I get this Windows error message
"Error: Expected a directive"
when downloading the .bsp code from my laptop to my BS2P40. Also, the
second line of code in the Basic Stamp Editor automatically highlights:
'{$PBASIC 2.5}
I had the same code working fine when downloaded from my PC back in the
Fall but now nothing but that error message. I've listed the full code
below (downloaded from the Parallax site) in case it is of some use.
There's nothing more frustrating than spending 2 to 3 hours on a problem
and getting no where. Note, if I remove the second line of code,
"'{$PBASIC 2.5}", the code downloads but the LCD display does nothing.
What is this line supposed to do???
Any ideas are appreciated
Regards and Happy New Year,
Chris Dundorf
'{$STAMP BS2p}
'{$PBASIC 2.5}
'Title: Parallel_lcd 2X16.bsp
'this code will work for the stamp2p and 2pe with the 2X16 parallel Lcd
' -----[ Declarations
temp VAR Byte
Lcd_pin CON 0
Non_op CON 0
char VAR Byte
' -----[ Initialization
DATA "Hello, This is the LCD demo."
Initlcd:
PAUSE 1000
FOR temp = 0 TO 2
LCDCMD 0,48
PAUSE 1
NEXT
LCDCMD Lcd_pin,32 'sets lcd in 4 bit mode
LCDCMD Lcd_pin,40 'sets lcd to 2 line mode with 5x8 font
LCDCMD Lcd_pin,12 'turns on display with no cursor
LCDCMD Lcd_pin,6 'set to auto-increment cursor
LCDCMD Lcd_pin,1 'clears display
' -----[ Main Routine
start:
FOR temp = 0 TO 27
READ temp,char
IF temp = 15 THEN Next_line
out:
LCDOUT 0,non_op,[char]
PAUSE 100 ' This number adjust the rate of displaying the text
NEXT
STOP
' -----[ Subroutines
Next_line:
LCDCMD Lcd_pin,192 'places cursor to line 2
GOTO out
[Non-text portions of this message have been removed]
Chris,
I just cut and pasted your code into the editor, and it compiled no problem.
Are you using the latest version of the editor? The '{$PBASIC 2.5} directive
tells the editor to use the latest syntax and include the latest commands
suppported by the editor.
Jonathan
www.madlabs.info
----- Original Message -----
Sent: Tuesday, December 30, 2003 7:53 PM
Subject: [basicstamps] "Error: Expected a directive".... Parallel-lcd
2x16.bsp
> '{$PBASIC 2.5}
> Chris Dundorf
> '{$STAMP BS2p}
> '{$PBASIC 2.5}
> temp VAR Byte
> Lcd_pin CON 0
> Non_op CON 0
> char VAR Byte
> Initlcd:
> PAUSE 1000
> FOR temp = 0 TO 2
> LCDCMD 0,48
> PAUSE 1
> NEXT
> start:
> FOR temp = 0 TO 27
> READ temp,char
> out:
> NEXT
> STOP
> Next_line:
> GOTO out
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/basicstamps/
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to:
I pasted your code into the Version 2.1, Beta 1 editor/compiler and it
does not complain about the $PBASIC directive. There is a FOR without a
NEXT. You may want to consider indenting code blocks to make things
easier to read. May I suggest "The Elements of PBASIC Style" that you
can find on our web site.
-- Jon Williams
-- Dallas Office
-----Original Message-----
Sent: Tuesday, December 30, 2003 9:54 PM
2x16.bsp
'{$PBASIC 2.5}
Chris Dundorf
'{$STAMP BS2p}
'{$PBASIC 2.5}
temp VAR Byte
Lcd_pin CON 0
Non_op CON 0
char VAR Byte
Initlcd:
PAUSE 1000
FOR temp = 0 TO 2
LCDCMD 0,48
PAUSE 1
NEXT
start:
FOR temp = 0 TO 27
READ temp,char
out:
PAUSE 100 ' This number adjust the rate of displaying the text NEXT STOP
Next_line:
GOTO out
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
John,
1. I'm running Stamp Editor V1.32. Could this make a difference? In
case it might I'm downloading V2.0.
2. What is the function of this line of code? '{$PBASIC 2.5}
3. Thanks for the suggestion on PBASIC Style. I just did a quick
copy and paste from the .pdf file to include as a reference. This
leads me to another question. Is there a way to copy and paste code
from .pdf files and maintain the formating of tabs and line spaces,
etc?
Chris
p.s. Please use cdundorf@junodotcom for direct replies if any.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
it
without a
you
> -- Jon Williams
> -- Dallas Office
> From: cdundorf@j... [mailto:cdundorf@j...]
lcd
> 2x16.bsp
the
highlights:
> '{$PBASIC 2.5}
the
code
problem
nothing.
> Chris Dundorf
> In case it might I'm downloading V2.0.
Yes, the editor version is your problem. The directive you ask about tells
the compiler to use the updated syntax of PBasic 2.5, and the earlier editor
cannot use that syntax. Install that new editor version and your problem
should go away.
Gary
Please, please, please ... some of you are nervous about the "Beta 1"
tag on our software. While it may not be perfect, we test everything
pretty thoroughly before releasing, so please download and install
Version 2.1, Beta 1 -- this is our latest and best version of the
product. You must have at least version 2.0 in order to use the PBASIC
2.5 syntax.
-- Jon Williams
-- Dallas Office
Sent: Wednesday, December 31, 2003 9:31 AM
Subject: [basicstamps] Re: "Error: Expected a directive"....
Parallel-lcd 2x16.bsp
John,
etc?
Chris
it
without a
you
> -- Jon Williams
> -- Dallas Office
lcd
> 2x16.bsp
the
highlights:
> '{$PBASIC 2.5}
the
code
problem
nothing.
> Chris Dundorf
Yahoo! Groups Links
abuse@p....
Some PDFs will let you copy. Select the text tool, highlight your text,
then press Ctrl+C to copy. Some PDFs are encoded in such a way that
prevents copying text -- none of ours from Parallax are encoded to
prevent copying.
-- Jon Williams
-- Dallas Office
John,
etc?
Chris
it
without a
you
> -- Jon Williams
> -- Dallas Office
lcd
> 2x16.bsp
the
highlights:
> '{$PBASIC 2.5}
the
code
problem
nothing.
> Chris Dundorf
Yahoo! Groups Links
abuse@p....
