| Parallax Forums > Public Forums > Robotics > Suggestions for increasing the torque on robot steering system--new system almost done | Forum Quick Jump
 |  Duffer Registered Member
       Date Joined Feb 2007 Total Posts : 296 | Posted 9/29/2009 7:20 PM (GMT -8) |   | Shortening the lever arm between the motor and the steering bar will increase the torque, but it will also decrease the travel length of the steering bar which will mean that the wheels won't turn as far.
Duffer | | Back to Top | | |
 |  Timmoore Registered Member
        Date Joined May 2008 Total Posts : 745 | Posted 9/29/2009 7:21 PM (GMT -8) |   | I can't tell but it looks like you have a 90degree gear that is turning the arm that is moving the steering? The choices I can see are different motor - slower/more torque - maybe a window motor since they often have the 90degree turn built in and tend to have a lot of torque Add gearing between motor and turning arm Change gearing and arm to be a screw gear - attach a screw rod to the motor, attach the nut to the steering column, when the motor turns it turns the screw rod then the nut can move side to side, this gives a large increase in torque. | | Back to Top | | |
         |  W9GFO Am I still a noob?
       Date Joined Jul 2006 Total Posts : 638 | Posted 10/26/2009 2:30 AM (GMT -8) |   | | | |
    |  Pi Guy Registered Member
       Date Joined Apr 2008 Total Posts : 642 | Posted 10/30/2009 4:02 PM (GMT -8) |   | Well, they obviously teach it somewhere since I'm doing the lathe work at school, but maybe it's just Idaho. I'm figuring it will have a lot of friction, but the motor is plenty strong enough to do the task. As it is, it seems to be breaking the system itself more than anything else. Or maybe that was just because an idiot was messing with it? But I now have to fix up a few things and hopefully make it stronger along the way. This is the second version of the steering system so I had better make it work.
Just to explain things further--I'm not sure what you are talking about with the lead screw, but if you're talking about the part that the 1X2" tubing is on it is actually a drill bit for cutting cement. It was just lying around, so I used it. I used tig to weld it to stainless pipe so it would fit in the 1" bearing, unfortunately making it lopsided, and then I pressed it in tightly so it isn't even necessary to use the set screws on the bearing. The part holding the bearing is just a pipe I cut and beveled to make it fit, and welded the other pieces to it so it would hold it and be easily mounted. The 1x2" metal part I mentioned earlier is just that, but with a 1/2" hole drilled in one side and a 3/4" hole in the other. To get it to fit in the 1/2" side, I used a grinder cutting blade to put a slot in it, forcing it to move with the screw, or drill bit. Hope this answered any questions, it really isn't too complex. PG | | Back to Top | | |
 |  mikediv Registered Member
        Date Joined Dec 2007 Total Posts : 455 | Posted 10/30/2009 6:23 PM (GMT -8) |   | | PiGuy is that a windshield wiper motor? It looks very robust. I recognized the drill bit very clever its amazing what some people can turn into working stuff thats a really big robot was it your go cart at one point? I would love to see some pictures of the whole thing | | Back to Top | | |
     |  PJ Allen Counsel of Despair ???
       Date Joined Sep 2005 Total Posts : 2807 | Posted 11/7/2009 4:38 AM (GMT -8) |   | | | |
  | Forum Information | Currently it is Friday, November 20, 2009 8:50 PM (GMT -8) There are a total of 393,724 posts in 55,520 threads. In the last 3 days there were 84 new threads and 703 reply posts. View Active Threads
| | Who's Online | This forum has 17686 registered members. Please welcome our newest member, micromang. 54 Guest(s), 7 Registered Member(s) are currently online. Details Kit Morton, Mike Green, RickB, blittled, Cluso99, benty, Rich_W8VK |
Forum powered by dotNetBB v2.42EC SP2.02 dotNetBB © 2000-2009 |
