Data acquisition speed — Parallax Forums
JasonZJasonZ Posts: 2
edited 2009-06-16 23:04 in Accessories
I've been playing with the BS2 stamp for a while now, using it to control position and record force. I've been using the PLX DAQ software to import my data directly into excel. The project is starting to require a much faster data acquisition that what's been previously attained·(~27 stamp loops / second).
I decided to remove the position part of the program, in an effort to speed things up - Now im getting about 37 force readings per second (polling·the ADC chip). Using subroutines in the program just barely slow it down. Some BS2px24 chips are ordered, and I assumed that the 19,000 instructions/sec would have some impact on the speed of the reads.
Is there anything else that can be done? How can I increase the speed at which PLX DAQ records data?
Much hope,
Jason
  • phil kennyphil kenny Posts: 233
    edited 2009-06-15 13:39
    Try posting your question regarding recording speed of PLX DAQ on the Yahoo
    Selmaware group at:
    tech.groups.yahoo.com/group/selmaware/?yguid=118350722
    phil
  • JasonZJasonZ Posts: 2
    edited 2009-06-15 14:37
    Also, would switching to the propeller chip help? Or another DAQ program?
    Thanks for the discussion group
    Jason
  • Jason-WIJason-WI Posts: 35
    edited 2009-06-16 21:22
    I have used Hyperterminal and sent text out of a BS2P40 with it comma delimited at high speed and then inport later into Excel. I have done 250 samples a second of a pressure transducer using a PIC16F877 at 20Mhz using PicBasic Pro from MElabs. A Prop should also be able to do high speed data acq as well as the SX using SXB. The BS2PX will get you a few more samples but nowhere near 250.
    Jason
    He who dies with the most toys wins!
  • LeonLeon Posts: 7,620
    A PIC24HJ32GP302 will give you 1.1 Msps (10-bits) or 500 Ksps (12-bits).
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 6/17/2009 2:03:20 AM GMT
