+ Reply to Thread
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 91
Thread: GPS Datalogger (Using Google Earth)
  1. #41
    Default Re: GPS Datalogger (Using Google Earth)
    [QUOTE=Ragtop;1040224]I did a Google Earth data logger with the propeller. It is amazing what you can do with KML. Here I have it move a 3d model along the path I took.
    Can you post your propeller code? or email it to me (briancarter@chipsofttech.com). TY!
  2. #42
    I'm looking to do a local hack-a-thon using the GPS Datalogger. I noticed the kit uses a serial board. Would post/send me your latest code? Also, you said the basicp stamp would be better. Would you spec out the parts I'd need for a USB kit using basicp? Thanks! Brian Carter (briancarter@chipsofttech.com)
  3. #43
    [QUOTE=briancarter;1040378]
    Quote Originally Posted by Ragtop View Post
    I am afraid it is not very well documented, but here it is.
    Code:
    CON
      _CLKMODE = XTAL1 + PLL16X
      _XINFREQ = 5_000_000
    obj
       sdcard: "fsrw"
       gps   : "GPS_Float"
       FS    : "FloatString"
    var
       long latold, latnew, longold, longnew, distance
       long x, filenum, open, oldelevation, newelevation
       long Stack[32], carpressed, bikepressed, hikepressed, firstloopcheck
       long model
       long year, month, day, hour, minute, second, endhour,endminute,endsecond
       long count 'for counting every 8th icon to fly map over to new position
       long Elcheck,rtcheck 'elevation and rotation changes
    pub main                               '900 coordinate updates an hour / every 4 seconds
           sdcard.mount(1)    ' 1 cog
           gps.init             ' 4 cogs
           initButtons         ' 1 cog
           dira[7]~~         'card writing LED indicator
           outa[7] := 0
           dira[6]~~         'sat fix LED indicator
           outa[6] := 0
           filenum := 1
           open := 0
           model := 0
           carpressed := 0
           bikepressed := 0
           hikepressed := 0
           main2
    Pub main2
           firstloopcheck := 0
           repeat
              repeat while carpressed == 0 and bikepressed == 0 and hikepressed == 0  'just wait until button pressed first time
                CheckSatFix
              ShortBlink
              if open == 1       'if file open and button pressed, close file.
                 Endfile
                 firstloopcheck := 0
                 carpressed := 0
                 bikepressed := 0
                 hikepressed := 0
              else
                 distance := 0   'start new file using filenum to increment filenames
                 if carpressed == 1
                    model := 1
                 if bikepressed == 1
                    model := 2
                 if hikepressed == 1
                    model := 3
                 carpressed := 0
                 bikepressed := 0
                 hikepressed := 0
                 Openfile
    Pub Openfile
              case filenum
                 1:   sdcard.popen(string("track1.kml"),"w")
                 2:   sdcard.popen(string("track2.kml"),"w")
                 3:   sdcard.popen(string("track3.kml"),"w")
                 4:   sdcard.popen(string("track4.kml"),"w")
                 5:   sdcard.popen(string("track5.kml"),"w")
                 6:   sdcard.popen(string("track6.kml"),"w")
                 7:   sdcard.popen(string("track7.kml"),"w")
                 8:   sdcard.popen(string("track8.kml"),"w")
                 9:   sdcard.popen(string("track9.kml"),"w")
                 10:  sdcard.popen(string("track10.kml"),"w")
              'term1
              WriteFileHeader
              filenum++
              open := 1
              count := 1
              WriteIcons
    Pub EndFile
            Shortblink
            'CheckSatFix
            TakeReading
            sdcard.SDStr(string("<Placemark>",13,10))
            'TimeStamp
            sdcard.SDStr(string("<name>Finished. Distance traveled is "))
            sdcard.sddec(distance)
            sdcard.SDStr(string(" ft "))
            sdcard.sdstr(fs.floattostring(gps.miles))
            sdcard.SDStr(string(" miles </name>",13,10))
            elcheck := gps.ElevationCheck
            rtcheck := gps.rotation
            WriteModel
            sdcard.SDStr(string("</Placemark>",13,10))
            sdcard.SDStr(string(" </Document>",13,10))
            sdcard.SDStr(string("</kml>",13,10))
            sdcard.pclose
            LongBlink
            open := 0
    PUB InitButtons
       cognew(button(@carpressed,@bikepressed,@hikepressed), @stack)
    Pub button(cp,bp,hp)             'three buttons to start hike, bike, or car track
       dira[8]~   'car
       dira[11]~   'bike
       dira[10]~  'hike
       long[cp] := 0        'car press
       long[bp] := 0        'bike press
       long[hp] := 0        'hike press
       repeat
         if ina[8] == 1       'stores a button press until an action is done in main program to remove timing issues.
            long[cp] := 1
         if ina[11] == 1
            long[bp] := 1
         if ina[10] == 1
            long[hp] := 1
    Pub CheckSatFix
        repeat while gps.Long_Fix_Quality < 1 or gps.Long_Fix_Quality > 8
           FixIndicatoroff
           if open == 1
              if carpressed == 1 or bikepressed == 1  or hikepressed == 1
                 endfile
                 main2
        FixIndicatorOn
    Pub FixIndicatorOn
        outa[6] := 1
    Pub FixIndicatorOff
        outa[6] := 0
    Pub WriteFileHeader
                sdcard.SDStr(string("<?xml version='1.0' encoding='UTF-8'?>",13,10))
                sdcard.SDStr(string("<kml xmlns='http://www.opengis.net/kml/2.2'",13,10))
                sdcard.SDStr(string("xmlns:gx='http://www.google.com/kml/ext/2.2'>",13,10))
                'sdcard.SDStr(string("<Feature id='Ragtops path'>",13,10))
                sdcard.SDStr(string("  <Document>",13,10))
                sdcard.SDStr(string("<description>This is track #"))
                sdcard.SDDec(filenum)
                sdcard.SDStr(string(" that was started on "))
                sdcard.sddec(gps.Long_Month)
                sdcard.SDStr(string("/"))
                sdcard.sddec(gps.Long_Day)
                sdcard.sddec(gps.Long_year)
                sdcard.SDStr(string("</description>",13,10))
                TakeReading
                'TimeStamp
                sdcard.SDStr(string("<name>Start</name>",13,10))
                WriteModel
                firstloopcheck := 1
    PUB WriteModel
       case model
           1:  sdcard.SDStr(string("<Model id='car'>",13,10))
           2:  sdcard.SDStr(string("<Model id='bike'>",13,10))
           3:  sdcard.SDStr(string("<Model id='hike'>",13,10))
       TimeStamp
       sdcard.SDStr(string("<altitudeMode>relativeToGround</altitudeMode>",13,10))
       sdcard.SDStr(string("<Location>",13,10))
       sdcard.SDStr(string("<longitude>"))
       sdcard.sdstr(fs.floattostring(longnew))
       sdcard.SDStr(string("</longitude>",13,10))
       sdcard.SDStr(string("<latitude>"))
       sdcard.sdstr(fs.floattostring(latnew))
       sdcard.SDStr(string("</latitude>",13,10))
       sdcard.SDStr(string("<altitude>0</altitude>",13,10))
       sdcard.SDStr(string("</Location>",13,10))
       sdcard.SDStr(string("<Orientation>",13,10))
       if model == 2
              case rtcheck
                         1:  sdcard.SDStr(string("<heading>270</heading>",13,10))               'north
                         2:  sdcard.SDStr(string("<heading>315</heading>",13,10))             'north east
                         3:  sdcard.SDStr(string("<heading>0</heading>",13,10))  'east
                         4:  sdcard.SDStr(string("<heading>45</heading>",13,10)) 'southeast
                         5:  sdcard.SDStr(string("<heading>90</heading>",13,10))   'south
                         6:  sdcard.SDStr(string("<heading>135</heading>",13,10))   ' southwest
                         7:  sdcard.SDStr(string("<heading>180</heading>",13,10))    'west
                         8:  sdcard.SDStr(string("<heading>225</heading>",13,10))   'northwest
       else
              case rtcheck
                         1:  sdcard.SDStr(string("<heading>180</heading>",13,10))               'north
                         2:  sdcard.SDStr(string("<heading>225</heading>",13,10))             'north east
                         3:  sdcard.SDStr(string("<heading>270</heading>",13,10))  'east
                         4:  sdcard.SDStr(string("<heading>315</heading>",13,10)) 'southeast
                         5:  sdcard.SDStr(string("<heading>0</heading>",13,10))   'south
                         6:  sdcard.SDStr(string("<heading>45</heading>",13,10))   ' southwest
                         7:  sdcard.SDStr(string("<heading>90</heading>",13,10))    'west
                         8:  sdcard.SDStr(string("<heading>135</heading>",13,10))   'northwest
       sdcard.SDStr(string("<tilt>0</tilt>",13,10))
       sdcard.SDStr(string("<roll>0</roll>",13,10))
       sdcard.SDStr(string("</Orientation>",13,10))
       sdcard.SDStr(string("<Scale>",13,10))
       sdcard.SDStr(string("<x>1</x>",13,10))
       sdcard.SDStr(string("<y>1</y>",13,10))
       sdcard.SDStr(string("<z>1</z>",13,10))
       sdcard.SDStr(string("</Scale>",13,10))
       sdcard.SDStr(string("<Link>",13,10))
       case model
         1:  sdcard.SDStr(string("<href>car.dae</href> ",13,10))
         2:  sdcard.SDStr(string("<href>bike.dae</href> ",13,10))
         3:  sdcard.SDStr(string("<href>hike.dae</href> ",13,10))
       sdcard.SDStr(string("</Link>",13,10))
       sdcard.SDStr(string("</Model>",13,10))
    Pub WriteIcons
                    Shortblink
                    CheckSatFix
                    TakeReading
                    count++
                    sdcard.SDStr(string("<name>"))
                    'sdcard.sddec(gps.Long_Hour)
                    'sdcard.SDStr(string(":"))
                    'sdcard.sddec(gps.Long_minute)
                    {sdcard.SDStr(string(" *E* "))
                    sdcard.SDDec(Elcheck)
                    sdcard.SDStr(string(" *R* "))
                    sdcard.SDDec(rtcheck)}
                    sdcard.SDStr(string("</name>",13,10))
                    ' check for being stopped.  only want one icon, so need to check if still stopped.
                    WriteModel
                    TimeStamp
                   waitcnt (clkfreq * 4 + cnt)
    Pub ShortBlink
           repeat 8
              !outa[7]
              waitcnt(9000_000 + cnt)
    Pub LongBlink
          outa[7] := 1
          waitcnt(clkfreq * 4 + cnt)
          outa[7] := 0
    Pub RecordOn
        outa[7] := 1
    Pub RecordOff
        outa[7] := 0
    PUB TakeReading
        CheckSatFix
        longold := longnew
        latold := latnew
        longnew := gps.Float_Longitude_Deg
        latnew :=  gps.Float_Latitude_Deg
        if firstloopcheck <> 0
            gps.distance(latold,longold,latnew,longnew)
            distance := gps.final
    Pub TimeStamp
         sdcard.SDStr(string("<TimeSpan>",13,10))
         sdcard.SDStr(string("<begin>"))
         year:=gps.Long_year
         month:=gps.long_month
         day:=gps.long_day
         hour:=gps.long_hour - 4
         minute:=gps.long_minute
         second:=gps.long_second
         sdcard.SDStr(string("-"))
         if month < 10
            sdcard.SDStr(string("0"))
            sdcard.sddec(month)
         else
            sdcard.sddec(month)
         if day < 10
            sdcard.sddec(day)
         else
            sdcard.sddec(day)
         sdcard.SDStr(string("T"))
         if hour < 10
            sdcard.sddec(hour)
         else
            sdcard.sddec(hour)
         if minute < 10
            sdcard.sddec(minute)
         else
         if second < 10
            sdcard.sddec(second)
         else
         sdcard.SDStr(string("Z</begin>"))
         sdcard.SDStr(string("<end>"))
         CalculateEndTime
         if month < 10
            sdcard.sddec(month)
         else
            sdcard.sddec(month)
         if day < 10
            sdcard.sddec(day)
         else
            sdcard.sddec(day)
         if endhour < 10
            sdcard.sddec(endhour)
         else
         if endminute < 10
            sdcard.sddec(endminute)
         else
         if endsecond < 10
            sdcard.sddec(endsecond)
         else
         sdcard.SDStr(string("Z</end>"))
         sdcard.SDStr(string("</TimeSpan>",13,10))
    Pub CalculateEndTime
         if (second + 10) > 60
             if (minute + 1) > 60
                endhour := hour + 1
                endminute := 0
                endsecond := (second + 10) - 60
             else
                endhour := hour
                endminute := minute + 1
         else
           endhour := hour
           endminute := minute
           endsecond := second + 10
  4. #44
    Hi all!
    As a regatta sailor, I would like to log NMEA data for later analysis to improve my performance, but I have a few questions.
    For this I would like to put together the GPS data logger kit (Item code 910-27937) form its components without the GPS module, as I would like to input NMEA data form my electronic navigation NMEA network. As I don’t have a serial connection on my computer I plan to add the RS232-USB connector (Item code 28031) to the set.
    The TackTick-network on my boat (Garmin GPS and a TackTick windmeter) has a standard NMEA (0183 V2.30) output. Received Sentences: DBT, DPT, GLL, HDG, HDM, MTW, MWV, RMB, RMC, VHW, VLW, VWR. Transmitted Sentences: DPT, GLL, HDG, MTW, MWV, RMB, RMC, VHW, VLW, VWR. The idea is to log timestamp, wind angle and speed, boat speed and course. The GPS also produces a log containing position, speed, course.
    I have not been able to log the output yet (no RS232 on my computers), so I’m not sure of the order of the sentences.
    As the system produces output approximately every second, I think of averaging 10 points which will also stabilize the numbers.
    Possibly I would like to add a live display in a later stage presenting deviation from previous average course to alert for tactical opportunities.
    The questions I have:
    1. Is it possible to add the RS232-USB connector to this kit
    2. Can I connect the Tacktick NMEA output straight to the logger input where the GPS module input originally is (and read its outputJ)?
    3. What Basic Stamp would I need for this task? Bigger leaves more options open, but consumes more power from the battery
    4. Would Chris Savages GPS Datalogger software be a good start for software?
    Although I’m new to the Parallax products, and only have basic experience in programming, I have help from my son who did a Boe-Bot school project recently.
    Thanks for your input and ideas.
    Eric
  5. #45
    It sounds like the boat system will output the NMEA strings out over RS232?
    1. You can use the Parallax RS232-USB converter only if you want to read the NMEA signals on a PC (via a USB port). It won't work to hook it up to a microcontroller.
    2. I would use one of these (or similar): http://www.pololu.com/catalog/product/126. You should be able to connect the RX line where the GPS line is on the kit sample code, and it will run the same.
    3. I would use one of the faster BS2s just to make sure that you have time to do everything that needs to be done. It would also depend on the baud rate of the NMEA system on your boat. IIRC correctly the BS2 can only go up to 9600 baud. I would use a BS2px. It only draws 55mA, or .275 watts.
    4. You can use the datalogger routines in that code, but you'll need to replace the GPS routines (he used the "smart" mode of the Parallax GPS, not NMEA). If you look around the web I'm sure that there are BS2 routines to read NMEA data.
  6. #46
    Parallax Engineering
    Chris Savage's Avatar
    Location
    Rocklin, CA
    Posts
    12,819
    Blog Entries
    8
    Lightbulb Re: GPS Datalogger (Using Google Earth)
    Quote Originally Posted by SailingEric View Post
    Eric
    1. The #28031 adapter you mentioned would work just fine for connecting the Super Carrier Board via USB.
    2. Yes, you can connect your GPS output to the BASIC Stamp Module, but not directly. You will need a 22K resistor and you will need to invert the baud mode used.
    3. The BS2p series all have a provision for capturing the serial data into SPRAM where it can be parsed to extract the fields you need, such as Latitude and Longitude. If needed I can provide a separate program which shows how to use the BS2p to read GPS data.
    4. Once the changes are made for the RS-232 into the datalogger (inverted via 22K resistor) and you have a BS2p with the modified software you could certainly save time on development by using this program as a base. As a note, I will be putting up the original datalogger project soon which did use a BS2p and a standard GPS module and also had more features.
    Engineering Tech, Parallax Inc.
    (916) 624-8333 x3005
    Website / Twitter / Google+
  7. #47
    Thanks for your reply!
    @SLRM
    1. I need the RS232-USB connector for communication and programming with my PC
    2. It’s clear to me now that I need a RS232 to connect to the NMEA-out from the network. As far as I understand the NMEA output of a marine network would normally be connected to RS232 pin 3 and 5. The Pololu seems to be difficult to get for me in the Netherlands. Doesn’t Parallax have similar products? These I can obtain via a distributor. Also see Chris' answer on this.
    3. Thanks. You’re probably right to choose a faster stamp. Power consumption is low, but I work on board battery, so not endless…
    4. I realize the routines have to be adjusted. I presume that will become more clear when I have the first readings of the output. So far I have not been able to connect to the PC due to the RS232 requirement
    @ Chris:
    1. That helps! Then I presume this would be my shopping list?
    As in the kit, but without the GPS module
    (1) Super Carrier Board
    (1) BASIC Stamp 2 Module (BS2P?)
    (1) Memory Stick Datalogger
    (2) 10K Resistors
    (1) 220 Ohm Resistor
    (2) Tact Switch
    (1) Bi-Color LED
    Extra:
    #28031 USB-RS232 connector
    22K Resistor
    1. This 22K resistor, should it be at pin3? How do you mean: “invert Baud rate?” I tried to search the forum on this but could not get it clear yet :-( Would you have a diagram available maybe?
    2. Thanks for the offer! That would help, although I would like to try myself first….
    3. Interesting! You already mentioned this somewhere else in the forum. That would steepen my learning curve I presume
    Eric
  8. #48
    Location
    Rocklin, CA
    Posts
    12,819
    Blog Entries
    8
    Eric, the BASIC Stamp modules use TRUE or INVERTED baud mode. If you are using the resistor and feeding the RS-232 signal into the I/O pin you would use inverted baud mode (see help on SERIN for more information) rather than TRUE baud mode.
  9. #49
    Hi everyone! Im wanting to remove the buttons from the the GPS datalogger program. I removed the first button that starts the logging process and i have it starting the process after it receives a valid signal but Im wanting it to log for 5 mins then stop and write the data to the flashdrive without the aid of the second button. I attached my file if anyone can help me out it would be GREATLY APPRECIATED ! finalprogram3.bs2
  10. #50
    Location
    Rocklin, CA
    Posts
    12,819
    Blog Entries
    8
    You could access the UTC time from the GPS and use that to determine when 5 minutes have passed and then close the file. It would be pretty straight foward if you understand what the code is doing. Otherwise you might use a 555 timer or some other simple external timer to output to the pin used by the second button and detect that to stop logging. It would almost like simulating a button press.
  11. #51
    SailingEric, I'm doing similar thing with the Propeller.
    I'm logging GPS data and wind, but using a dedicated anemometer. I'm checking the possibility to interface to the tacktick NMEA unit, and it has an RS484 data output. I have yet to try it, but an RS485->serial tranceiver should do the job. The ground is common to all the circuits, and the RS485 tranceiver will keep your two instruments worlds connected in a safe way.
    I Also emailed tacktick asking questions about interfaciing their instruments with other, third party hardware, but (strangely) they didn't answer.
    Massimo
  12. #52
    Thank you Massimo!
    I've been looking for this and couldnt find it 8-$
    Where did you find this info?
    Also baud rates (which I thought I needed), and indeed Tacktick does not help a lot. I managed to get a reply, but they could only refer to the internet for information on NMEA connectivity...
    Which seems to be getting more true every week!
    You realize Tacktick has switched owner from Suunto to Raymarine? They might be very occupied with internal matters for some time.
    Why Propeller? Is it better for this job? Propeller uses different progamming than Basic Stamp? Or could I use/see your programming? I'm a newbee on this...
    I might decide to purchase a Propeller set if it makes my life much easier.
    Eric
  13. #53
    I think we are hijacking Chris's thread. Probably better starting a new discussion on "general" or "sensors"?
    We can share the infos and hopefully get there faster..
    Massimo
    edit: http://forums.parallax.com/showthrea...19#post1057019
  14. #54
    Cluso99's Avatar
    Location
    Sydney/Brisbane Australia or 'sailing on the high seas'
    Posts
    10,501
    O.T. For those interested, I have answered Massimo's thread http://forums.parallax.com/showthrea...tick-NMEA-unit where I describe what I did a few years ago with the propeller and reading the NEMA data.
    My Prop boards: CpuBlade, TriBlade, RamBlade, www.clusos.com
    Prop Tools (Index)
    Emulators (Index) ZiCog (Z80)
    Prop OS (also see Sphinx, PropDos, PropCmd)
  15. #55
    Hey I am having problems with the code. I do the gps test and it works fine then I load the data logger code and the led turns off cause it can not recognize the gps. can you help me thanks Bridger
  16. #56
    Location
    Rocklin, CA
    Posts
    12,819
    Blog Entries
    8
    Which GPS Module are you using?
  17. #57
    Quote Originally Posted by Chris Savage View Post
    I am using vpn1513 gps board. it is the blue gps board parallax sells
    sweeping mine me
  18. #58
    @ bridger
    Did you try changing the baud to 9600? It looks like the VPN module's smart mode is at 9600, not 4800 like the code has it.
    What is the RAW pin connected to?
  19. #59
    Quote Originally Posted by SRLM View Post
    @ bridger
    ok I will try that and the raw pin is at 13 like the code specified.
    sweeping mine me
  20. #60
    @ bridger
    Hey thanks I would have never thought of that. thanks for your help.
    sweeping mine me
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
