How to post program code in the forum.
Program code is unique, in that indentation and spacing are often important, especially with Spin, and it always looks better when rendered in a monospaced font. Fortunately, posting code so that it looks right and can easily be read by others is very easy. For example, here's some Spin/PASM code that was just pasted into the message edit box:
PUB stop
'' Stop the overlay object.
if gray_cog
cogstop(gray_cog - 1)
gray_cog~
DAT
org 0
entry mov block_cnt,#0
movd :wr_code,#disp_line
mov nsyncs,width
shl nsyncs,#4
add nsyncs,#3
Notice that none of the leading spaces gets displayed, and even interior spaces get compressed. This not only makes the code hard to read but, if copied and pasted, it wouldn't even compile.
Here's what the same code looks like when properly displayed in a code box:
Code:
PUB stop
if gray_cog
gray_cog~
DAT
org 0
mov nsyncs,width
shl nsyncs,#4
add nsyncs,#3
See how much easier it is to read and how nicely everything lines up? It's not hard to make this happen. When creating or editing your post, just enclose your code between [code] and [/code] tags, like this:
http://forums.parallax.com/attachmen...3&d=1297987610 http://forums.parallax.com/attachmen...2&d=1297993394
IMPORTANT NOTE: Do not use the WYSIWYG Editor when entering or editing posts with code. Use the Basic Editor instead. The WYSIWYG Editor messes with numeric data following a percent (%) sign and enters the code incorrectly.
... and how to help others learn to post code.
If you see a forumista who needs help posting code, copy and paste the following as a reply to his post:
[url=http://forums.parallax.com/showthread.php?129690&p=978076&viewfull=1#post9780 76][img]http://forums.parallax.com/attachment.php?attachmentid=78421&d=1297987572[/img][/url]
What will get displayed is this:
http://forums.parallax.com/attachmen...1&d=1297987572
Re: ... and how to help others learn to post code.
...tsk...tsk - a blatant hack of an Industry Icon!
You, Sir, should be ashamed of yourself!
:smile:
DJ
BTW - thanks for the info.
:lol: :lol: :lol: :lol: :lol: :lol:
:lol: :lol: :lol: :lol: :innocent: :thumb:
Good one!
DJ
Re: How to post program code in the forum.
Hey, this thing is great!
Incredibly useful post!
It has been made sticky.
J
'bout time! :)
That's what I like about these forums. Stuff that just helps!
Thanks for doing that Jen, (couldn't Phil have done that, being a Moderator, or does that take a Staff or Admin to do that?)
Quote:
Originally Posted by Publison
...couldn't Phil have done that, being a Moderator, or does that take a Staff or Admin to do that?
I'm sure it's restricted to Admins, as it should be. Even if I could have, though, stickifying one's own thread unilaterally would be considered bad form. BTW, I'm not a Moderator. Browser (my cat) has the mod status in this household -- and not just in the forum. :)
I can remember the picture of Browser high atop the Phil 1980-90's magazine archives in the Priority box. I guess Browser can read, Priority means Authority . :)
Check the shrimp status.
Phil Pilgrim (PhiPi)
I got an error message about some token but I resubmitted it anyway.It didn'nt copy as it was written.
[' {$STAMP BS2}
' {$PBASIC 2.5}
' COM Parameters
COM_RX PIN 0 ' rx pin
COM_TX PIN 2 ' tx pin
COM_SPEED CON 84 ' baud 9600
COM_10MS CON 10 ' 10ms unit
' Protocol Command
CMD_BREAK CON "b" ' abort recog or ping
CMD_SLEEP CON "s" ' go to power down
CMD_KNOB CON "k" ' set si knob <1>
CMD_LEVEL CON "v" ' set sd level <1>
CMD_LANGUAGE CON "l" ' set si language <1>
CMD_TIMEOUT CON "o" ' set timeout <1>
CMD_RECOG_SI CON "i" ' do si recog from ws <1>
CMD_RECOG_SD CON "d" ' do sd recog at group <1> (0 = trigger mixed si/sd)
' Protocol Status
STS_AWAKEN CON "w" ' back from power down mode
STS_ERROR CON "e" ' signal error code <1-2>
STS_INVALID CON "v" ' invalid command or argument
STS_TIMEOUT CON "t" ' timeout expired
STS_INTERR CON "i" ' back from aborted recognition (see 'break')
STS_SUCCESS CON "o" ' no errors status
STS_RESULT CON "r" ' recognised sd command <1> - training similar to sd <1>
STS_SIMILAR CON "s" ' recognised si <1> (in mixed si/sd) - training similar to si <1>
' Protocol arguments are in the range 0x40 (-1) TO 0x60 (+31) inclusive
ARG_MIN CON 64 ' 0x40
ARG_MAX CON 96 ' 0x60
ARG_ZERO CON 65 ' 0x41
ARG_ACK CON 32 ' 0x20 'TO READ more status arguments
'Groups and Commands
GROUP_1 CON 1 '(Command count: 1)
G1_UNNAMED_COMMAND_0 CON 0
RES_ERROR CON 255
RES_TIMEOUT CON 254
RES_COMMFAIL CON 253
RES_BUILTIN CON 32
'Robot Constant
VRLED PIN 4
'Global Variable
VRA VAR Byte
VRA1 VAR Byte
VRGROUP VAR Byte
VRCOMMAND VAR Byte
' Main Start
INPUT COM_RX
HIGH COM_TX
Restart:
LOW VRLED
VRGROUP = 0
DEBUG CR, "Setting up VRbot... "
'Wake up or stop recognition
GOSUB VR_Wakeup
DEBUG "awake... "
'Set SI Language
VRA1 = 0
GOSUB VR_SetLanguage
DEBUG "language ", DEC VRA1, "... "
'Set 5 seconds timeout
VRA1 = 5
GOSUB VR_SetTimeout
DEBUG "timeout ", DEC VRA1, "... "
DEBUG CR, "VRbot ready!"
VR_Loop:
DEBUG CR, "VRbot in group ", DEC VRGROUP, " waiting for command... "
LOW VRLED
PAUSE 150
IF VRGROUP > 0 THEN HIGH VRLED
VRA1 = VRGROUP
GOSUB VR_RecognizeSD
'-- handle errors or timeout
IF VRA1 = RES_ERROR THEN
DEBUG "error"
'try again in the same group
GOTO VR_Loop
ENDIF
IF VRA1 = RES_TIMEOUT THEN
DEBUG "timed out"
VRGROUP = 0 ' back to trigger
GOTO VR_Loop
ENDIF
IF VRA1 = RES_COMMFAIL THEN
DEBUG "comm failed"
'resync and try again
GOSUB VR_Wakeup
GOTO VR_Loop
ENDIF
'-- got a command
VRCOMMAND = VRA1
IF VRCOMMAND <= RES_BUILTIN THEN GOSUB VR_Action
GOTO VR_Loop
VR_Action:
DEBUG "got ", DEC VRCOMMAND
SELECT VRGROUP
CASE GROUP_1
SELECT VRCOMMAND
CASE G1_UNNAMED_COMMAND_0
PAUSE 0 '-- write your code here
ENDSELECT
ENDSELECT
RETURN
'=== VR Routines ===
' Wake up:
VR_Wakeup:
TOGGLE VRLED
VRA = CMD_BREAK
SEROUT COM_TX, COM_SPEED, [VRA]
SERIN COM_RX, COM_SPEED, 100*COM_10MS, VR_Wakeup, [VRA]
IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup
LOW VRLED
RETURN
' Inputs:
' VRA1 = language index (0 = english, ...)
VR_SetLanguage:
VRA = CMD_LANGUAGE
VRA1 = VRA1 + ARG_ZERO
SEROUT COM_TX, COM_SPEED, [VRA1]
SERIN COM_RX, COM_SPEED, 20*COM_10MS, VR_CommFailed, [VRA]
VRA1 = VRA1 - ARG_ZERO
'IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup
RETURN
' Inputs:
' VRA1 = timeout (in ms, 0=forever, 255=default)
VR_SetTimeout:
VRA = CMD_TIMEOUT
RETURN
' Inputs:
' VRA1 = SI knob (0=loosest, 2=normal, 4=tightest)
VR_SetKnob:
VRA = CMD_KNOB
RETURN
' Inputs:
' VRA1 = SD level (1=easy, 2=default, 5=hard)
VR_SetLevel:
VRA = CMD_LEVEL
RETURN
' Inputs:
' VRA1 = wordset (0=trigger)
' Ouputs:
' VRA1 = result (0-31=word, 32..=builtin, 253=comm err, 254=timeout, 255=error)
VR_RecognizeSI:
VRA = CMD_RECOG_SI
GOTO VR_Recognize0
VR_RecognizeSD:
VRA = CMD_RECOG_SD
VR_Recognize0:
' send Group/WS
' wait for answer
SERIN COM_RX, COM_SPEED, 600*COM_10MS, VR_CommFailed, [VRA]
IF VRA = STS_RESULT THEN
' send ack
VRA = ARG_ACK
' wait for recognised command code
SERIN COM_RX, COM_SPEED, 20*COM_10MS, VR_CommFailed, [VRA1]
ELSEIF VRA = STS_SIMILAR THEN
' send ack
VRA = ARG_ACK
VRA1 = VRA1 - ARG_ZERO + RES_BUILTIN
ELSEIF VRA = STS_TIMEOUT THEN
VRA1 = RES_TIMEOUT
ELSE
VRA1 = RES_ERROR
ENDIF
RETURN
VR_CommFailed:
VRA1 = RES_COMMFAIL
RETURN ]
Paul,
You want to use code tags. The brackets are part of the tags. Don't replace the word "code" with your program. The word "code" is part of the tag. Here's what you'd enter: (I used a zero instead of an "o" so the word "code" will show up here.)
[C0DE]' {$STAMP BS2}
' {$PBASIC 2.5}
' COM Parameters
'<more code here>
VRA1 = RES_TIMEOUT
ELSE
VRA1 = RES_ERROR
ENDIF
RETURN
VR_CommFailed:
VRA1 = RES_COMMFAIL
RETURN[/C0DE]
This will show up as:
Code:
' {$STAMP BS2}
' {$PBASIC 2.5}
' COM Parameters
'<more code here>
VRA1 = RES_TIMEOUT
ELSE
VRA1 = RES_ERROR
ENDIF
RETURN
VR_CommFailed:
VRA1 = RES_COMMFAIL
RETURN
