__trisc var not defined going from SX28 to SX48 [solved] — Parallax Forums
YendorYendor Posts: 288
edited 2010-05-17 17:41 in General Discussion
I'm moving my project from an SX28 to SX48 for some additional breathing room.
When I compile the code on the SX48, the following error occurs:
··MOV FSR,#__TRISC
Error 3 Pass 2: Symbol <__TRISC> is not defined
I see __TRISX(0) var at $FF, but don't see __TRISC var·like I did on the SX28.
How does __TRISX function in collaboration·with __TRISC and the other __TRIS vars on the SX48?
Thanks!
[noparse][[/noparse]update] not sure if this is correct, but defining __TRISC as a byte var compiles, at least.
Post Edited (Yendor) : 5/17/2010 5:43:35 PM GMT
  • BeanBean Posts: 8,129
    edited 2010-05-16 11:18
    Yendor,
    What line of SX/B code is generating the "MOV FSR,#__TRISC" line ?
    The SX48 doesn't use individual __TRISA, __TRISB, etc variables because the SX48 can read and write the TRIS registers. On the SX28 they are write only.
    Bean
    Use BASIC on the Propeller with the speed of assembly language.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
    March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
    There are two rules in life:
    · 1) Never divulge all information
    If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
  • YendorYendor Posts: 288
    edited 2010-05-16 23:19
    Thanks Bean
    it's from am in line assembly instruction.
    I am still unclear what to do,as of yet.
    Any help appreciated!
    It's from the serial code interrupt.
  • ZootZoot Posts: 2,227
    edited 2010-05-17 00:01
    Bean means attach your SX/B program (or the snippet that generates that assembly). I would post the whole program. You have SX48 defined in the device line?
    Thanks for the guidance guys - I think I have this one figured out now.
    Now I have another one, which comes up with another thread.
