Page 1 of 3 123 LastLast
Results 1 to 20 of 53
Thread: Propeller with propellers
    Default Propeller with propellers
    I've been working on a quad-rotor project for a while, but the Propeller chip made my life a lot easier. Remote control in and servo output each on their own cogs is a LOT easier and more accurate than using interrupts. It's not finished yet, but I've now had my first few successful flights in my garage.
    Video:
    http://jasondorie.com/WordPress/?cat=3
    Jason
    Update: Oct 13, 2008 - Code and schematic are attached. Note that the 'H48C' in the schematic is now an MCP3208 connected to a dual-axis gyro and an accelerometer. The interface is identical.
    Post Edited (JasonDorie) : 10/16/2008 6:34:51 AM GMT
    Attached Files Attached Files
    Wow. That knocked my socks off! Amazing work.
    Hi Jason,
    Nice project and great execution!
    I have been looking at the Draganflyer, but feel it is way over priced.
    I would definitely be interested in your Propeller code and how you established the stabilization of the platform.
    Regards,
    TCIII
    If you are going to senda Robotto save the world, youbetter make sure it likes it the way it is!
    Parallax Engineering
    Chris Savage's Avatar
    Location
    Rocklin, CA
    Posts
    12,774
    Blog Entries
    8
    Jason,
    Is this indeed a finished project (As this forum is for)? Your first post indicates it is a work in progress.
    Chris Savage
    Hi Jason,
    A couple of questions:
    Are the motors outrunner brushless or what?
    The receiver appears to possibly be a Spektrum unit, possibly an AR6000 or AR6200?
    Are you running a lipo battery and if so what size?
    How long can it stay in the air?
    Have you determined what kind of payload it can handle?
    Regards,
    TCIII
    Chris,
    It's finished in the sense that it now flies and is reasonably stable. Prior to posting I hadn't read the rules on finished/unfinished, so I apologize. I will comment the full code enough that others should be able to read it, and will post the schematic and code for what you see in the video.
    It's unfinished in that I want to add self-levelling to the flight control loop, and the plan is for this to ultimately have moveable rotors (like an Osprey) and real wings, so it'll fly normally, or do VTOL. I figured the VTOL part would be the hardest, so I did that first.
    Jason
    Location
    Rocklin, CA
    Posts
    12,774
    Blog Entries
    8
    Jason,
    Okay, yes, please add schematics and code to make it complete. =) Take care.
    Chris Savage
    Tom,
    The receiver is a Spektrum AR6200, but anything should work. Motors are indeed brushless. Motors are 1050Kv, 20A max, and I'm using TowerPro 20A brushless speed controls. A pair of 3 cell, ThunderPower 2070 batteries in parallel gives it about 4.1Ah of power, and I have yet to figure out my power draw exactly. At 2 Lbs, 13 oz, it's pretty heavy with the packs loaded, but it hovers at approximately 1/2 throttle.
    I haven't figured out the flight duration, but I suspect it's around 6 minutes or so. To be fair, I'm not using the most efficient prop for this kind of flight. I think my props are 8.5x6, but if I were to go to a lower pitch with larger diameter it would be more efficient. Ultimately I want the thing to do 'plane like' flight as well as hover, so I wanted the props to balance between fast forward flight and decent hover performance. If I was going for JUST hover performance, lower KV motors and 10x4 props would probably be much better for payload capacity and flight time.
    Also, the platform is still somewhat unstable, though that's in my garage in a lot of propwash, so it might not be as bad as I think. I fly R/C helicopters, so I'm pretty good at controlling the thing. This would not be something I'd recommend for someone with no flight experience. If and when the self-levelling works it'll be easier to handle.
    Jason
    Post Edited (JasonDorie) : 10/14/2008 4:28:28 AM GMT
    Jason,
    Thanks for the info on the Propeller heliplatform.
    Regards,
    TCIII
    No problem. I've update the original post to include the full code and schematic. I flew it outside for a few minutes today, and even with a small breeze it was more stable than it was indoors. Still a little twitchy, but I'm working on it.
    Jason
    Jason,
    I am not able to view the schematic using gEDA schematic editor in Linux. Can you post it as a jpg?
    Item 2 is the wire extending from the bottom of the aircraft. Is it for stabilization or is it an antenna extension?
    Ron
    sailman58 said...
    Jason,
    Ron
    The schematic was created with EaglePCB. I'll post a JPG when I get home tonight, and the wire you mention is just the battery leads for the motors. The receiver antennas are only an inch long (there are 4 of them).
    Jason
    Jason,
    Actually I was hoping that you had a method of lengthening the 2.4 Ghz antenna. If that was the case, I was going to borrow the idea so I could use a 2.4 Ghz system on a submarine at periscope depth.
    Ron
    sailman58
    Here is a link to the Spektrum AR6200 that Jason is using: http://www.spektrumrc.com/Products/D...odID=SPMAR6200
    Regards,
    TCIII
    Thanks Tom C.I have been using a Spektrum DX-6 for a couple of years now in my surface boats, and just picked up a 6i. What I would like to do is to somehow lenghten the antenna so i could run it up a periscope and use it on the submarines too.
    Ron
    sailman58,
    I suspect that the receiver antennas are 1/4 wave given their short length. As you can see, the AR6200 uses two receivers due to the directionality of the 2.4GHz signal compared to a 72/75 MHz signal.
    If you need a longer antenna you might have to retrogress back to 72/75 MHz where the receivers use a long wire antenna that might be a 1/4 wave or even 1/2 wave.
    I am presently using a Spektrum DX6i and a BR6000 which is a nice combination for a rover robot. I am able to control the DX6i with my PC through an Endurance R/C PCTx. If I can duplicate Jason's Propeller heliplatform, I plan to buy a AR6200 to go with my DX6i.
    Just a thought.
    Regards,
    TCIII
    It's worth noting that the AR6200 (and many other Spektrum receivers) use multiple receiver modules and choose the best signal among them. The connector for the 'outrigger' is 3 wires, presumably power, ground, and signal. You could probably extend the lines to the 2nd receiver and put the whole thing, antennas and all, into the head of a periscope (if it was large enough). You could remove the case to cut the size down a little.
    I'm considering hooking it up to a scope to see ifI can figure out what the protocol is. It'd be nice to havean I2C or SPI receiver instead of having to interpret pulse widths. :)
    Jason
    Jason - Your project is way cool. I have wanted to building something like this for some time, way to go!
    I checked out your web site with the blog and videos. Might I recommend adding the videos to YouTube? They would be easier to watch and others can learn about your cool project.
    Certainly keep us posted on your project.
    Timothy D. Swieter, E.I.
    www.brilldea.com- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
    www.sxmicro.com - a blogexploring the SX micro
    www.tdswieter.com
    Adding the videos to YouTube would mean lower res, and that I'd actually have to learn to post videos on YouTube. :)
    My goal is to produce this: http://www.knifeedge.com/forums/show...16&postcount=4 (it only exists in that simulator)
    I want to start working on the airframe now, but to me that's more daunting than the electronics. The motors rotate forward for normal flight, and up to hover. I've been working on getting the 'static motor' version as stable as possible before I move on. I'd like to be able to hover it hands off, though it's actually quite stable now. I'll take a new video in a few days if I have time. I reduced the weight of the propellers, so the motor response is quicker, and I added code to 'help' level it, using the accelerometer and Kalman filters. If I turn it up too high it starts to oscillate, but even with it set low it helps quite a bit.
    I'll post more as it happens. Thanks for the encouragement, everyone. Thanks especially to Parallax for this very cool chip. This is my 3rd quadrotor, and the Propeller-based version was the simplest to code by far, and the most fun. I get to spend more time tweaking and less time figuring out how to drive servos, read RC inputs, and do math on one thread. :)
    Jason
    Jason - I believe in a desing like this two of the propellers rotate in one direciton and the other two rotate in the opposite direction. Or maybe they have a differenet blade or pitch or something like that. What did you do with yours?
    BTW, YouTube is a breeze. They now have a high resolution viewing option to if you upload your video in a high res format.
    www.tdswieter.com
