Keychain DVR — Parallax Forums
Keychain DVR
ercoerco Posts: 20,250
edited 2010-04-21 18:19 in General Discussion
My latest WOW find from China/Ebay is a tiny digital video camera/recorder for ~$40. Keychain car remote-sized, they call it a "spy" unit,·and there are tons of uses. Stick one on your robot for a POV cam. Acts like a flashdrive, USB hookup. Records nice quality audio & video, 640x480, 30 FPS, also takes digital stills at 1280x960. Rechargeable built-in·battery, built-in·4 GB memory will record ~1 hour of video! So tiny that you really can mount it anywhere with foam tape, weighs just 16 grams. Friggin' amazing.
My sample videos:
http://www.youtube.com/watch?v=zde3DduyEWw·outdoor·bike ride
http://www.youtube.com/watch?v=9Yjw6Z0-Kpw·indoor light level
Sept·3 Edit: Recommend you ONLY look for 4 GB cameras that have a CCD sensor (NOT CMOS) and 30 FPS. There are cheaper 8 GB cameras using CMOS sensors that shoot 15 FPS and the picture and audio is poor quality. These will shoot longer duration·video,·but are suitable only for a fixed location camera. Moving them around gives a blurry smear of an image.
Post Edited (erco) : 9/3/2009 1:59:37 AM GMT
«1345
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-08-23 17:58
    Wow is right! That is really an amazing find if there ever was one. I take it you download the video after you've taken it? I'm thinking about maybe hacking one of these, and intercepting the video feed or something... That way you can have LIVE video on your robot. This is just awesome erco!
  • WhitWhit Posts: 4,191
    edited 2009-08-23 18:34
    Great find erco!
    After watching the bike ride video I am now on the floor with a damp washcloth on my head - the room is still spinning. I feel like I just watched The Blaire Witch Project. wink.gif
    This would be very cool on a robot! What an amazing little device. Thanks for the heads up.
    Whit+
    edited 2009-08-24 12:40
    WoW! Thankx for the link.
    That would be useful as part of some security projects.
    A controller could use that to take short videos...if it
    turned out easy to interface/hack.
    In a few years all camcorders will have no visible lens, or it will be
    a small fisheye lens. Higher density and more sensitive image chips will take the wide view
    image through a pinhold lens thus capturing all the action and no focus
    needed as the pinhole makes it all sharp. Software will then take the distorted
    fisheye image and convert that back to where everything looks normal.
    - Some mornings I wake up cranky.....but usually I just let him sleep in -
    edited 2009-08-31 04:16
    I managed to snag 3 of these things.
    Going to see if I can pop one open and interface it to a prop.
    I have several cool project ideas for them.
    Should be able to interface it safely using opto couplers I would think.
    I'm curious what's inside these...bet it's cramped on that circuit board.
    The video and audio from these is amazing!
    Be cool if it was possible to make the 8gb of flash ram available to the prop.
    Imagine a propeller security device that could snap thousands of 1.2mp snapshots
    and 6+ hours of 640 by 480 video at 30 frames per sec....and add just 20.00 to
    the project cost.
    Might be best to pull the board out and interface it, then encapsulate it in
    black plastic leaving just a row of pins sticking out the bottom...so snoops
    can't figure out what it is and how cheap they really are.
    They need to make a 16:9 aspect ratio model of this thing.
    Videos made with this seem to have a date and time stamp on the bottom,
    at least I think they do? Found several keychain spy cam vids on youtube
    and they seem to have the stamp. Wonder if it can be turned off?
    - Some mornings I wake up cranky.....but usually I just let him sleep -
    Post Edited (HollyMinkowski) : 8/31/2009 5:08:17 AM GMT
  • ercoerco Posts: 20,250
    edited 2009-08-31 22:28
    You and your encapsulating plastic... LOL.
    Glad you're pleased with 'em, I think they are the bee's knees. I like the date/time stamp myself. You set the time by making a "settime.txt" file in the root directory of the device. Might try setting to all blank or all zeroes to turn it off.
    BTW, a friend found a firmware glitch when he left his camera on to record video until the onboard memory was full. He got about 1 hour on a 4 GB unit. He could download the file properly, and then he deleted the file, but the camera wouldn't function again until he reformatted it FAT32. Then all was fine.
    MFR's Directions:
    How do you set the time of video and images taken with the device?
    Create a new Txt file on your computer named “SetTime”. Open the file, input the date and time in the following format: year , month, day, hours, minutes and seconds format (for example : 2009.05.18 18:28:23). Then save the text file, connect the device via USB and copy the text file to the root catalog of the device then disconnect the device. Then turn on the device again to record a video as usual; connect to the computer again and you will find the date and time have been changed to the one you had set. If this method does not work, please try formatting the device first, and then repeat the previous steps.
    edited 2009-09-01 03:05
    These things just have to be worth 20-30 dollars.
    An 8gb thumb drive costs nearly as much.
    If it can just be interfaced to the prop you could
    create all sorts of security gizmos and just fun toys.
    Put it into a mundane object and have one cog running
    at low clock speed watching and waiting for a good opportunity
    to snap an image or record video....possibilities are endless.
    Put it in a tiny box with a prop and velcro it to your dash, every time the car starts
    the prop could start recording. It could start deleting files
    in a fifo manner to always have space to continue. That would
    be a great thing to have if you were in an accident or something
    strange just happened while you were on the road.
    Time lapse photography, one frame every second or two and this thing
    could run for months.
    Build a custom package with a prop that uses this as the camera and flash ram parts.
    Plug in a VGA monitor and kbrd and customize what the device does in a zillion ways.
    Sell them on ebay to security guys and geeks. A cheap GPS add on and a real time clock
    would make the data look good in court.
    Picture a tiny plastic case holding this cam, GPS, a prop
    and a few amp hrs of battery...put a rare earth magnet on the case and stick it in a good
    spot beneath the frame of a car....or wherever and however you could place it.
    Make it small enough and with ingenuity you might get the target to
    carry the thing around with them.
    I wonder what sort of processor this thing has and wouldn't it be cool
    if it can be re-programmed via the USB... if I had designed it I would
    have left that option in case a bug turned up...they could be fixed and not
    just dumped. I found out that the same device has VOX functions but the
    newest version left off the switch, to save $ I'd guess. The vox started taking video
    when sound was detected.
    edited 2009-09-01 22:01
    These DVRs are all over Ebay now, and I just got an inferior unit from a different source, so be careful what you're buying. My original 4 GB unit took much better photos and video because it had a CCD sensor and 30 FPS. The newer 8 GB unit was actually cheaper, but uses a CMOS sensor that is less sensitive, and the unit uses only 15 FPS. Granted, the 8 GB unit can store 4 hours of video compared to 1 hour for the 4 GB, but the audio & video quality is much lower. Its best use would be as a stationary camera, because the image smears noticeably when you move the camera.
    I suggest you stick with CCD and 30 FPS, even if the memory is smaller (like the 4 GB unit). The rechargeable internal battery is probably only good for about an hour anyway.
    edited 2009-09-02 06:50
    Ouch!
    I hope the ones I ordered are 30 frames/second and not 15 :-(
    edited 2009-09-02 14:42
    Whit and Holly, you both "enjoyed" our bike video. Actually, that was a fairly tame ride for us, I was riding the brakes the whole way. My 8-month pregnant wife (twin girls due any day now) was on the back, so we ride very conservatively these days. But between the camera's slightly fish-eye lens, the DVR & Youtube video compression algorithms and that howling wind noise, the video does look daredevil-worthy. Not to worry, I know I'm hauling precious cargo and we take it easy. As of last weekend, the bike is parked and we're max attentive to baby watch 2009. When my future posts only appear between 2-4 am feedings, you'll know that li'l Amy & Lindsey have arrived. Woo-Hoo!
    edited 2009-09-02 15:43
    Yes, I "enjoyed" the ride! Glad to hear all is well. I love the names.
    Thanks for the tip on the inferior DVRs! I am about to place an order.
    Edit- I just took a look. I can find the 30 frames per second, but the ones I can find are all CMOS. I will keep looking. Even the one you initially linked is a Color CMOS sensor.
    Whit+
    Post Edited (Whit) : 9/2/2009 3:54:23 PM GMT
    edited 2009-09-02 19:50
    @erco
    Wonderful news about the twin babies!
    I just love babies!!!
    Makes me shudder to think of her behind you on that wild ride while 8mos pregnant...shame on you guys smile.gif
    Post a photo of the girls after they arrive.
    I bet I am going to end up with the cheaper cmos cams...darn it.
    It does say 30fps though..not 15. If you can provide a link to cams
    that you know are like the first one you bought please post it.
    When the babies arrive use your original cam to make a short clip of the darlings.
    Then make another with the cmos cam you just bought and post them to http://www.ziddu.com/
    (you can post anonymously without registering) and let us download the original clips
    instead of the youtubed versions.... maybe you could post that wild bike ride
    on ziddu as well.
    Post Edited (HollyMinkowski) : 9/2/2009 7:58:43 PM GMT
    edited 2009-09-03 01:12
    Whit: Sorry about that bum info. When I first posted, I didn't know I had a "good" camera and that there were "bad" cameras out there. I'll go back and edit my first post. Now I know to look only for 4 GB CCD 30 FPS cameras such as this one: http://cgi.ebay.com/Keychain-DV-DVR-Video-Camera-Spy-cam-CCD-Camcorder_W0QQitemZ250486006903QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a52212477&_trksid=p3286.c0.m14
    That's a $35 Buy it Now with free shipping, the best I can find right now. Hope it helps, and glad you approve of·our baby·names!!!
    Holly: Glad you like babies so much! Ours are not identical, and per the ultrasounds so far, one's·already bigger than the other. If you're a diapering expert, please stop by and give us a few dozen lessons the next time you're in LA!
    Post Edited (erco) : 9/3/2009 2:00:54 AM GMT
    edited 2009-09-03 01:59
    No appology required! I did not mean for you to go shopping either - but... now that you have - thanks!
    Wonder if you could make a dirty diaper detector out of one of these? http://www.parallax.com/Store/Sensors/PressureFlexRPM/tabid/177/CategoryID/46/List/0/SortField/0/Level/a/ProductID/557/Default.aspx
    Whit+
    Post Edited (Whit) : 9/3/2009 2:59:05 AM GMT
    edited 2009-09-03 02:25
    erco, I'm the fastest diaperer in the west!
    I get to LA about twice/year
    I usually drive there, straight
    out I10 all the way.
    I will bring the proper equipment
    for a guy to change a diaper.
    (guys really really hate to change diapers)
    LoL, while looking for a thumbnail image of rubber gloves I saw this one...wonder what this
    edited 2009-09-03 03:05
    You kids are awesome! That's just the kind of humor that just might get me through this (wonderful) ordeal.· The gas mask is standard equipment, natch. Whit's methane detector·is just a BS2 away from triggering·some Rube Goldberg-type robotic diapering contraption built from Holly's parts roundup. How hard could it be? Except someone beat me to it... http://dsi.kqed.org/index.php/projects/story_big/85/
    What's funny is that I'll be almost 49 when the girls are born, so I'll be 70 when they're 21. At some point, I'll·be going into diapers just as they're coming out of them.
    BTW, the GOOD cameras I have seen have the time/date stamp on the bottom right in red, as shown in Holly's still image shown previously. The BAD cameras have the time/date code in small hi-res white numbers on the top left.
    Post Edited (erco) : 9/3/2009 3:10:31 AM GMT
    edited 2009-09-03 03:38
    It's pretty confusing about these cams.
    One place I found on ebay shows the box that says ccd
    but the written description says cmos...wth
    I have found no youtube vid from a spy cam that
    has the time in upper left. Why don't you take a short vid
    using the 2nd 'bad' cam you got and post to
    Ziddu.com anonymously and then put the link here so
    we can download the actual video...and does that bad cam
    look exactly like the good one?
    Saw some reviews for the 8gb cams that claims they are good?
    Maybe there is more than 1 version of the 8gb cams?
    Where did you buy the 2nd cam that was not as good as the first?
    So we can avoid them...probably it's where I just bought mine.
    I have bad karma for stuff like this.
    Look at this toon.... the pregnant lady is at one of those
    Obamacare town halls.... The 6 greasy burritos sounds
    about right for a pregnant lady that far along.
    HUNGER!
    Your wife will like this toon...
    A 70yr old guy with 2 young daughters!?
    I wants me some babies, but it makes me nervous.
    I just can't believe that 'it' can really stretch that far.
    It's just that I picture this big scene where the MD says
    "it's just not gonna fit through, quick! bring me the scissors!"
    They actually do sometimes have to just cut the edge of 'it' so
    that the baby will fit through...it's called an episiotomy
    and I feel faint just thinking about it.
    don't go look at real images on google of that...it will scare your wife.
    Post Edited (HollyMinkowski) : 9/3/2009 3:56:34 AM GMT
  • W9GFOW9GFO Posts: 4,010
    edited 2009-09-03 04:28
    HollyMinkowski said...
    I was very relieved on the night my twins (fraternal) were delivered when the doctor decided a cesarean would be best. I was not looking forward to witnessing such trauma. My own trip down the birth canal, which took literally days, resulted in my mother first seeing her son as a banana with eyes. Fortunately, baby skulls are soft so I didn't retain the potassium rich appearance for very long. My kids didn't have to make that trip, the doc just reached in and pulled them right out, nice. More interesting is when they pulled the entire uterus out and flipped it side to side checking that all was ok. You'd think they would handle internal organs more carefully.
    If you decide to have kids, good for you! Undoubtedly, the most rewarding experience possible.
    If you decide not to have kids, good for you! You'll avoid massive amounts of stress and worry plus you won't be contributing to overpopulation - and you'll save tons of money.
    Rich H
    The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
    edited 2009-09-03 05:13
    Holly: here's your·DVR comparison on Youtube:
    4 GB, CCD, 30 FPS: http://www.youtube.com/watch?v=9Yjw6Z0-Kpw· Good audio/video
    8 GB, CMOS, 15 FPS: http://www.youtube.com/watch?v=-avxyodwVis· Bad audio/video
    Note the different time stamp formats.
    edited 2009-09-03 07:55
    The image on the 8gb cam actually looks just fine.
    But the smearing limits it to lesser uses than the other cam.
    OK for stills probably, ok for certain uses like security
    type chores where the quality may not be as critical.
    I just bet that the flash is much cheaper and slower than the
    4gb one and that is why the frame rate has dropped.
    I'm inclined to think it is trying to write at 30fps but the
    flash speed just won't allow it, thus it is missing frames
    and the rate is lowered.
    They probably decided that they could sell more with
    8gb of really cheap and slow flash than 4gb of fast flash...price probably came
    out about the same but 8gb sounds better to the masses.
    The flash speed can be determined by sending a large file
    to it over USB and checking the time it takes compared to
    the 4gb version.
    Oh well, if my cams turn out to be slow ones I will just have
    to find someone selling the same ones you bought first.
    If the cams won't do 30fps I will give scathing reviews to
    the seller so that others might be forewarned.
    In the place where you put the buyers review
    I will place a link to a youtube vid of me using their
    Was that link you posted before the one to the very same seller and camera you got 1st?
    edited 2009-09-03 15:57
    Holly: My camera seller & listing are long gone now. I emailed the seller gadget.topseller88 in that new link I posted, to ask about CCD and 30 FPS, he says yes to both.
    One other thing: the good cameras came in a nice little gift box (~4x3x1.5 inch) and included a 120v USB charger in the package. The bad cameras simply·came in a small flat envelope in bubble wrap. Both included the cable and minimal instructions.
    The above seller above also·verified·his cams come in a gift box w/charger, so I'm pretty sure they are the good ones.
    edited 2009-09-03 22:00
    PCB closeups for your hacking consideration. This is the good 4 GB CCD 30 FPS cam.
    1280 x 960 - 289K
    1280 x 960 - 293K
    1280 x 960 - 295K
    1280 x 960 - 523K
    edited 2009-09-03 22:19
    WoW! cool...
    Were they hard to get popped open?
    I foresee a use for both the 35$ better ones and the 20 dollar cheapies.
    The lower quality ones will still suffice for lots of gadgets you could make
    That circuit looks awfully tiny... I will have to use the rework station at work
    with the binocular scope attached to make changes and connections to those tiny things.
    Be nice to make them start filming or taking stills in response to changes in
    the cameras detected image or sound, remote switch closures..etc
    I wonder how difficult to tap the video data stream from cam to the
    propeller for analysis?
    edited 2009-09-03 22:24
    Oh, I looked at your other youtube vids and saw one where you are with your wife.
    When you said she was behind you on that bike ride I didn't realize it was a bike for 2 smile.gif
    She really was behind you...that looks like a fun way to exercise.
    edited 2009-09-03 22:32
    Yipee, the flash is on ordinary micro sd it appears.
    I expected it to be one of those cob chips covered with epoxy.
    Looks easy enough to connect to the pins for the USB socket.
    Also appears you can easily encapsulate it in plastic and leave the mic
    and cds cam exposed at the front.
    Then harvest the battery.
    Looks very hackable, be a good article for Hack-a-day
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-09-03 22:43
    HollyM.> will bring the proper equipment
    Holly, good thing you prepared Erco with most of the pictures of the require diaper-changing gear (for guys, that is).
    erco> How hard could it be?
    Hi erco,
    Clearly, Holly wanted you to be ready - but I'm guessing she also didn't want to scare you too bad, seeing how she left out the picture of the guy-item needed most for a particularly messy change.
    Namely, the full-body Tyvek hazmat suit.
    Good luck (sincerely) to you and your wife!
    - Howard
    edited 2009-09-03 23:12
    I think I found the good cams for 29.96 shipping included
    Does this look like the same setup of parts and boxes that came with your cam?
  • vaclav_salvaclav_sal Posts: 451
    edited 2009-09-04 00:05
    What is missing for my project is remote access!
    All I “need” is Bluetooth (mode of operation) of 100 meters range.
    Any radical suggestion?
    The “challenge” is it has to be super tiny!
    edited 2009-09-04 00:45
    @Bean
    I sent u a pm with the url
    I want to make sure they are indeed the right cams before
    posting here. I don't want anyone to order thinking they
    Should be possible for a propeller to gain access to the 4gb
    class2 SDHC card and use for storage of data and programs.
    I wonder if anyone has put up an object for SDHC greater then 2gb?
    The prop could modify the image files directly, you can add
    any amount of data to the end of a jpg for instance. It could add
    gps location data, time, whatever.
    I just hope the 3 I bought have an 8gb sdhc in them. If so
    then they are still a great buy even if they are only good
    for still images...be great for time lapse.
    The one I sent the link for is worth something in parts alone.
    Lion battery, mic, cds sensor, 4gb SDHC card and socket, 5volt usb wall charger,
    what looks like it might be an eeprom chip.... I mean, even if it broke
    you could harvest those parts and do OK.
    edited 2009-09-04 00:48
    @vaclav_sal
    I remember there was a bluetooth board for low$
    in my thread called "Holly's cheap parts roundup"
    It's in this group. (sandbox)
    edited 2009-09-04 00:59
    CounterRotatingProps said...
    Girls are usually taught to change a baby at 11 or 12 years of age.
    So it is just another messy chore girls learn to deal with...we have several.
    Just not a big deal.
    There are things you watch carefully for like rash but that rarely
    comes up if you are keeping close watch for when baby needs
    changing. You can just stick a finger tip beneath the diaper
    to feel for wetness although the super absorbent diapers make that hard.
    Me, I pick the baby up and smell it's bottom close up, I can tell
    I bet some guys couldn't pass that test...LoL
    <ducks and runs>
    Post Edited (HollyMinkowski) : 9/4/2009 3:55:04 AM GMT
