax.com/showthrea...=1#post1071744
    Neat project. I have a fascination with machine vision systems. I've only done simple stuff though, nothing this fancy.
    Here is complete solution of object tracking.
    I tested it on the prototype of “Twinky rover” and it works fine:
    I also added “Learn from motion” option to “Object recognition” mode and you should download RoboRealm package
    with new AVM Navigator v0.7.4.
    >> Hi, how do I update AVM Navigator? I purchased it last version.
    You had to receive download link after registration on RoboRealm site.
    Just use this link for downloading recent version of RoboRealm package with AVM Navigator.
    You could also start RoboRealm application and then click "Option" button and further click "Download Upgrade".
    Further you should set "Learn from motion" checkbox with "Object recognition" mode in AVM Navigator dialog window.
    Quote Originally Posted by plingboot
    I've had a 'fiddle' with AVM navigator and managed to teach it a few objects/faces, but not the first idea how to turn that into tracking commands…
    It is easy. You should just use "Object recognition mode" in AVM Navigator module.
    First clear the AVM search tree by click on button "Set key image size(New)" and further press "Yes".
    Now you can train AVM on some faces like in video below:
    When training will be done you should use variables that described below for your VBScript program:
    NV_OBJECTS_TOTAL - total number of recognized objects
    NV_ARR_OBJ_RECT_X - left-top corner X coordinate of recognized object
    NV_ARR_OBJ_RECT_Y - left-top corner Y coordinate of recognized object
    NV_ARR_OBJ_RECT_W - width of recognized object
    NV_ARR_OBJ_RECT_H - height of recognized object
    As example you can use these VBScript programs that was published in this topics:
    http://www.roborealm.com/forum/index...hread_id=3881#
    http://forums.trossenrobotics.com/sh...8865#post48865
    Okay guys
    I have some pretty videos from user that made testing of AVM Navigator on his robot and I also share it with you:
    Navigation by map:
    Follow me in “Navigate mode”:
    Watching mode:
    It is enough difficult route that was passed by robot with help AVM Navigator (route training and passing):
    Autonomous navigation view from outside:
    Twinky rover and fruit (color tracking with RoboRealm)
    You've been busy, ExDxV! Great job, so your navigation tests are all using camera and Roborealm, no sonar, is that right?
