+ Reply to Thread
Page 57 of 60 FirstFirst ... 7475354555657585960 LastLast
Results 1,121 to 1,140 of 1190
Thread: ZiCog a Zilog Z80 emulator in 1 Cog
  1. #1121
    Default Re: ZiCog a Zilog Z80 emulator in 1 Cog
    Ok, this has me interested too. pullmoll moved most of the simulation into pasm, but one thing that it needed was a big hub buffer for the video. Move the display out to a touchscreen (which *can* do a 80x40 display) and you save all that hub ram. And if you drop in Kye's SD driver it works out of the box for pretty much every SD card I have tested.
    No need necessarily for a Z80 emulation. 8080 was just fine (my preferred CP/M source was Z80 opcodes but only using 8080 ones so essentially 8080 code which is much simpler than Z80, ie Zicog). And if you only use 8080 opcodes we are back to Zicog which is simpler to run.
    Keeping with the CP/M philosophy, one always rewrote the disk drivers anyway. Sorry I can't post all mine, they are custom coded for the N8VEM. Head to Peter Schorn's site as heater suggests
    I like what you are planning. A few weeks back I finally cracked the CP/M file system code. You probably have too. And it isn't what is in the official textbooks. Basically, the file table is a list of pointers to the data blocks, and if the file is too big, put in multiple file table entries with the same file name.
    If you want to check this out, download a clean CP/M 2.2 from the SIMH site, copy just one large (eg >16k) file to the "i" dsk, then examine the i.dsk file using a hex editor. There is something really satisfying about cracking a code like this. What are the chances of us mere mortals ever really understanding fat32 for instance?
    If you can crack the "fat" code, you can read and write directly to a SD card file. And that means that Wordstar can read and write a .txt file straight off an SD card. That gives you multiple free text editors for the Propeller chip.
  2. #1122
    Cluso99's Avatar
    Location
    Sydney/Brisbane Australia or 'sailing on the high seas'
    Posts
    10,395
    Drac: Yes I worked out the file system for cpm. There are a few 4/8? extents per directory entry. If there are more then another directory entry is added. The sequence number is not necessarily consecutive and this had me stumped for a while until I figured it out. Its to do with the size calcs.
    The data heater pointed to I had found, but there was a bit more info there too.
    The Fat system is not that complex. Since it seems that the BIOS handles the physical disk code, it seems that I only have to replicate the calls and pass that to spin or pasm. There are relatively few calls and provided I am correct in believing that the code to locate the segments in cpm is hidden from the user by the bios, then this should be quite simple to replace the cpm system with fat16/32. Cpm will not know about sub-directories but I don't think that matters. Later I think we could use disks to substitute for sub-directories. We would just ignore user numbers because fat does not support this.
    Now presuming there are no gotchas, then we can use cpm to do any editting we require (wordstar or vedit, etc - take your pick). We would also have supercalc and visicalc, and a database too. Basic, Pascal, etc, etc. And we can switch back and forth between the prop (pasm, spin, C, Forth, Basic or whatever) and Zicog/cpm. In fact, we can keep cpm resident to save even restarting it.
    My Prop boards: CpuBlade, TriBlade, RamBlade, www.clusos.com
    Prop Tools (Index)
    Emulators (Index) ZiCog (Z80)
    Prop OS (also see Sphinx, PropDos, PropCmd)
  3. #1123
    Quote Originally Posted by ChrisCantrell View Post
    Eventually I would like to have several CPUs ... 6809, 6502, Z80, etc. Anybody else interested in this direction? Maybe take it to a different thread?
    Thanks for reading.Attachment 91619
    Yes, I am interested in 6502... I didn't find a 6502 emulator for a Propeller, so...
    ....now I am learning SPIN/PASM by writing a vga driver. It is almost finished - it only needs some debugging (cursor code doesn't work as expected) and cleanup.... then maybe it is time to start working on 6502...
  4. #1124
    Pik33,
    A couple of years back some guys here were working on a 6502 emulator for the Prop. Last I heard they had adopted the same technique of calling multiple atomic functions from addresses squeezed into single dispatch table longs as used in Zicog. A very neat suggetion from Cluso by the way.
    I don't know what happened to that effort or how far along it got.
    Perhaps you might like to put up a 6502 emulator thread to attract their attention.
  5. #1125
    Dr A,
    An 8080 only emulation for running CP/M is a great idea as it saves having emulation code for instructions that are never used. However the CP/M used in ZiCog,from SIMH Altair, requires some Z80 ops to run the system that rebuilds CP/M. I think it is only the string operations.
    There are also some non Digital Research CP/M enhancements that require a Z80 but I'm not inclined to worry about that.
  6. #1126
    So re the bdos calls http://www.seasip.demon.co.uk/Cpm/bdos.html
    Are you thinking of replicating all the file ones? eg scroll down to function 15, file open. Replace with the fileopen used for an sd card. And return the fields as CP/M expects?
    Actually, that list might be a bit long as it includes later versions of CP/M. I'll see if I can find one specific for just CP/M 2.2 as there are only a handful of codes as I recall, and many of them map directly to fsrw/kye sd routines.
    This one is a bit easier to follow http://members.iinet.net.au/~daveb/cpm/bdosfunc.html
    Scroll down and I think for CP/M 2.2 you can stop at function 40.
    I must say, this would be a pretty cool thing to do. Did you find the source code?
  7. #1127
    Cluso99's Avatar
    Location
    Posts
    10,395
    Drac: Yes, I believe there are only a few functions to replace. It seems that if you write a new file, the BIOS takes care of adding the entries (havent checked any sources yet).
    So the program does not know the format of the directory entries. If this assumption is correct, then it will work with FAT. The 32 byte directory structure and FAT is different in FAT to CPM. Perhaps there may be some programs that do not abide by using the BIOS. If so, I guess I can trap this withing ZiCog to prevent corruption.
    If what I now believe to be so, I should be able to remap the BIOS calls directly to Kye's SD drivers. To get just the Editor programs working on the FAT structure would be a fantastic boost to out Prop OS.
    I will take a look at your links today Drac. I have some other things I must do also. Thanks.
    Prop Tools (Index)
  8. #1128
    Cluso99's Avatar
    Location
    Posts
    10,395
    Yes, just implement BDOS calls 13-40.
    Prop Tools (Index)
  9. #1129
    I tried running Turbo pascal on ramblade and ZiCog. TP uses Z80 instructions, which are not implemented in ZiCog. Attached is my first
    try, added/fixed is partial support for SBC HL,xx instruction (partial because not all flags are supported).
    I also implemented the EXAF instruction and changed tables for LD A,I, LD A,R and reverse LD I,A, LD R, A to function as NOP.
    This are needed by DDTZ (the cp/m Z80 debugger) for trace.
    Unfortunately now Turbo pascal hangs when i enter editor mode, so there is more work to be done.
    Attached Files Attached Files
  10. #1130
    I have fired up TP on a prop, but not done anything with it, but that was using a DracBlade - running Pullmoll's QZ80 - running Pullmoll's Nascom emu - running TP ...
    With the memory overheads etc with this setup it only emulates about a 2MHz Z80, where as a Ramblade should give nearer to a 4MHz one, I believe.
  11. #1131
    Jus for reference, the digital research source for cpm and other things is located here. http://www.cpm.z80.de/source.html Thought it might help since having the real cpm source, might make it easier to emulate it all. hth.
    Blind programmer, and Parallax customer (bs2, quickstart, javelin stamp, spin stamp and more)
  12. #1132
    Burek,
    Wow, nice to see someone take interest in ZiCog and welcome to the forum.
    I am traveling at the moment so cannot be of much help. I will gladly add any fixes you make to ZiCog.
    One suggestion is that there a few instruction groups that are not implemented, bit set/get and such if I remember correctly. These, along with all other not implemeted instructions should be directed to a trap handler in the ZiCog emulation. (I'm not sure if this actually true in the last releases). This way when TP crashes out you might see the instruction that is causing the problem.
    Have you run the EXZ80 program on your ZiCog version? It is a thorough instruction set test that did have a couple of failures last time I tried it. It will give clues as to where to look.
    By the way ZiCog has always used CP/M 2.2 source code from the SIMH Altair project. The BIOS and boot loader is from there as well, but has been modified.
    http://www.schorn.ch/altair.html
  13. #1133
    Ok, so now that I have my human interface board for my quickstart board, I wanted to try this cpm os for the prop.
    Unfortunately, I don't see a quick way to locate all the required bits and pieces.
    Is there a summary somewhere of what's necessary to download, and where to get them?
    I know it won't work as is, since the quickstart isn't a ramblade, but I'm not opposed to modifying code to get it to work, but I can't remember where all the pieces are, even though it was only a month or so ago that I read this entire thread *grumble*.
    So, any pointers would be great.
    Thanks.
  14. #1134
    Cluso99's Avatar
    Location
    Posts
    10,395
    softcon: My latest source is on the ramblade thread at the end and is ZiCog version 173 IIRC. The whole download (for the SD card) is on my bluemagic website IIRC www.cluso.bluemagic.biz
    There are other references in my signature. Unfortunately I never had the time to try and get Pullmolls version working on the ramblade.
    You will require external ram of some kind to get this running with any of the later forms of the code. As far as I know there were only my TriBlade and RamBlade and the various versions of DrAcula's DracBlade that had ZiCog working - plus a few who built their own various versions of our boards.
    If you need help with finding the files then just post here. I am a quite busy with family for Xmas-New Year and apart from that, am working with getting spin running on the P2 emulators. Just post here and I will reply - may take a day or 2.
    Or email me cluso at clusos dot com and I can zip the files and send them to you.
    Prop Tools (Index)
  15. #1135
    Oh, I don't have a ramblade, I had thought the latest version of the code had been written for the ram blades. I have the quickstart board, and the new human interface board for it (sound, vga, ps/2 ports for mouse and keyboard) Everything required to make a nice little stand-alone computer running cp/m. Very cool (if I can make it work) If 173 is the latest, I'll grab it and give it a shot, and see what happens.
  16. #1136
    softcon,
    Sorry for not replying earlier.
    I was planning on sifting though all the various versions of ZiCog I have and getting them into some semblance of order whilst away from home over he Christmas break. I even have a repository started for that effort on github. It's time to start thinking about the Prop II version and finishing up those last few missing Z80 instructions. I also want to make a 8080/8085 only version which will save memory space and run CP/M just as well. Now I realize I have left all my ZiCog running hardware behind with no chance to go back and fetch it before New Year. So I won't be able to do any actual development or testing.
    You will need some external RAM of some kind and and SD card to get it working. It also requires BST or HomeSpun to compile it as it makes use of #defines to select different hardware options.
    There is not much chance of an internet connection out in the forest where I am going but I'll be back on call here after the New Year if I can be of any assistance.
  17. #1137
    Cluso99's Avatar
    Location
    Posts
    10,395
    softcon: As heater and I have both said, you will require external ram of some kind (a minimum of 64KB) to store the Z80/cpm code and an SD/microSD card to do the disk storage. We have 8 x 8MB disks mapped into files under FAT16/32 for CPM2.2 execution. The ZiCog emulation will locate these disk files and use them as hard drives A-H under cpm. Most cpm programs run, but not turbo pascal because a few Z80 instructions are not emulated.
    Prop Tools (Index)
  18. #1138
    I really have to find out what's up with Turbo Pascal on ZiCog. My bet is that it is those pesky register bank exchange ops. EX and whatever.
  19. #1139
    The quickstart board already has 64K eeprom, so no problem there. I don't know how much ram it has (only 32K I think, it's not really clear from the text in the various documents, though I'm sure a quick check of the schematics for someone who can read them would answer the question pretty quickly). With the human interface board, I now have sd card abilities too, though I already had one of those anyhow.
    Only problem is: I don't actually have an sd card for the reader. Got to go to walmart and fix that.
    So, short of adding some external ram (something I want to do anyway) is it possible to run this on my current configuration?
    After I get this working, I'll need to add one of the emic2 speech modules, then see what I can do to get me a bit of screen reading support on cp/m, should prove interesting.
    Oh, and getting turbo pascal working would be fantastic. Pascal was my second language, and I still use it for quick and dirty hacks that are mostly one-time uses, so having it working on cp/m would be great too.
  20. #1140
    Cluso99's Avatar
    Location
    Posts
    10,395
    eeprom will not run fast enough for emulation for zicog. next, it needs to be ram as you might quickly ware out the eeprom. we have not tried any of the cache software afaik.
    Prop Tools (Index)
+ Reply to Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
