Robotics Base for the 12V Motor Mount Wheel Kit (27971) and Caster Wheel (28971 — Parallax Forums
Ken GraceyKen Gracey Posts: 7,386
edited 2010-06-01 02:41 in Robotics
Hey all,
Over the Christmas holidays I made a number of revisions (6-7) of a round robot base from high-quality, 9-layer solid wood core finish-grade plywood (the best plywood I could find within 100 miles of here). These were cut on an older ShopBot I found on Craig's List. It's a direct gear/pinion stepper arrangement so the resolution is about .003" which is fine for this kind of work. I made these bases because I think our customers need a quicker method of getting started (for a low cost) with the motor mount and wheel kits / caster wheels.
Why marry such fine aluminum machined products to a wooden base? Robotics is a personal hobby and everybody has their own preferences. As much as I'm an all-metal kind of crafter, maybe wood has a place in this application. It's one material that's easily workable with only minimal tools. It can be drilled without chipping, sanded and painted nicely with minimal skills, and produced at a very low cost. Within a few minutes you could have a robot platform ready to roll. Acrylic chips when drilled, metal isn't easy to work with, etc.
And what's with this round shape? Goofy-looking, I agree. But, round robots can free themselves more easily from chairs and other obstructions.
Some of the features of the robot base:
- 18" diameter
- 1/8" rounded bevel on all edges
- 12V Motor Mount and Wheel Kit + Encoders (27971) mount underneath the base with 1/4 x 20 stainless steel button head screws
- Drill patterns for one (or two) Caster Wheels (28971)
- Drill patterns for up to 10 Ping))) sensors using the Ping Protector Stand (725-28015)
- Battery platform for 12V 7AHr batteries mounts underneath motor mount bearing block with 1/4 x 20 stainless steel button head screws
The battery platform holds the battery in place, but doesn't prohibit it from fore/aft movement. You can secure the battery by mounting a small piece of angle aluminum on either side of the platform.
The goal was to provide the minimal number of holes and decisions necessary, leaving plenty of customizing and work for the robo-head. For example, no holes were drilled for HB-25s, Parallax 3x4 boards (BOE, Prop Proto Board, BASIC Stamp Super Carrier, etc.). There is plenty of room underneath to mount CCFL tubes for full-on 'bot pimping, too. This is certainly not an attempt to make a new standard in robot bases, as your craftsmanship and experimentation is what the hobby is all about. But, I hope that these bases will at least get people started more quickly.
Until we put a professional ShopBot or ShopSabre CNC router in Parallax, these platforms are coming from my garage (limited production capacity). We'll set up a gantry mill at Parallax as soon as we clear out a storage space (our former chip programming room). For now, we have 20 sets available at $29.99 and I can make another run as necessary. Until the marketeers get this on the web you'll just need to call our Sales staff and ask for one of "Ken's wooden robot platforms from his office desk" and tell them to sell it to you "non-stock". They should get these on-line by the end of the week at which time they'll have a part number.
What you get in the kit:
- 18" round robot base
- Battery pack platform
- (4) 1/4 x 20 3/4" stainless steel cap screws for mounting the motor mount bearing blocks to robot base
- (4) 1/4 x 20 1/2" stainless steel cap screws for mounting the battery pack platform to bottom of motor mount bearing blocks
- (6) 6-32 x 7/8" socket cap screws + nylon lock nuts for mounting two caster wheels to robot base
The drawings are provided under Creative Commons 3.0 license - use them freely and cut your own robot base if you wish.
I know you'll want a photo of a built-up robot. I can't wait to build one from these bases so it shouldn't be too long before I provide more photos. But for now you can get a general idea of what this looks like from an older photo I have attached (a smaller, 16" diameter base).
Hope some people find this useful.
Sincerely,
Parallax Inc.
Parallax Inc.
Follow me at http://twitter.com/ParallaxKen for some insider news.
Post Edited (Ken Gracey (Parallax)) : 3/26/2010 2:01:35 AM GMT
«13
  • Ken GraceyKen Gracey Posts: 7,386
    edited 2010-01-02 20:57
    And a picture of a very old revision to give you the idea. This is a 16" diameter, but the robot base shown above has now become 18" diameter. This extra room is really helpful.
    - Ken
    1000 x 718 - 237K
  • Roy ElthamRoy Eltham Posts: 2,996
    edited 2010-01-02 23:36
    This is really neat.
    I think it would be pretty cool if you guys made a kit for this that had the motors, wheels, castors, HB25s, and a controller board. Sort of like a big brother to the Stringray.
    Check out the Propeller Wiki·and contribute if you can.
    edited 2010-01-03 00:01
    Roy, we can do that. It'll get fairly expensive depending on where we draw the line.
    12V Motor Mount and Wheel Kit $279.99
    HB-25s 2@ $49.99
    Caster Wheels 2@79.99
    That's $540 and the Ping))) are not added.
    With ten (10) Ping))) sensors and Ping Mounting Bracket the cost could climb to $700.
    And then we could offer a discount, of course.
    Still not much compared to R/C toys, and there's often a heck of a lot more satisfaction and learning from a quality robot.
    edited 2010-01-03 00:44
    Well the Base kit could be like the Stingray and not include PING))) or any sensors really. I think the main thing it to have a working mobile platform to start from, just like the Stingray only bigger, faster, and more powerful. Maybe you could do a MSR1 contoller board that leaves out the motor controller stuff and instead has connections for the 2 HB-25s? MSR2? Then you could have a 10 PING)))s and brackets kit for it, and so on. [noparse]:)[/noparse]
  • WhitWhit Posts: 4,191
    edited 2010-01-03 00:46
    Ken,
    Looks great!
    I was going to make a base out of Dupont Corian. But it turns out you can't buy unless it is intalled by factory authorized companies.
    I like your wooden platform and I like the zero turning radius design too.
    Whit+
    Post Edited (Whit) : 1/3/2010 12:52:52 AM GMT
    edited 2010-01-03 01:02
    Whit, I've found Corian at the local countertop fabricator as scraps. They've usually got heaps of it laying around - have you taken this approach?
    What you describe is a a real racket - anybody should be able to buy that stuff. Have you checked eBay?
    I bet we can find some. . . wonder if it would cut well on the CNC router [noparse]:)[/noparse]
    Ken
  • DufferDuffer Posts: 374
    edited 2010-01-03 02:43
    How about something like these SHDPE (Super High Density Polyethylene) plastic cutting boards. And less than $27 for an 18x24" piece (already edge finished and in assorted colors). Less than $24 in sets of six. They're probably not much harder to work than plywood and they would be indistructable. Route/mill recesses for the motor drive and the casters to remove the possibility of shear forces and·clean, fool-proof parts location.
    http://www.cuttingboardcompany.com/cuttingboards.asp?id=3
    Also, talk about "pinping your bot", imagine how those CCFL tubes would look under that translucent HDPE deck or in routed grooves cut into the top of the deck!
    Duffer
    Post Edited (Duffer) : 1/3/2010 3:18:42 AM GMT
    edited 2010-01-03 03:29
    Ken and Duffer,
    Thanks for the ideas! Ken, I did know that you could get scraps, but the closest to me is about 100 miles away. I should not have been so easily put off. Duffer, I did think about cutting boards, but I couldn't find a color I like or a big enough board. I should have googled it! Thanks for the link.
    I like the idea of either for several reasons. I thing it would be easy to work with saw, drill and route. They use a router to round the corners of countertop and at sinks. I like the color through the material, non-condutivity, rigidity but slight flexibiltiy. Look at the cool colors of the Corian here - http://www2.dupont.com/Surfaces/en_US/products/corian/new_colors.html I was thinking Nocturne, Cobalt, or even Mardi Gras,·but lots of colors would work including some of the bright solid colors.
    Duffer - these cutting boards are really good option with all the advantages of the Corian. I like the thickness too. I think that 1/2 would be a minimum - this is also available in the Corian.
    Thanks for getting me excited again. I start working and then get distracted, till something gets me fired up again. I got the 12 volt motors for something really cool - robotic wise -·and wanted the platform to be equally as neat as the wheels. I probably should have built a test platform in something quick and easy to work our other issues, but I didn't.
    Whit+
    Post Edited (Whit) : 1/3/2010 1:42:36 PM GMT
    edited 2010-01-03 03:59
    Whit,
    If you send me the material of your choice I'll cut whatever you want on my CNC router. Or, if you prefer one of the wooden bases above just make the request and I'll get one off to you quickly. I didn't realize you were still sitting on a set of 12V Motor Mount + Wheel kits - we need to put those to use so you have a great demo for the kids.
    - Ken
    edited 2010-01-03 13:46
    Ken,
    Thanks for the kind offer! I will be in touch...
    Whit+
    edited 2010-01-03 23:59
    The bases painted up quite nicely. The process was sand lightly with 360 grit, then 600 grit. Next I used water-based polyurethane brush-on sealer. Then I taped off for a stripe and sprayed Krylon paint, followed up with a final spray of water-based polyurethane. This was a bit of a test since I covered a water-based product with an oil-based type, and then a final coat with water-based. I probably wouldn't do this on a skateboard or some type of outdoor hardware, as the water-based products are very easy to apply but with a tradeoff of less durability.
    1000 x 750 - 151K
    1000 x 750 - 97K
    edited 2010-01-04 01:37
    Ken,
    They bases are beautiful. I like the wood and the paint looks fantastic!
    Whit+
  • ercoerco Posts: 20,254
    edited 2010-01-04 02:35
    Sweet finish.
    Hmmm. Maybe my Poor Cousin robot needs a duct-tape racing stripe to "keep up with the Graceys".
    edited 2010-01-04 05:35
    And a few more photos before I ran out of Ping))) sensors and mounting brackets. Bummer on that, but good thing I get to go to work tomorrow! Oh wait. . .I don't even have time to think about robots at Parallax. Grrrr.
    This particular robot is going to Phil Pilgrim when it is finished (except for wiring, which I'll leave for him to do). The hope is that Phil will write us some useful and simple GPS waypoint navigation code for this robot. Knowing him, he'll probably write a sweet little Perl GUI to download the waypoints to the robot. We'll see what he does in a couple of months.
    Parallax Inc.
    1000 x 750 - 143K
    1000 x 750 - 151K
    edited 2010-01-04 07:45
    This is really going to be fun! My first mission, though, will be to build an RF remote kill switch (actually a keep-alive button or "dead-man switch"). Those motors have enough torque to do some serious damage if things go awry, as they surely will before I've tamed this spirited colt! smile.gif
    edited 2010-01-04 16:03
    Ken,
    That bot is looking great. I can't wait to see what Phil does with this. Sounds like he is already thinking...
    Whit+
  • MikerocontrollerMikerocontroller Posts: 310
    edited 2010-01-05 01:35
    · Very nice looking robot.· Of course the Poor Cousin looks good too.· Please explain the ice on the deck.· I thought you were in California.· I hate to admit·it, ·but·I was sweating this Saturday while·clearing out a storage locker·in San Diego.· Also, do the neon tubes generate elctrical noise?
    edited 2010-01-05 01:55
    Hey Mikerocontroller,
    I live in N. California in the Sierra Nevada mountains at 6,700 feet. About 12 miles from my home is the regularly recorded deepest annual snowpack in the continental USA at Donner Summit along I-80. Snow covers the ground for more than half of the year in a strong winter. While you sweat it out in the storage locker I'm probably freezing in the mountains.
    The CCFL tubes haven't posed a problem for any of my electronics. Aside from the 12V 300 mA current draw they only generate a little bit of warmth.
    Poor cousin could be outfitted with CCFL tubes, too. I'll contact erco and see what he wants to add some flair to his robot.
    Post Edited (Ken Gracey (Parallax)) : 1/5/2010 5:47:11 AM GMT
    edited 2010-01-05 17:19
    Parallax now has 20 of these kits in our inventory under part number 28975 "Robot Base Kit".
    Price is $29.99.
    Preliminary documentation is attached, too.
    Parallax Inc.
    edited 2010-01-05 18:09
    Poor Cousin (PC) thinks the CCFLs look great on your SuperBot, but can't commit the space (or power) to use them just yet. But I thank you for your kind offer!
    300 mA@12V to power the CCFLs? That's more power than one of PC's drive motors uses at 12V! Stall current is just 500 mA. Efficiency-wise, my PC is more like a Prius.
    I gotta have something on SuperBot. [noparse]:)[/noparse]
    edited 2010-01-08 20:58
    Me again, shamelessly resurrecting the thread again. Caught this photo flying around on our internal e-mail. I guess the marketeers are preparing this product for the web! Part number 28975 - $29.99.
    Parallax Inc.
    700 x 700 - 65K
  • Jen J.Jen J. Posts: 649
    edited 2010-01-08 23:56
    The Robot Base is up at Parallax.com now.
    www.parallax.com/tabid/145/ProductID/635/Default.aspx
    All your base are belong to us.
    Have a great weekend.
    Cheers, JJ
    edited 2010-01-08 23:59
    Ken:
    You go ahead and bump this thread all you want. Your CNC'ed platform is gorgeous, but my homebuilt robot thread is gaining momentum. People are sharing photos and details of their handmade creations and they are amazing! I hope everyone who has ever built their own robot posts there. I think the homemade crowd thread may surpass you in total views and posts over the weekend. Let the games begin! [noparse]:)[/noparse]
    PS: Did you see the centerfold someone posted at http://forums.parallax.com/showthread.php?p=869446·???
    Post Edited (erco) : 1/9/2010 12:06:34 AM GMT
    edited 2010-01-09 00:41
    I was initially excited that this became available... but then I went to add the motor/wheel kits and casters to my order and they are out of stock, same for the PING))) metal brackets. Now I am bummed that I have to wait until the 30th to get those.
    Maybe by then you guys can work out a package for the motor/wheel kit, 2x HB-25s, 2x casters, and 10 pings with brackets? [noparse]:)[/noparse]
    edited 2010-01-09 22:05
    Two more photos to complete the visual tutorial.
    This particular robot is destined for Phil Pilgrim, in hopes that he does some GPS work for us using the robot base kit. Lucky guy, isn't he?
    Parallax Inc.
    1000 x 750 - 223K
    1000 x 750 - 232K
    edited 2010-01-09 22:26
    Ken Gracey said...
    Now the onus will be on me to meet Ken's expectations for this project. Oh, the pressure! [noparse][[/noparse]hyperventilates]
    Seriously, this will be some major fun. Thanks, Ken!
    edited 2010-01-09 23:02
    That looks great Ken, can't wait til I can get all the parts to build one of those myself.
    edited 2010-01-10 00:16
    @Roy, I realize we're out of stock of all machined parts. We're working to change that every day. We just increased the quantity we build per-job, which will do a couple of things: (a) lower the unit cost by amortizing setup times across more parts and (b) increase our inventory level overall. I'd hope to reduce some prices after our next manufacturing round.
    Thanks for the interest!
    Ken
    edited 2010-01-10 01:59
    The new pics look great and I love the Stingray board on there. My son's comment was, "Oh my gosh! So many eyes!"
    I am also glad to see the base up on the Parallax site too.
    Whit+
    edited 2010-01-11 03:45
    @Ken, sounds decent. As soon as everything is available, I'll be putting in an order. Thanks.
