Proposed method of LMM for PropBASIC. Comments requested.
BeanBean Posts: 7,794
edited February 2010 in Propeller 1 Vote Up0Vote Down
Before everyone gets all fired-up...LMM will not be in PropBASIC until AFTER the inital release. There are too many potential bugs.
But I was cleaning up the compiler code and though I'd better at least get an idea of how I am going to implement it.
So here is my version of LMM.
I have about zero experience with LMM, so I'd like some comments from member who have used it.
I have unrolled the execute loop 4 times, I know I could go further but I want to save as much space as possible for variables.
This code seems to work fine. You can copy and paste the main body of the code many times (past the 496 instruction limit) and it will still work.
''  *** COMPILED WITH PropBasic VERSION 00.00.79  Feb 3, 2010 ***
CON                                                          'DEVICE P8X32A, XTAL1, PLL16X
  _ClkMode = XTAL1 + PLL16X
  _XInFreq =   5000000                                       'FREQ 80_000_000
' LEDS    PIN 23..16 LOW                                     'LEDS    PIN 23..16 LOW
' Delay   SUB 1                                              'Delay   SUB 1
PUB __Program                                                'PROGRAM Start LMM
  __OFFSET := @__Init
  CogInit(0, @_LMM_Entry, @__DATASTART)
DAT
                  org           0
__Init
                  mov           dira,__InitDirA
                  mov           outa,__InitOutA
                  jmp           #_LMM_JUMP
                  long          @Start - @__Init
Start                                                        'Start:
                  mov           __temp1,#255                 '  LEDS = 255
                  shl           __temp1,#16
                  and           __temp1,LEDS
                  andn          outa,LEDS
                  or            outa,__temp1
                  mov           __param1,#100                '  Delay 100
                  jmp           #_LMM_CALL
                  long          @Delay_ret - @__Init
                  long          @Delay - @__Init
                  mov           __temp1,#0                   '  LEDS = 0
                  shl           __temp1,#16
                  and           __temp1,LEDS
                  andn          outa,LEDS
                  or            outa,__temp1
                  jmp           #_LMM_CALL
                  jmp           #_LMM_JUMP                   '  GOTO Start
                  mov           __temp1,#0                   'END
                  waitpne       __temp1,__temp1
Delay                                                        'SUB Delay
                  mov           __temp1,cnt                  '  PAUSE __param1
                  adds          __temp1,_1mSec
                  mov           __temp2,__param1
                  mins          __temp2,#1 WC
__L0001
    IF_NC         waitcnt       __temp1,_1mSec
    IF_NC         djnz          __temp2,#_LMM_JUMP
                  long          @__L0001 - @__Init
                  rdlong        __PC,__PC                    'ENDSUB
Delay_ret
                  long          0-0
DAT
  'LMM Execution code
  ORG 0
_LMM_Entry
                  mov           __PC,__OFFSET
_LMM_LOOP
                  rdlong        __INSTR1,__PC
                  add           __PC,#4
__INSTR1
                  nop           ' Placeholder for LMM instruction
                  rdlong        __INSTR2,__PC
                  add           __PC,#4
__INSTR2
                  rdlong        __INSTR3,__PC
                  add           __PC,#4
__INSTR3
                  rdlong        __INSTR4,__PC
                  add           __PC,#4
__INSTR4
                  jmp           #_LMM_LOOP
_LMM_JUMP
                  rdlong        __PC,__PC
                  add           __PC,__OFFSET
                  jmp           #_LMM_LOOP
_LMM_CALL
                  rdlong        __temp1,__PC
                  add           __temp1,__OFFSET
                  add           __PC,#8
                  wrlong        __PC,__temp1
                  sub           __PC,#4
                  rdlong        __PC,__PC
                  add           __PC,__OFFSET
                  jmp           #_LMM_LOOP
                  '             Variables for LMM execution code
__OFFSET         LONG 0-0' Set by spin
__PC             LONG 0  ' Program counter
__InitDirA       LONG %00000000_11111111_00000000_00000000
__InitOutA       LONG %00000000_00000000_00000000_00000000
_1mSec           LONG 80000
LEDS             LONG 255 << 16
_FREQ            LONG 80000000
__remainder
__temp1          RES 1
__temp2          RES 1
__temp3          RES 1
__temp4          RES 1
__temp5          RES 1
__param1         RES 1
__param2         RES 1
__param3         RES 1
__param4         RES 1
__paramcnt       RES 1
FIT 492
CON
  LSBFIRST                         = 0
  MSBFIRST                         = 1
  MSBPRE                           = 0
  LSBPRE                           = 1
  MSBPOST                          = 2
  LSBPOST                          = 3
DAT
__DATASTART
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
Post Edited (Bean) : 2/5/2010 6:21:04 PM GMT
logo.png?503
Esterline Research & Design
thitt@esterlineresearch.com
We offer consulting on the following areas of expertise:
Frequency Control - Micro-Controller/Processor Projects
Test and Automation - General Programming and Coding
Circuit Design - Board Layouts
  • 12 Comments sorted by Date Added Votes
  • jazzedjazzed Posts: 11,791
    edited February 2010 Vote Up0Vote Down
    Hi Bean.
    Using an LMM macro jump vector table will simplify things and allow you to use
    the same kernel regardless of where the LMM macros are implemented.
    The downside is using longs for the table and slightly delayed execution.
    DAT org 0
    INIT    jmp #_init  ' 0
    MJMP    jmp #_jmp   ' 1
    MCALL   jmp #_call  ' 2
    ' ... other macros.
    _init
    ' init body
    _jmp
    ' jmp body
    _call
    ' call body
  • Bill HenningBill Henning Posts: 6,413
    I don't see any problems... and your CALL/RETURN mechanism is basically the same as for PASM, which I think will make it easier for beginners to understand.
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
    Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler Largos - upcoming nano operating system
    www.mikronauts.com / E-mail: mikronauts _at_ gmail _dot_ com / @Mikronauts on Twitter
    RoboPi: The most advanced Robot controller for the Raspberry Pi (Propeller based)
  • BeanBean Posts: 7,794
    Am I correct that the "LONG @label - @__Init" will not cause any problems if executed since all the condition bits will be zero (since the value will always be less than 18 bits) ?
    Bean
    logo.png?503
    Yes, you are correct. I rely on that in my LMM code too.
    Bean said...
    Bean
  • Dr_AculaDr_Acula Posts: 5,478
    Having seen on a board in front of me the awesome power of LMM with Catalina C (programs hundreds of kilobytes long), I'm really excited about similar code for Basic.
    A few months ago I was pretty chuffed when I compiled a C and a Basic program on the Zicog, and after compilation both returned a "40kb free" message. More than the memory on the propeller. Then RossH goes and blows that out of the water with ten times that. And now PropBasic is heading the same way. I am *very* impressed.
    The code looks great. Speed is not a big issue ('tis now as it ever was, use assembly for speed), but the ability to start writing a program and to keep writing and keep writing and never worry about running out of space, well that is just awesome.
    Answers: 1) A quadcopter. 2) Very high. 3) The internet. 4) A lot. 5) No.
    @Dr_Acula,
    · PropBASIC LMM is not virtual memory. It runs from HUB ram, so programs are still limited to 32K. But that is a far cry from 2K. Also lots of room for variables with LMM.
    · Speed is about 1/5 of native code. I think that is a fair trade-off. Code with lots of calls and jumps will suffer most, but will still be·blazing compared to spin.
    · You will be able to specify LMM for the main code, and for each TASK. So some tasks can be native (for video drivers and stuff) and some can be LMM within the same program.
    · Actually for small TASKs it takes less space to make them native. I think very few TASKs will be LMM, but I wanted to have the option.
    · I ran into an issue using VAR arrays. I use MOVS and MOVD to do indexing, well that doesn't work in LMM. So I had to make two more LMM routines to handle it.
    · I'm going through the compiler and making the changes to handle LMM. I may post it for some testing, but NOT as the offical beta version.
    · Once you get your head around it, LMM isn't that hard. I hope the LMM code generated will provide assistance to PropBASIC users who want to do LMM in assembly.
    · Thanks for the encouragement.
    Bean.
    Post Edited (Bean) : 2/6/2010 4:32:32 AM GMT
    logo.png?503
    32k would be a huge amount for propbasic, given how efficiently the compiler seems to be coding. As an aside, I've been coding all day on an SBasic program and only got to 10k.
    I'm looking at my code at the moment and thinking maybe it could be ported to propbasic?
  • Toby SeckshundToby Seckshund Posts: 2,001
    "to start writing a program and to keep writing and keep writing and never worry about running out of space, well that is just awesome."
    Thats not "awesome" its "Microsoft"
    Style and grace : Nil point
    If anyone is interested in testing LMM in PropBASIC send me a PM.
    Bean.
    logo.png?503
  • Christof Eb.Christof Eb. Posts: 291
    Hi Bean,
    during my experiments with PropBasic I have seen, that you can do really very much without LMM and you have got full speed.
    So I am very glad to read, that there will be the choice for each task if this task will run in the cog only or with LMM!
    Is there a chance to include some sort of debugging feature into the LMM? It should be possible to insert debugging steps between program parts?
    Perhaps you could install some sort of a "hook" for a debugger routine,·that can be called after each basic line. This debugger routine could be done later.
    The debugger routine might copy a source code line number and all cog variables to hub ram. A debug task might then send the information to a serial line.
    The hook could perhaps be used for some sort of polled interrupts too?
    I think, that debugging features are often·very valuable, perhaps more valuable then execution speed.
    (I would like to have multi line comments too...)
    Christof
    Hmmm, A debugger hook is an interesting idea. I'll have to explore that a little bit more.
    Just to give you some idea of speed:
    PASM instructions without jumps require 20 clocks (on average), 3 instructions require 16 clocks, then the·4th requires 32 clocks.
    Jumps require 32 clocks. Calls require 96 clocks.
    So code with alot of jumps and calls do take a real performace hit.
    Bean.
    March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
    Post Edited (Bean) : 2/11/2010 7:29:27 PM GMT
    logo.png?503
