| Parallax Forums > Public Forums > Propeller Chip > Book for absolute beginners. Propeller 101 | Forum Quick Jump
|  HollyMinkowski 104lbs of trouble
       Date Joined May 2009 Total Posts : 445 | Posted 8/11/2009 8:02 AM (GMT -8) |   | Another title that is sorely needed for the Prop.
"P8X32A Assembly language For The Complete Idiot" (I'd buy a copy) | | Back to Top | | |
       Date Joined May 2009 Total Posts : 445 | Posted 8/11/2009 8:17 AM (GMT -8) |   | @Oldbitcollector
Maybe someday I will write that asm book myself.
Right now it would be a case of the blind leading the blind  | | Back to Top | | |
 |  Harprit Registered Member
       Date Joined Dec 2008 Total Posts : 62 | Posted 8/11/2009 10:14 AM (GMT -8) |   | Where is the language described? What resources are available? Who sells the software?
I'll look into it but having just finished How to run motors with PIC microprocessors and How to make Instrument and controllers with PIC microprocessors And now finishing up the 101 book I'm a bit burned out right now!
The fact that there are not many good beginners books is a hallmark of the problems that we as a society and going through, and on the horizon is the death of the book as we know it today.
NOT GOOD
HSS | | Back to Top | | |
 |  Bob Lawrence (VE1RLL) Registered Member
       Date Joined Aug 2007 Total Posts : 420 | Posted 8/11/2009 11:53 AM (GMT -8) |   | | | |
 |  microcontrolled My head is SPINing.
       Date Joined Oct 2008 Total Posts : 867 | Posted 8/11/2009 12:11 PM (GMT -8) |   | I would take that ASM book! That makes 3! Just call me micro.
If it's not Parallax then don't even bother.
I have changed my avatar so that I will no longer be confused with others who use genaric avatars.
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap shipping unless specified! 150 left!!
| | Back to Top | | |
       Date Joined Dec 2008 Total Posts : 62 | Posted 8/11/2009 12:12 PM (GMT -8) |   | Cosmic:
Thanks
HSS
PS Re information of robot on left asked about by many. This robot is built in my book on Intro to robotics published in 1996!!!! It is the first weight shifting robot of its kind. Its the first one that actually walked or should I say waddled I put it in the public domain for all to build and learn Not counting the servos and controller you can build it for $5.00 with a fret saw. All the many new humanoids now on the market are based on the information in my book but only one guys actually say that what he sells is based on my book. So much for credits re intellectual property created. It must be the times. HSS. | | Back to Top | | |
  |  Radio Shack Jim Registered Member
        Date Joined Jul 2008 Total Posts : 99 | Posted 9/20/2009 5:41 AM (GMT -8) |   | Any More updates? I am very interested in Particularly the interface of SPIN and PASM. RadioShack_JIM | | Back to Top | | |
 |  StefanL38 Registered Member
        Date Joined Sep 2006 Total Posts : 958 | Posted 9/20/2009 7:43 AM (GMT -8) |   | | | |
       Date Joined Dec 2008 Total Posts : 62 | Posted 9/20/2009 2:02 PM (GMT -8) |   | No more updates The book is getting close to done Its essentially scoped out but needs fortification and checking I'm up to 270 pages or so today. Will be 350 or so. Writing code frantically This is one fantastic chip. Who knew! Never thought I'd have so much fun First material has been submitted to McGraw Hill Final submittal due Dec 15 I will meet the deadline Book will be out in about 3 months after that. As promised, lots of pictures Lots and lots of code Pages and pages of code Every line commented in detail Lots of real world applications
Here is the thing as of now
Outline as of Sept 10 2009 There will be minor changes as books gets to completion
Preface Part. 1 The Propeller. What it is Understanding the system 1 General introduction to the Propeller chip 2 Propeller chip 3 Hardware and software set up 4 Propeller tool environment 5 The memories 6 The 8 cogs 7 One Cog 8 Special terms and ideas 9 The Spin language 10 Why and how of shared memory 11 Tasks that are suited to parallel processing
Part 2. Input and output, the basics Beginning learning by doing 12 General discussion of the projects 13 Setting up the LCD so we can get started 14 Reading inputs and creating outputs 15 Binary Inputs and outputs 16 Pulse widths 17 Duty cycles 18 Reading and setting Frequencies. 19 Read a potentiometer.
Part 3. The Projects. Combining the basics. Advanced Learning by Making 20 Liquid Crystal Displays in detail 21 R/C Servo 22 Touch panel 23 Motors prelim discussion 24 Motor amplifiers 25 Small DC motors 26 Stepper motors 27 Simple single point Controller 28 Using a gravity sensor to create a level 29 Using a light detector to create a light meter. 30 Running a DC motor with an optical encoder Metronomes Output to seven segment displays
Appendix Debugging Suppliers Terms
Index
A million thanks to all who took time to help me. Here and at Parallax And did I ever need help, and how!
Best regards Harprit | | Back to Top | | |
      |  whiteoxe Registered Member
       Date Joined Aug 2007 Total Posts : 97 | Posted 11/3/2009 6:54 PM (GMT -8) |   | | Be good if you sat down down with a beginner and watched them walk through the entire book and also gave a copy to a couple of beginners and asked them to make notes of what they had trouble with ? Would be challenging in some ways if you understand completely a subject and are writing to an audience that knows very little. At some point it would be hard acknowledging./seeing your own assumptions? | | Back to Top | | |
       Date Joined Dec 2008 Total Posts : 62 | Posted 11/4/2009 10:48 AM (GMT -8) |   | _Spinner: You will recall that a lot was put on this discussion board about a year ago so I do have an idea about what is going on but I don't think it will be possible to go through the scenario you have described considering the deadlines we are working under. If we had the time it would be the best way to do it, I agree. Thanks for the input HSS | | Back to Top | | |
 | 93 posts in this thread. Viewing Page : 1 2 3 4 | | Forum Information | Currently it is Saturday, November 21, 2009 11:37 AM (GMT -8) There are a total of 393,861 posts in 55,536 threads. In the last 3 days there were 84 new threads and 712 reply posts. View Active Threads
| | Who's Online | This forum has 17692 registered members. Please welcome our newest member, old guy. 51 Guest(s), 13 Registered Member(s) are currently online. Details Siri, Jay Kickliter, Mike Green, Jim Fouch, Dogg, hover1, ErNa, Harley, Sapieha, Electronegativity, Tubular, Leon, MicroDirk |
Forum powered by dotNetBB v2.42EC SP2.02 dotNetBB © 2000-2009 |
