+ Reply to Thread
Page 4 of 42 FirstFirst 1234567814 ... LastLast
Results 61 to 80 of 835
Thread: Download PropBASIC here... 00.01.14 July 27, 2011
  1. #61
    Default
    JonnyMac said...
    Here's a version of Terry's program that lets you store the lighting sequences in a DATA table (does not use program space as tables are stored in the Hub) -- this will let you define sequences using Terry's color scheme, which is FAR EASIER than the high-low mash-up strategy you started with. You simply call the PLAY subroutine with the sequence you want to use and the step timing.
    Thanks again!
    This is wayyyy cool, at least to me.
    I'm still working to understand exactly·how it all does what it does on this version, this is a lot of new ground for me, but it's coming.
    Darlene
  2. #62
    Default
    There's a hidden trick in there: When you pass a Hub variable or xDATA symbol to a subroutine or function it is passed by address, not by value. In order to read from the hub you have to use RDxxxx, in this case we use RDBYTE as the sequence is a table of bytes. The syntax for RDBYTE is RDBYTE hubaddress, value. This gets used six times (for your six RGB led groups) in PLAY checking for an end-of-sequence value ($FF) each time, and then incrementing (adding one to) the address for the next group. After all the LEDs are updated the delay value you passed is used with DELAY_MS (shell for PAUSE).
    There is a compiler trick in use, as well. You see, PropBASIC knows how to adjust outputs for a pin group, based on the location of that pin group. The [internal] code isn't difficult, nor is it trivial. For example, if you want to do this:
    Code:
    CSG6 = PURPLE
    ... the compiler actually generates the following code. I've added comments to explain what each line does
    Code:
    ' CS6 = PURPLE
                    mov         __temp1,#PURPLE                     ' copy PURPLE (%101) to __temp1
                    shl         __temp1,#15                         ' align with base pin of CS6 group
                    and         __temp1,CS6                         ' clear non-CS6 bits from __temp1
                    andn        outa,CS6                            ' clear old CS6 group outputs
                    or          outa,__temp1                        ' write new value to CS6 group outputs
    Post Edited (JonnyMac) : 1/1/2010 2:36:52 AM GMT
  3. #63
    Bean's Avatar
    Location
    Near Harrisburg PA
    Posts
    7,404
    Blog Entries
    2
    Default
    Geekgirl,
    · Yeah if you're coming from PBASIC "pin groups" are great.
    · If you need more assistance please ask. It's nice to see what forum members are "up to" with PropBASIC.
    · P.S. Jon must have downloaded my code before I fixed the color names.· ORANGE should be YELLOW, and PURPLE should be MAGENTA, and AQUA should be CYAN.
    Bean.
    Try BASIC on the Propeller.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
    Post Edited (Bean (Hitt Consulting)) : 12/31/2009 9:54:16 PM GMT
  4. #64
    Default
    A little more development on using Bean's method to talk to Spin objects from PropBASIC, running on Rayman's PSM.
    The following makes two Spin objects available on demand to the main BASIC program;
    This time there actually is some code in the BASIC program; which generates a tone, then displays version detail on the LCD.
    The object of posting this is so that newcomers like myself can have an easy example, with a low level of abstraction.
    T o n y
    Code:
    DEVICE P8X32A, XTAL1, PLL16X
    FREQ 80_000_000
    tonegenStart CON 1
    psmStart CON 2
    psmDeviceinfo CON 3
    spinCmd HUB BYTE = 0
    hub_long1 HUB LONG
    hub_long2 HUB LONG
    hub_long3 HUB LONG
    temp VAR LONG
    ASM
    OBJ
      soundmachine: "psm_tonegenerator"
      psmmachine: "psm_serialcontrol_a"
    PUB SpinStart
      CogInit(1, @__Init, @__DATASTART)
      Repeat
        case spinCmd
          tonegenStart:
            soundmachine.tonegen(hub_long1,hub_long2,hub_long3)
            spinCmd := 0
          psmStart:
            psmmachine.main
            spinCmd := 0
          psmDeviceinfo:
            psmmachine.showdeviceinfo
            spinCmd := 0
    ENDASM
    PROGRAM Start
    Start:
    'start tonegen driver
    WRLONG hub_long1, 400
    WRLONG hub_long2, 500
    WRLONG hub_long3, 3
    WRBYTE spinCmd, tonegenStart
    'wait for driver to process
    DO
      RDBYTE spinCmd, temp
    LOOP UNTIL temp = 0
    'start psm driver
    WRBYTE spinCmd, psmStart
    DO
    LOOP UNTIL temp = 0
    'start deviceinfo driver
    WRBYTE spinCmd, psmDeviceinfo
    DO
    LOOP UNTIL temp = 0
    END
    Post Edited By Moderator (Bean (Hitt Consulting)) : 1/1/2010 12:55:35 AM GMT
  5. #65
    Bean's Avatar
    Location
    Near Harrisburg PA
    Posts
    7,404
    Blog Entries
    2
    Default
    Tony,
    · If you put your code inside the "Formatted Code" area (the # icon), it will keep the spacing.
    Bean
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134·
  6. #66
    Default
    Here's another demo using the tone generator. Note that the psm_tonegenerator object hard-codes the output pins so you may need to change this (as I did) if you're using the Propeller Demo Board (I may *liberate* this code to create my own version that can pass pins and be stopped while playing).
    This demo plays three tones and then goes into a random loop -- somewhat reminiscent of old sci-fi computer sounds.
    Post Edited (JonnyMac) : 1/1/2010 1:18:15 AM GMT
    Attached Files Attached Files
  7. #67
    Default
    JonnyMac,
    Thanks for the wonderful tonegenerator example!
    It's running in the background, playing music while I'm studying the code.
    It's 0130 here, back to some nightwork after the party.
    T o n y
  8. #68
    Default
    That is what I like about this forum. IT ROCKS!
    JMH
  9. #69
    Bean's Avatar
    Location
    Near Harrisburg PA
    Posts
    7,404
    Blog Entries
    2
    Default
    I have posted version 00.00.53.
    Along with a couple of bug fixes, PropBASIC now supports inline strings.
    Inline strings can be used anywhere a DATA label can be used.
    NOTE: Inline strings are Z-strings, so the compiler will automatically add a zero·to the end of them as a "end of string" indicator byte.
    Here is a demo showing inline strings:
    Code:
    FREQ   80_000_000
    Baud   CON "T115200"
    TX     PIN 30 HIGH
    temp   VAR     Long
    SendChar  SUB 1
    SendStr   SUB 1
    Message DATA "GoodBye", 0
    PROGRAM Start
    Start:
      GETADDR "Testing 1,2,3", temp
      SendStr temp
      PAUSE 1000
      SendStr "Hello"
      PAUSE 1000
      SendStr Message
      PAUSE 1000
      GOTO Start
    END
    SUB SendChar
      SEROUT TX, Baud, __param1
    ENDSUB
    SUB SendStr
      __param2 = __param1 ' SendChar uses __param1
      DO
        RDBYTE __param2, __param3
        IF __param3 = 0 THEN EXIT
        SendChar __param3
        INC __param2
      LOOP
      SendChar 13
    ENDSUB
    Bean.
    Use BASIC on the Propeller with the speed of assembly language.
    Post Edited (Bean (Hitt Consulting)) : 1/2/2010 3:25:57 PM GMT
  10. #70
    Bean's Avatar
    Location
    Near Harrisburg PA
    Posts
    7,404
    Blog Entries
    2
    Default
    Coley found a bug in "var = const * [power of 2]" and "var = const / [power of 2]".
    The bug has been fixed in version 00.00.54 in the first post in this thread.
    Bean
  11. #71
    Bean's Avatar
    Location
    Near Harrisburg PA
    Posts
    7,404
    Blog Entries
    2
    Default
    Jon found a bug when using serial open baud modes.
    I have fixed it and posted version 00.00.55 in the first post.
    Bean.
  12. #72
    Default
    PropBASIC/FUNC question:
    Hi all,
    May I tempt you with the following easy question?
    The following compiles nicely; but how do I do the three steps in one?
    Code:
    FUNC GetToneNumberSteps
      Temp1=Duration*clkfreq
      Temp1=Temp1/1000
      ToneNumberSteps=Temp1/200
      RETURN ToneNumberSteps
    ENDFUNC
  13. #73
    Bean's Avatar
    Location
    Near Harrisburg PA
    Posts
    7,404
    Blog Entries
    2
    Default
    Assuming you don't need the temp1 value you can do:
    · ToneNumberSteps·= Duration * clkfreq
    · ToneNumberSteps = ToneNumberSteps / 200_000
    Bean
    TonyWaite said...
    Hi all,
    Code:
      Temp1=Temp1/1000
    ENDFUNC
  14. #74
    Default
    TonyWaite said...
    Hi all,
    Code:
      Temp1=Temp1/1000
    ENDFUNC
    You need to be careful with duration -- if it goes more than 25 or so then you could get a rollover problem (from positive to negative) with the values. Since the *typical* clkfreq setting of a Propeller project is 80MHz and you have a constant value of 1000 you could boil the division down to 80_000, like this:
    Code:
      __param1 = __param1 * 80_000
      __param1 = __param1 / 200
      ENDFUNC
    The duration is passed in __param1 and we don't need to use RETURN (just consumes a line of precious code space) because functions use __paramx variables to send values back to the caller.
  15. #75
    Default
    Whoops, now that I look at it, the function can be even simpler given a clkfreq of 80MHz
    Code:
      __param1 = __param1 * 400
      ENDFUNC
    If you need to accommodate clkfreq I think you can simplify to:
    Code:
      __param2 = clkfreq / 200_000
      __param1 = __param1 * __param2
      ENDFUNC
    Post Edited (JonnyMac) : 1/3/2010 9:28:31 PM GMT
  16. #76
    Default
    Bean & JonnyMac: many thanks!
    Now to improve my code ...
  17. #77
    Default
    /Continued
    (Project is to attempt re-write of Rayman's PSM_ToneGenerator in PropBASIC)
    I've tried to work in the FUNC calls; the following gets past the compiler - which is encouraging.
    I'm uncertain whether I've used the __paramx variables correctly to get information in and out of the FUNC.
    My progress certainly improved when my blurry eyesight spotted the 'double-underscore' typography!
    Thank you, T o n y
    Code:
    XIN                5_000_000
    ToneNumberSteps       VAR LONG
    ToneLeftPhaseStep     VAR LONG
    ToneRightPhaseStep    VAR LONG
    ToneLeftAttenuation   VAR LONG
    ToneRightAttenuation  VAR LONG
    ToneLeftPin           VAR LONG
    ToneRightPin          VAR LONG
    ToneRunning           VAR LONG
    Frequency             VAR LONG
    Duration              VAR LONG
    LeftFrequency         VAR LONG
    RightFrequency        VAR LONG
    Tonegen               SUB  3,5
    GetToneNumberSteps    FUNC 1
    GetTonePhaseStep      FUNC 1
    PROGRAM               Start
    Start:
      DO
        Tonegen(400,500,3)                      'outputs test-tone of 400Hz, 500mS, attenuation level 3
        PAUSE 3000
      LOOP
    END
      ' use duration as __param1
      'return of __param1 required
      RETURN __param1
      ENDFUNC
    FUNC GetTonePhaseStep
      ' use Frequency as __param1
      __param2 = 1 << 15
      __param1 = __param1 / __param2
      __param2 = 1 << 13
      __param2 = 1 << 4
      __param1 / __param1 * __param2
      'return of _param1 required
      RETURN __param1
      ENDFUNC
    SUB Tonegen (frequency,duration,attenuation)ŠLeftFrequency,RightFrequency)
      ToneLeftPin=5
      ToneRightPin=4
      LeftFrequency=Frequency
      RightFrequency=Frequency
      ToneNumberSteps=GetToneNumberSteps Duration
      ToneLeftPhaseStep=GetTonePhaseStep LeftFrequency
      ToneRightPhaseStep=GetTonePhaseStep RightFrequency
      ToneLeftAttenuation=Attenuation
      ToneRightAttenuation=Attenuation
      ToneRunning=true
      'COGSTART ......assembly stuff to come here with DAT etc to follow
    ENDSUB
  18. #78
    Default
    Out of curiosity, what's the rationale behind using cogstart instead of cognew and swapping the parameters for RDxxx/WRxxx (compared to their PASM equivalents)? Regarding the latter, not that I mind that much but people starting with BASIC and going for PASM later might find this confusing.
  19. #79
    Default
    The idea behind PropBASIC is to help those coming from PBASIC make the transition, hence the RDxxxx and WRxxxx more closely match READ and WRITE from PBASIC (and SX/B) where the address is the first parameter. Mind you, that's a guess on my part -- I do docs, but didn't design the compiler.
  20. #80
    Default
    JonnyMac said...
    Fair enough, not having used PBASIC I didn't/couldn't make that connection but that sounds reasonable :)
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
