Stingray Standards?
WhitWhit Posts: 3,736
edited October 2009 in Robotics Vote Up0Vote Down
Hey Stingray owners,
Would there be any advantages to establishing some pin standards for the Stingray. I know that standards are voluntarily used by some on the Propeller for things like video, audio, SD Card adapter,·etc and that the Propeller Wiki has these laid out. See - http://propeller.wikispaces.com/PinDefs.spin
Something like this might be handy for·some things on the Stingray too. Any thoughts on this?
Whit+
Post Edited (Whit) : 10/13/2009 6:02:46 PM GMT
Whit+
  • 5 Comments sorted by Date Added Votes
    edited October 2009 Vote Up0Vote Down
    Seems like an interestnig way to be able to share program code between owners. But, I think it could be complicated by different users having different mixes of attached devices. I wonder if a complimentary idea would be that any "shared code" use constants for pins and not bury "magic numbers" in the program code? Just a thought
    Whit,
    Currently the pins are defined as follows:
    P30 – P31 – Serial communication and programming (standard across all Propeller platforms)
    P28 – P29 – I2C bus…not brought out currently, but connected to 64KB EEPROM
    P24 – P27 – H-Bridge Control (detailed in the documentation)
    P0 – P23 – Generic I/O through translator chips. Three groups of eight pins.
    That’s pretty much going to be the same no matter what. Now, if we develop certain sensors and accessories, that may cause some of the generic pins to used for those purposes, or more unlikely to share the I2C pins. Is this what you were referring to?
    Chris Savage
    Parallax Engineering
    50 72 6F 6A 65 63 74 20 53 69 74 65
    Chris Savage | Engineering Tech | Main Office: (916) 624-8333 | Direct to Tech Support: (888) 997-8267 | Website | Twitter | Google+
  • WhitWhit Posts: 3,736
    Chris and TinkersALot,
    That is what I was talking about. The fixed pins do seem to be well documented in the Stingray Robot Documentatin Sheet -http://www.parallax.com/Portals/0/Downloads/docs/prod/robo/28980-StingrayRobot-v1.1.pdf So those pins are set in my mind.
    I was also thinking about P0-P23 - the generic ones. I know people will use them very differently. I just thought that maybe one might be assigned LCD display, or Ping))) or Pings))).
    I also like TinkersALot's idea of one easy fix up in the constants rather than scattered through the code.
    I guess you could also have P0-p7 at 3.3v (jumped from the power headers), P8-P15 at 5.0v and P16-P23 at VIN if you needed too.
    Whit+
    Whit+
    Whit,
    As the Stingray matures as a product and we have more accessories for it, our code examples will define how we recommend connecting the various accessories. No doubt though since the Stingray is a highly customizable platform customers will find what works for them in their specific applications.
    Chris Savage
